Vidbid Generator
  • #61
    Freedom Generator Mark III
    I just thought I would share my latest design modification.
    Please tell me what you think and why.
    I believe that flux paths must be controlled as best as possible.
    Vidbid
    VIDBID
    • #62
      Flux Containment Module
      I came up with a new idea for contain the flux.
      Upper FCM Shown Above
      Isolate and confine the flux and regulate its direction in modules, known as FCM, Flux Containment Modules, and mount the modules above and below a disc rotor, wire accordingly.
      There are two types of Modules: Upper Module and Lower Module.
      Vidbid
      VIDBID
      • #63
        56 Conductor Flux Containment Module
        A further embodiment.
        Vidbid
        VIDBID
        • #64
          FCM with Mounting Plate
          FCM shown with mounting plate.
          Vidbid
          VIDBID
          • #65
            Experiment Proposal for Laurent
            Hi Laurent,
            For your consideration, deflection of the B-field to avoid the return conductors.
            Vidbid
            VIDBID
            • #66
              Hi Laurent,
              Vidbid
              Hey Vidbid,
              I will give it a try, making a different type of winding...One where the "return lines" are outside or on the weaker (further) side of magnetic field...while we concentrate the heavier spiral winding on the "Equator Line".
              Something like this:
              [IMG][/IMG]
              Then with Dual Spiral Windings...
              [IMG][/IMG]
              Where the Magnetic Field (Purple Bubble) ends... in order that return windings run outside of it...
              [IMG][/IMG]
              We could use a non magnetic material...like a plastic washer to fill the space after magnets (not shown on 3D CAD) to turn and hold wires around it.
              Front View...
              [IMG][/IMG]
              • #67
                B-Field Isolation Generator & Flux Guide System
                Wow, Ufopolitics, very impressive drawings. Thank you for giving it a try. I agree. Non-magnetic materials must be utilized.
                My New Design: B-Field Isolation Generator & Flux Guide System
                and
                Vidbid
                VIDBID
                • #68
                  Hello Vidbid, i enjoyed your Questions, and enquiries on the Don Smith Thread a ways ago, Thanks, have you built and tested any of the proposed Motors or Generators you so kindly are showing here, or does time and funds, destract you.
                  BTW. did your solar panel setup, satisify your needs.
                  Regards Cornboy.
                  • #69
                    Hi. Probably a silly question. I cant help wondering why not vidbids first original idea but with one small change. Instead of winding the coil around 1 neo ring magnet, get 2 ring magnets and a steel washer all of same dimensions, then sandwich the washer between the two magnets with like poles facing the washer. then wind the coil around all three and leave the rest of the device the same.
                    • #70
                      Inertial Gradients
                      I want to mention Inertial Gradients. This idea came to me last night.
                      If I have a straight length of wire conductor with a B-field cutting across it on a rotating plastic disc, then at different points along the wire, those point are each experiencing different speeds.
                      Vidbid
                      VIDBID
                      • #71
                        Four Directions
                        Generation: Going in circles: The Four Directions.
                        Vidbid
                        VIDBID
                        • #72
                          @vidbid,
                          FYI, since you posted a reference to it on page 1 of this thread, you may be surprised at what Bruce DePalma himself had to say about "The Homopolar Handbook: A Definitive Guide to Faraday Disk and N-Machine".
                          He wrote a rather contemptuous review of it
                          Review of Valone publication by Bruce DePalma
                          • #73
                            B-Field Directed Wire by VIDBID - March 2, 2014
                            I came up with the idea of a B-field directed wire.
                            VIDBID
                            VIDBID
                            • #74
                              Shaft?
                              VIDBID
                              Hello Vid,
                              About N-Machine CAD's
                              On your Diagrams, remember to always set the axle/shaft line...it could be an intermittent one...
                              Also call views as convention CAD Diag...Front View, Side View, Top View, Rear View, Isometric...Perspective (3D) etc,etc...No "End" view...end from where?...front or rear?
                              When Front or Rear View, set the shaft as a Point and arrow it.
                              It is very important (mainly) on an N-Machine to always indicate shaft positioning.
                              For example, reading your End View above on left...am lost as where is the center of rotation?
                              Regarding rotation of the Magnetic Fields, When conductors cut Magnetic Fields...besides the fact of being Static, Moving...or slower, more dense than...The Main Reason why this is possible is by rotating magnets of SAME Polarity within the SAME Space Ring they create by rotation...Meaning, If you rotate within same space "ring" a North and a South...Both Opposite Fields will cancel out in every spin by "spatial replacement", producing absolutely no induction.
                              • #75
                                Hello Vid,
                                Thanks UFOpolitics.
                                Sorry about that.
                                I should have thought of that.
                                I guess if you took a piece of wire and cut it in half and looked at one of the the ends where you cut it (the wire), then I guess that is what I meant.
                                I guess I should have been more precise.
                                Sorry, my bad.
                                Something like this, I think.
                                VIDBID
                                PS: Doesn't anybody know of a free and easy to use CAD program? I'm currently using Windows Paint and CompactDRAW.
                                VIDBID
