Negative Side Discharge
Hey Dave
This thread has been great. Much input has got my hopes back up again Gotta git ready for the let down
Now let's talk energy. I am dumping to the neg terminal and I can go to a 40 amp plus discharge of pos energy to the neg side.
Those large batteries never get even slightly warm. I ran down one of those big beauties last night to 12.2vdc and today the discharge that they are receiving has been excepted much more readily than ever before.
I am very excited about the way these batteries run and charge so well.
There is no heat on these 6 devices so i am thrilled about that.
You see the capacitor bank is the biggest that anyone has shown on the web for hitting a battery with and on top of that everyone thinks they know what I need to use for a circuit to discharge them.
I didn't know that is for sure and like Matt said I need to learn to calculate. Well I know how to calculate and end up doing some after getting into the ball park.
So far what I am learning "that I like the sound of" is using more capacitance to fire the gates of fets. I am looking around at the websites for stuff. Matt answered one of my questions super good.
Matt said one thing and I said another and it went like this.
I said I wanted to build a 12 device parallel dump with mosfets not knowing which way would be best.
Matt said "Basically" "If I read Matt right" he said that using many drivers is the best way to cut down on heat.
I wanted to fire 6 - 12 devices with a single driver. Of course we are not really just talking about this dump, because I want to employ these chips to drive an inverter? 2 stage?
Yeah thats right I think 2 stage "Cheers to Matt" that last post blew me away with the circuit with 3 coils one wound ccw and the other 2 cw?
Let me know if you build one after supper. I could do it with 2n2222 and a 2n3906 maybe or some small transistors.
I think the cap at the top represents the cap bank?
Anyway back to my dumping (Had to get all that off my mind first)
The battery I am slugging is over 1000ah with a tiny little pulse of energy.
The way I envision the process is like beating a dirty rug on a tree as the only way possible to get it the cleanest. You could sweep the rug with a broom or vacuum it but striking it with the entire weight of the rug impacting and flexing does wonders.
This is my weak description of how much more powerful a cap dump is in cleaning and charging plates at the same time over the process of trickle charging or magnetizing plate.
It is true that once pulse charging has been done and cycles has been accomplished that the battery does go up much faster and does not need so much force to get the job done charging. Less and less should be needed now to charge this completely desulfated battery.
Without the Horse Power batteries are not able to be recovered in a reasonable amount of time. I have through this process of testing going on 2 years, I know what it takes.
I have used small energizers, I have used large energizers ALL on a wide range of true deep cycle AGM converted ALUM.
Nothing and I repeat "NOTHING" can out do a good health punch coming from the proper size unit matched to battery.
Energizers lower resistance so a charge will be excepted and help to recover batteries then GENERATOR MODE will drive them right up.
All energizers MUST and I repeat MUST be hooked to a cap bank first before the battery if you want to keep your battery in one piece. High voltage spikes will destroy any battery if hooked directly to an inductive spiking coil.
Kiss it good bye. So what we learn in our practical application is that batteries WANT and NEED pos energy and POS energy is what comes out of capacitors.
Like Matt said that he wouldn't spend so much time on the dump as he would on how I could charge CAPACITORS, hummm now I see what he means with that last circuit post.
Get the 2x plus recovery to a cap and discharger it in the form that the battery wants "Positive pulse power"
Today the battery went from 12.2vdc to 13vdc in an hour or so. This is the fastest I have seen it charge
Mike
Mike
