Understanding that liquid fuel will not burn, and needs to be vapor to achieve combustion (along with a oxidizer and ignition source) prompted a number of vaporizing carburetor designs over the years (including a couple of my own) in search of higher milage/efficiency and maybe lower emissions. The designs that I have played with in years past have been moderately successful but plagued with problems and proved impractical so got left by the wayside when the A.D.D. kicked in.
As with most things i just put it on a shelf in the back of the brain, where occasionally it worms it's way forward in my conciseness and proceeds to distract me for a short while.
The last couple of years some very basic concepts on the vapor keep niggling at me.
1. a sphere i.e.. fuel droplet has the smallest surface area for the greatest volume, vapor only occurring on the surface?
2. Gasoline components start to vaporize (but not all) @ 190f and up @ sea level.
3. Hot vapor mixed with air in carb type setup extremely volatile (much like HHO)
4. Heated fuel likes to vapor lock fuel lines
So what if
we take a fuel injection system boost the fuel pressure to say 100psi and heat the fuel to say 300deg F, install an after market computer (programable).
Fuel under high pressure should be able to be heated without boiling in the fuel rails, yet flash to vapor as it exits the injector.
Just a niggling idea
David
So what if
David
