COP 20.0 (2000%) Demonstration
  • Gentlemen,
    Just a suggestion. Stick with simple MOSFETS. See if you can get it to work first. KEEP IT SIMPLE.
    Why complicate things. Jim's worked on MOSFETS only and it worked just fine. Just prove the concept.
    • Hi Silver, I am using mosfets.
      Mario
      • another method in making the devise is a modular conceptual approach to waveform.
        It was suggested that understanding how to produce the Tesla wave would be far ahead.
        The lumpy wave, appears to be a series of envelopes in one direction.
        It is possible to look at the resistive load sensing transformer which is part of the instrumentation scope or part of the controller module or both by looking at the picture.
        My intention is to evaluate information given about concept and begin to formulate a simple platform and not a replica. From it we can understand basic skills finding design constraints from experimental data such as from the epoxy soft iron core. Not that simple is best but rather kept simple until it is imperative it needs more complexity and approximately how much of what is needed. More work is needed in understanding reluctance role in critical timing.
        The mosfets burned out alot (died as soldiers) this is the nature of the devise and what flows through it. It is problematic but not a major concept.
        some concepts to concider:
        There is elecrical energy that is carried by the current itself that is in addition to the energy in magnetic and electric fields.
        The devise uses watts that go back and forth unlike the current and voltage that are usually 90 degrees out of phase that is not available for work.
        • K.i.s.s.
          The K.I.S.S. formula works for me so I don't get all worn out before I get started Soft epoxy iron cores Okay well i don't know where you got that one but you sure make a lot of sense.
          "More work is needed in understanding reluctance role in critical timing."
          I wonder how to do that? Switched reluctance motors and circuits are plentiful
          Mike
          • The epoxy iron core, how it came about, why it is used and how to make it.
            after he explains core he talks about why longer wire coils convert to radiant energy.
            https://www.youtube.com/watch?featur...WvloZBgQ#t=950
            • Number 7 Bird shot
              I thought I remembered that he use an epoxy isolation transformer . Number 7 bird shot iron and epoxy. Thanks for shaking me , I went to sleep on that small detail, very very important. One small item like this and you strike out.
              Thanks Man.
              Mike
              • Hi All,
                I bought today the lecture:
                and posted my analysis results here:
                COP 20.00 (2000%) Times, Reactive Power Energy Source Generator,
                Regards, Stefan.
                www.overunity.com
                • Pulsing motor coils and cap discharges
                  Originally posted by hartiberlin View Post
                  Hi All,
                  Regards, Stefan.
                  Thanks for the information about the setup being like a rotoverter or some kind of motor coils rotating mass using split second timing cap discharges.
                  @Harti
                  The answer to why they don't open source is that first someone else will try to steal it and the rest of us would take 20 years to find time to get it operating. Most folks don't have the time or the MONEY to build a decent 10 pole monopole. They will never build this one.
                  Newman was talked about as an explanation for the way they see energy transfer. Let me ask you something, did Newman get stonewalled in his youth when he had answers to energy production? Did Tesla?
                  You and I are not going to change the way the world is run but what we should do is merge our inventions with existing systems to improve efficiencies.
                  Once that is done it will be all downhill from there. Once the young minds wrap their heads around the new ways of power generation, the old stuff will be almost insulting to pursue.
                  But all of these great ideas will end up at the bottom of everyone closet as spare parts, without MONEY,BACKING and lots of it. Plus making friends on the inside of the energy cartel.
                  That is what he said in so many words. And that is what I say also.
                  Us little people can't fight city hall is what I say.
                  Thanks Stefan for the bigger picture of the setup. It is nothing like we thought. I thought they were doing solid state pulse discharge systems.
                  However when you think about all of the motor coil systems Tesla was working with it doesn't surprise me that their work includes rotation mass with adjoining coils.
                  The circuit he said was nothing, just plumbing. Whatever that means.
                  Mike
                  • Hi Mike,
                    my comments were probably a bit too sloppy.
                    I have high respect to Babcock and Murray.
                    The Flyback Power Motor from Paul Babcock
                    was shown for the first time in this sales video.
                    He showed, how he can maintain the speed and thus
                    torque while reducing input amperage by about a half so reducing input power.
                    So this is different to a rotoverter....
                    But this was a totally other demo than the SERPS unit, that is a solid state
                    device.
                    Jason just found out that they are just using only 1 cap and just reverse
                    its polarity every quarter waveform. Then we get exactly the waveforms
                    Babcock and Murray have shown on their scopeshots.
                    The new simulations are posted at overunity.com
                    Regards, Stefan.
                    www.overunity.com
                    • 2000 percent COP
                      Hi Stefan
                      I am really lost now. Oh well I will get up to speed in a minute .
                      So Paul is showing more than one device? Both are demos of a 2000 Percent unit?
                      Oh well I better go back and read the whole thread.
                      Let me get this straight, the SERPS ya know the switched energy resonance device is the discussion about the series/parallel cap switching and the motor demo done at the conference has nothing to do with the SERPS thread?
                      Is this correct? So we need another thread for the other unrelated subject matter? Or does this other demo relate to the SERPS 2000 percent?
                      Transformer cores with bird shot using soft carbon free metal only apply to the motor stuff not the SERPS?
                      Paul's transformers and motor cores are all the same? Or No?
                      Please specify switch material you are reviewing on any given day.
                      I know this is a complicated website and I expect difficulties to arise/confusion and what not.
                      You Stefan are far more advanced than I am.
                      Silver says "NO FANCY CORES"
                      "Mikrovolt" shows the core designing video for the motor stuff and everyone else is talking about Pauls inventions.
                      Okay I think we are all on the same page now.
                      I guess everyone is trying to understand Paul's work prier to the SERPS so they can understand the SERPS device?
                      That must be what is going on here.
                      I will assume this is the case because Paul stated that the SERPS is a merger of his work with the other technologies, so it makes sense to find all of the details that Paul talked about before the SERPS came.
                      The question now is "Does the SERPS use Pauls core designs"?????
                      Mike
                      • Hi Mike,
                        well yes, in the sales video
                        http://bit.ly/serpslecture
                        and enclosed PDF files
                        they have shown many devices that they have worked on !
                        Not just the new SERPS unit.
                        Murray had woked on many rotary devices, like his dynaflux
                        machines and other generators.
                        And Backcock has invented this special toroidal motor
                        that is using power from Flyback pulses and is probably an overunity motor,
                        but he made only a short video demo of it.
                        But the real interesting device is the SPERPS unit, as it is solid state and
                        by end of this year you can heat your flat with it for instance with constant 1 KWatts and still deliver 300 Watts back to the utility, so your meter will
                        turn backwards and it is not stolen power !
                        www.overunity.com
                        • Paul's Iron Shot Core
                          Mike
                          Dear Mike,
                          As far as I can tell the demonstration SERPS device seen at the convention did not employ any of Paul's core designs. He appeared to be using a standard power transformer with sheet iron laminations. However, his toroid motor did use the cast able approach. He pointed out that some of the iron shot was not well sealed in the epoxy matrix and made noise during operation.
                          Paul was kind enough to give me a sample of the #7 soft iron shot, the source from where he got it, and several construction details.
                          I'm sure Paul would be flattered if anybody would be interested in this information. I would be glad to wright a short paragraph if anyone is planning to build one of these.
                          Spokane1
                          • SPICE Simulations of SERPS
                            Hi Aaron and all,
                            Jim Murray talked about how his SERPS technology doesn't require any knowledge of advanced electrical science, but uses all of the known electrical engineering calculations to determine component values, etc. Does anyone know if he ever successfully simulated his SERPS design in a SPICE simulator? My assumption is that since he mentions a mass component of the current that has not been accounted for, this may suggest a no, but just thought I would ask anyway.
                            Thanks!
                            Jason O
                            • Originally posted by Spokane1 View Post
                              Spokane1
                              Yes
                              I am very interested in experimenting with non crystal no carbon scrambled iron core using a long winding because there is something going on there.
                              The hysteresis and magnetic absorbing properties is a significant benefit to motors using radiant energy. Since radiant energy related to SERPS goes into esoteric discussion it follows that we are far ahead to understand the Tesla side of the technology in simple repeatable steps, leave the SERPS patented assets alone as it is for large commercial licensed development.
                              • bird shot core
                                Mark,
                                Paul does discuss the bird shot core in this interview from last year. https://www.youtube.com/watch?v=WXMWvloZBgQ
                                RPX & MWO http://vril.io
