Ratchet mechanism to turn what? Tesla US685957 patent.
Look at the drawing on the first page:
Patent Images
Same picture as in Fig2 --->
File:PhotoelectricEffect(Tesla).png - Wikipedia, the free encyclopedia
In Fig 2 why is there a mechanism that spins a cog wheel with a spring-loaded ratchet? Is that wheel supposed to modulate something like the distance between contacts (f) and (f')? It looks like there is a cam on this wheel. So it pushes something closer together and lets it come back further apart?
This wheel will take many charge and discharge cycles to turn 360 degrees. So if it is used to make the Radiant Energy apparatus more efficient, it modulates some very large cycle.
This patent is talking about negative voltage being applied to the plate that is exposed to radiant energy.
If I take a Marx generator and energize a piece of aluminum foil to 100,000V, would I be able to efficiently build up more charge as particles (such as particles that can be seen in Cloud Chamber Cloud chamber - Wikipedia, the free encyclopedia
I believe that this invention doesn't violate any laws of conventional physics because cloud chambers show this radiation that this circuit takes advantage of...
Isolating a solar panel with the load from the ground and applying high negative voltage will help attract photons to the solar panel and make it more efficient?
I want to know as much as I can before I continue experiments in this field.
Thank you.
Patent Images
Thank you.
