William F. Skinner - 1939 Gravity Power
  • I think the Murakami E.D. will work better than the idea of a horizontal
    bar that oscillates back and forth on a pivot with another short bar that pivots on it's end and "whips" around as Aaron laid out in one of the videos
    with the white graph paper pieces.
    I built a crude version of the horizontal arm type and the short bar wouldn't
    always whip around as the longer bar was oscillated back and forth. Often it
    would just remain basically at right angles to the longer horizontal bar.
    Keep in mind that we have to coordinate the rotating upper weights with each other in order to keep the forces balanced. Any given upper weight
    has to move in a manner exactly opposite to the one across from it on the machine or the whole thing will vibrate itself apart or across the floor.
    I'm still not convinced that we need to move the lower end of the input lever shaft in an ellipse. Maybe the question to ask is what motion would serve us best?
    It seems to me the top of the bottom weight shaft (where it attaches to the translation coupler in a spherical bearing) moves in a circle through volumetric space (through the air). To try to confine it to an ellipse would
    require significant force that would always be fighting the centrifugal force
    of the lower, tall weight. That would lower the output of the whole machine.
    Therefore if the top of the bottom shaft moves in a circle, the translation coupler must move in a circle which means the bottom of the input lever rod
    must move in a circle. That means the top of the input lever rod must move in a circle. ?
    Trying to visualise it all is fun.... I think the lower weight's shaft lower pivot/bearing point (just above the gear but below the universal joint), and the x/y pivot point in the frame of the input lever rod must be lined up vertically so both the upper and lower weights are moving in circles in the air.
    The lower tip of the input lever rod and the upper end of the lower shaft would be drawing circles in the air but they would be different diameters.
    The translation plate would be doing some sort of dance around these 2
    pivot points.
    watching the videos it seems that my eyes and brain can see whatever motion of the top end of the input lever rod I want to see. I can see it moving in a clockwise circle. then if I play it again I can see it turning in a counter clockwise circle. then if played again I can see it oscillating back and forth. ???
    the above are just some musings on the workings of it all.
    I could be completely wrong.
    I sure am enjoying this discussion forum, thanks for almost everyone's helpful and insightful input.
    You bet this is getting exciting!
    Tom
    • hopefully this will help people visualize
      Skinner gravity Engine Gimbals Part 5 - YouTube
      installed gimbals
      could use either of my pre built drive trains to run this but looking at ellipsoid
      • Originally posted by eltimple View Post
        installed gimbals
        Thanks for that video! Great work.
        which motion best starts the top weight spinning?
        • Simple graphic
          Here is a small video of an ellipsographic type mechanism with 2 axis, note the circle, broad ellipse, thin ellipse and the linear to and fro, all from the same mechanism. Regards Arto.
          Ellipse Guides - YouTube
          • youtube
            Originally posted by shylo View Post
            Hi All, just got the video posted over at ou, if somebody wants to put it here their more than welcome. Here it just keeps saying failed to load maybe not enough room I don't know?
            artv
            Thanks Shylo, do you have a YouTube account you can post it to?
            RPX & MWO http://vril.io
            • ellipse methods
              see this video on elliipses starts at at 54 seconds
              https://www.youtube.com/watch?v=1v5Aqo6PaFw
              Yes, same concept. Looked around more but still can't find that anyone is actually using the wheel method.
              Those are all really cool - I like the wheel method like what I'm going with and the swing.
              I think the swing would make the most incredible piece of moving art and it would give the biggest gain since it does make use of gravitational potential energy. On a big unit with massive weights that don't have to move fast, the swing would be perfect. It would start to look like a Rube Goldberg machine at that point, but all the better. lol
              • elliptical motion
                pivot points.
                Tom
                Tom,
                Instead of a short bar at the end of the horizontal shaft, would it work better if it was a wheel with the connection to the lever offset - like the little pulley I show in the video. I wasn't using it for that purpose but if that pulley was on the end of the horizontal bar and the lever was connected to where I have the self-centering bearing, it would serve the same purpose and might rotate easier?
                I believe elliptical absolutely serves us best. I don't think it is an issue of fighting the centrifugal force trying to maintain the ellipse. It is intrinsic in the mechanism to make that ellipse and its motion is limited by its relationship to the input lever's limits. There's like multiple positive feedback methods that are intrinsic to the whole machine.
                • gimbals and gimbal bearings
                  installed gimbals
                  Great demo! I didn't know it was called a gimbal - keeps things level like cameras, gyroscope instruments, etc...
                  Started to search for gimbals online and found there are gimbal bearings - just what I need. Seems they're usually used in boat motors to keep the shaft in alignment and they have a lot more swivel action than the self-centering bearings I've been using.
                  I can mount one of those on a wheel for the elliptical drive and can tilt the wheel quite a bit more than with the self centering bearings to get a narrow ellipse.
                  Can also be used for the pivot point of the lever.
                  One test I was using 3 super balls put in a triangle (as the pivot point) with the lever rod going through the middle. Gave me the range of motion needed and also was intrinsically spring loaded.
                  Looks like a gimbal like what you made would give the most range on a wheel for an elliptical drive but I hope I can get away with just one of these bearings.
                  • well my gimbals could be scaled up, 4 x 1 inch flange bearings mounted on angle iron ( bolted together) then take the thing to a welder to weld all the bolts would not be much work...could all be done using a pilar drill with perhaps a 20 dollar tip to a mechanic to weld up in his lunch hour.
                    • Sketch
                      Hi Aaron, I have drawn an interesting combination, as you suggested, this particular type will definitely show chaotic tendency, multiple ellipses in a circular form, it could show harmonic tendencies of whole number elliptical rotations.
                      Eltimple, nice work on your gimbals, I drew the Skinner gimbals as per video(+ or - 1/16"), any machine shop could make it, or even a good drill press and some flat bar and scrap steel also the bearings are available at QBC.
                      It looks like everybody is enjoying a great learning experience, thanks William. Regards Arto.
                      • i have drawn up a dyno excell spreadsheet based on the Lindemann prony protocol..I could not actually find anything ro use so drew this up..link to my dropbox
                        https://www.dropbox.com/s/781fzq359jocsy4/Dyno.xls
                        if you have anything better let me know
                        • input lever
                          Arto,
                          Where the images says "Free Rotation" it would still have a pivot there. The input wheel would be tilted and would be locked into place guaranteeing the top of the input lever traces the same ellipse every time.
                          • input lever
                            Thanks for the spreadsheet. I think the build has to be on a scale where there is some significant mass in movement.
                            What mechanism are you using for the input to the lever attached to the gimbal?
                            • dont think that the any change of scale would do different results
                              but you need to scale weight and size of all parts precise
                              I don't know did any of you notice that the top lever(rod) that is moving the
                              plate is pretty long and its mass is laying down on gimbal,therefore helping to
                              create a more force with less input power
                              • no if it works then scale has no bearing...infact the common excuse for overunity machines not working is always if it was just a little bigger it would work.....that is a great mis-conception. If a small weight is big enought to affect the system by falling and hence moving the shaft towards the new COE. then its big enough.
                                centrifugal math means that when you double the speed you quadruple the force, that happens at the macroscopic or the enormous
                                but the spread sheet will work with any size you want
