tuning
hello, thank you always for your prezioni suggestions. I spoke about a failing rotor is now correct. the abnormal rotation was caused by a bearing that not having friction, was fionfare weight over the position derived from the lower weight. while the other three use a tube inside another tube that having friction reach the desired position by 90 ° on the vertical axis. for synchronizing the lower weights I stuck to converging pair of rotors and after I stretched as far as possible the chain. use an induction motor 220v 180w. with reduction gear 10: 1 while I used a bicycle transmission input which currently runs everything at 45 rpm. I'm going to use a mechanical variator axis to the engine that will allow me to adjust the turns a little at a time.
Originally posted by goldpro
