Overunity?
The Impossible Video - YouTube
Here is the patent material filed. Note, the filing date is about 2.5 months ago: http://www.thejohndevice.com/TheJohnDeviceBook.pdf
Here is a recent update: "The World Intellectual Property Organization (WIPO) published the first John Device related patent on May 15, 2014. You can look up the patent directly on their site (WIPO - World Intellectual Property Organization) using the Title: The John Device. Alternately, you can simply download "The John Device" book (a .pdf file), which has the entire patent as a section in it...
Website: The John Device Home
A bit more food for thought:
"After SFTH Analysis, the 100W generator currently being used will need 400+ lbs of weight, so a 50W generator from the same company has been ordered (remember - from central Mongolia). The plywood and 2x4s and the layout of the system weren't designed for those 400+ lb weights. The larger weights are slowly destroying the frame (and the operator/inventor) because of the poor construction and implementation - not system conceptual issues. As you would expect when you understand The John Device technology, however, the system gets easier and easier to rotate the MORE mass is added."
