Originally posted by Jetijs
What a sychronicity! Probably the PATHS mind time travel Module. Just today I was thinking about how come no one has inquired about my being quite surprised at Aaron's drawings.
I have spoken at length with Aaron and his drawings are accurate renditions of the superpole setup.
The way I have mine setup is now being tested and documented. The results should be available within 1-2 weeks.
Regarding testing the ground- What I did the other day was just walk around my property and stick the leads from my volt meter in the ground...3-4 inches apart from each other. I had the meter set at the 20 volt DC setting. The earth was a bit damp (it had rained 3 days previous). Also, we sit on a huge aquafier about 100 feet down (I do not know if this makes any difference).
In Maui I used two steel rods and measured hundreds of locations with the leads taped to the rods and the rods 3-4 inches into the ground at each location. I believe a better test would have been to put them deeper and to use copper rods, but this was not feasible for me at that time.
btw, it is 245 am here right now and it has been raining for about 5 hours and just stopped, so I went out to the location that was giving me 3.3 volts the other day and it is now reading reading only .42 volts. I am not sure why this is, but have noticed variance like this in the past.
Also, as a little antenna type fun, I put the ground lead into the ground just now and put the positive lead on the unpainted metal siding of my barn....got a .76 volt reading. The barn is still under construction and there is NO electricity in it or near it. Also, there are many places where the metal (galvanized steel) siding is 2-3 inches into the ground.
Hope this helps.
