Gyroscopes:
Fran McCabe:
Wix.com Fran McCabe Home created by dolly1000 based on Global Ventures
McCabe Compilation (Read Vid Description)
https://www.youtube.com/watch?v=2xYhrFgcyWQ
A self contained 3 wheel vehicle. Its motion is caused by oscillating two 180 degree precessional segments gyroscopics that causes alternating arcuate vehicle motion. The 1.5 lb gyro wheel is spun by a 1/2 HP air motor. The gyro has its precession forced and timed by tuning the two 180 gyro segments into tuned arcuate motions--- being a wavy track vehicle motion.
https://www.youtube.com/watch?v=4kyzd3BaDm0
A 4 spoke assembly that can rotate and traverse in its axial direction; in a cradle with air-driven, single gimbal 'gyro horizons' on the outer end of each spoke. Manual turning of the crank aligns the gyros to the gyro neutral equinox's. A resistance is induced during the alignments....possibly the mechanical demonstration of inertia? An additional physics feature is that the assembly sets up a self-induced frequency that results in selected sequencing of motorizations of the gyro horizons.
https://www.youtube.com/watch?v=vP4emXJ_GS0
A directionally guided pendulum whose period can be controlled to motorize the gyro assembly as each end reversal occurs. These are two pneumatic aircraft gyro horizons rigidly attached to an air motor-driven wheel to provide powered precession that is the power source for motorization.
https://www.youtube.com/watch?v=Fy7aCfC9P4s
A 1/2 HP air motor-driven wheel; and an air gear motor for the powered precession turning of a 4' verticle spiral pivoting arm. The gyro assembly is centrally mounted on the 4' arm. This confuses natural and powered precession, but an upward (anti gravity?) spiral can only be caused by powered precession. Disconnecting the chain-powered precession drive then permits only natural precession. When the sliding weight on the 4' arm is moved in towards the center (not shown on the video) the 4' arm slows. This seems to go against "conservation of energy" physics.
https://www.youtube.com/watch?v=rtuNh4Aa_XU
1200 inch pounds of torque from 2.5 in lb. rated motor.
https://www.youtube.com/watch?v=QmqIg00xSFo
Two 6", 1.5 lb gyro wheels, air motor driven with air motor powered precession mounted on a crank arm. During 1/2 of the precessional rotation the major arm moves down, and up during the second 180 degrees (between two gyro neutral, parallel positions).
The output cranking torque is many multiples of the DC motor's rated torque.
https://www.youtube.com/watch?v=KjrVfsDNX2c
A 2.5 in lb 12/24 V rated DC motor spinning a1.5 lb, 6" D. Gyro wheel can systemically output 31.5 in lb thru gyroscopic natural and powered precession.
https://www.youtube.com/watch?v=c74C2iTSIzI
Centripetal Force:
https://www.youtube.com/watch?v=GC5ZiJNZssk
Eric Laithwaite on Gyroscopes:
https://www.youtube.com/watch?v=OpCEJxO6V9g
Laithwaite on Gyroscopic Propulsion:
https://www.youtube.com/watch?v=Pt9wTAL5KoU
Sandy Kidd:
Gyro Says "No" to Newton:
https://www.youtube.com/watch?v=UTEVC22qAZg
Gyro Experiments Galore:
http://relmachine.blogspot.com
Self Rotation
https://www.youtube.com/watch?v=aYK2-7kdtcY
The behavior of a single spinning wheel in gimbals is a well-documented subject; however, the interaction between multiple spinning wheels is less fully explored. Some researchers have hypothesized that spinning wheels could be mathematically modeled after electrical inductors, suggesting that the interaction between multiple spinning wheels might mirror that of multiple inductors in proximity with each other. The goal of the current set of experiments was to examine the interaction between two gimbaled spinning wheels with six degrees of freedom embedded in one scaffolding and observe their behavioral similarity to electrical inductors.
https://www.youtube.com/watch?v=camtPxBL-YM
Working Together:
https://www.youtube.com/watch?v=0IPtlYipB4w
Levers:
https://www.youtube.com/watch?v=OdM2jWg2uEE
Pulleys:
https://www.youtube.com/watch?v=aMx7nIIH9ik
Inclined Planes:
https://www.youtube.com/watch?v=E_ErI0QjNos
Wheels and Axles:
https://www.youtube.com/watch?v=P7xu9O0miEc
Fran McCabe:
Centripetal Force:
Sandy Kidd:
Self Rotation
Working Together:
Levers:
Pulleys:
Inclined Planes:
Wheels and Axles:
