Its certain: THIS is the future. PERIOD. 1/1000th as much power use and 1000X faster
  • Its certain: THIS is the future. PERIOD. 1/1000th as much power use and 1000X faster
    The FUTURE is vortex technology. ................P E R I O D................
    (I also might have an inside source on some 'things' going down hard and heavy)
    Kids will grow up , within 20 years, knowing ONLY vortex communications at 3-5+ Terabytes per second.
    also this type of tech USES FAR FAR FAR LESS POWER.
    Download 1000X times as much in 1/1000th as much time
    no more blowing POWER RUNNING YOUR MACHINE on HUGE DOWNLOADS.
    no more ENORMOUS POWER USE IN SERVER FARMS LIMITED BY TRANSFER TIMES AND BUFFERING LIMITATIONS.
    And these kids will wonder how the old coots made it along at a pathetic 50MBs download speeds.
    WHAT DOES THAT MEAN? .....It means I was the first person on earth to tell you the missing secret of LIGHT ...........it is ABSOLUTELY NOT (merely, or only) ELECTROMAGNETIC RADIATION.
    LIGHT / EM as mere "self-propagating transverse E and M waves" are IMPOSSIBLE, ........THEY CANNOT EXIST. IT IS IMPOSSIBLE.
    All light, all EM, has a Z-AXIS radial dielectric component. PERIOD<
    VIDEO 34 Uncovering the Missing Secrets of Magnetism. THE MISSING SECRET OF LIGHT PART 1
    https://www.youtube.com/watch?v=vBKZOl_dRlQ
    VIDEO 35 Uncovering the Missing Secrets of Magnetism. THE MISSING SECRET OF LIGHT PART 2
    https://www.youtube.com/watch?v=CUMP6-Gos2I
    While, (obviously) others invented the O.V.B. (optical vortex beams) technology, they HAVE NO IDEA, NONE, ZERO, NOTHING AND IN NO WAY do they understand the HOW/WHY light CAN do this.
    .............Light/ EM is utterly absolutely unquestionably IMPOSSIBLE to exist as mere E and M waves.
    O.V.B. (optical vortex beams) makes this fact a MILLION TIMES more impossible...........
    DEM (dielectro-electromagnetic) . Light is, in actually,what I call, D.E.M.
    Light is a circuit and must must MUST , like transmission lines, contain dielectricity as its center-radial pulsed source at which E and M transverse propagation exits.
    Light is 100% absolutely like a COAX CABLE,
    E and M 'bouncing' around the shielding,and a radial dielectric center conductor.
    (Oliver Heaviside invented the COAX).
    Wi-Fi networking has gotten to be remarkably fast. But even as 802.11n, with up to 600 Megabits per second (Mbps) speeds has become commonplace, and 802-11ac, with its Gigabit speeds is finally showing up, we've seen nothing like the speeds that the still experimental twisted, vortex beams using orbital angular momentum (OAM) is going to deliver. In the lab, OAM technologies is already delivering a mind-bending 2.5 Terabits per second (Tbps).
    Alan Willner and fellow researchers from the University of Southern California, NASA’s Jet Propulsion Laboratory, and Tel Aviv University, have just announced in a Nature article, Terabit free-space data transmission employing orbital angular momentum multiplexing that they can deliver 2.56Tbps speeds with by twisting beams of light together, multiplexing them, and then encoding data using OAM and current Wi-Fi technologies, such as spin angular momentum (SAM), which we're already using in Wi-Fi and 4G.
    How fast is that? 2.56Tbps is about the same as 320 Gigabytes (not bits, bytes) of data a second. Or, to put in more homey terms, as 25GBs for a typical single layer Blu-Ray HDTV movie, an OAM wireless connection could send almost 13 HDTV movies a second to your television.
    In short by twisting wireless signals into spirals, the researchers were able to encode far more information into a single connection than we've ever seen with any other networking technology. Trie, this latest test was done with optical transmissions, over only a meter. Before that test though Bo Thide of the Swedish Institute of Space Physics has already proven that OAM can be used with conventional wireless technologies. In his tests, Thide was able to use 2.4GHz Wi-Fi signal to send an OAM encoded signal over 442 meters.
    Thide maintains that is just the tip of the ice-berg. He believes that besides being able to drastically increase Wi-Fi network throughput that the use of “OAM states might dramatically increase the capacity of any frequency band, allowing the use of dense coding techniques in each of these new vortex radio channels.” In other with OAM vortexes we can potentially transmit an “infinite number of channels in a given, fixed bandwidth, even without using polarization, multiport or dense coding techniques” on any kind of wireless network--TV, radio, Wi-Fi, 4G, what have you--at the same time on the same frequency.
    In short, not only could Vortex wireless vastly increase our wireless networking speed it could end all our current congested wireless network problems. As this technology moves from the lab bench to the home and office we will see a wireless networking transformation as great as any we've ever seen since Marconi and Tesla simultaneously invented radio in the 1890s.
    No, I'm not kidding. Vortex wireless is going to change everything. and I mean everything, we thought we knew about the limits of wireless networking.
    O.V.B. (optical vortex beams) are the future, plane and simple
    angular vortex antenna
    an experiment in Venice, Thide and his Italian colleagues have transmitted two signals at the same time, on the same frequency, over a distance of 442 meters (1450ft). Pictured on the right is the antenna that the team used. No, your eyes don’t deceive you: To create these radio vortices, all you have to do is make a cut in a standard parabolic reflector and twist it slightly. If you imagine a corkscrew of radio signals being continuously transmitted from the outside edge of the antenna, that’s effectively what’s occurring. On the receiving end, there are two “normal” TV antennae (Yagi-Uda) set apart by the same angle as the break in the transmitter. These antennae “decode” the vortex, and voila: Two radio signals transmitted over the same frequency.
      It's been known for a long time that light travels in spirals or helical paths.
      Light waves do not just fluctuate up and down or side to side, they spiral.
      When we look at a magnified "light wave" from any side angle near 90 degrees from propagation
      or a "wave form", what we see as a 2 dimensional representation is a wave like pattern.
      But the actual path is helical or spiral. If we look at the light "wave's" path
      "magnified" from in line with it's direction of propagation we would see a circle.
      A helix is a vortex now ?
        Youre thinking about circular polarization, wholly diff. creature than this new technology.
        However it has NEVER BEEN KNOWN or written about by anyone...... that light contains a 3rd component, a Z-axis radial dielectric component.
        "self-propagating transverse electric and magnetic 'waves' " as an explanation of Light/ EM is impossible, it cannot exist as a full or near full explanation.
        Electricity itself cannot even exist without dielectricity,
        Phi (magnetism) and Psi (dielectric) are BOTH necessary for electric existence. The notion that Magnetism and Electricity are circular or linear polarizations, propagating thru 'space', and are reciprocating around NOTHING, is an absolute impossibility and a farce.
        circular polarization is, as analogy, one entity with limited carrier potential, this is taking same and causing vortex properties that will allow (its already proven) TREMENDOUSLY more data in transmission.
        Youre thinking about top LEFT
        Im talking about bottom RIGHT
        See video:
        https://www.youtube.com/watch?v=QB5GkGNMdA8
        however when the moron in the video says "electron" just replace that with dielectric
        The team of researchers that produced infinite-capacity wireless vortex beams has deployed the same technology in optical fibers, using twisted laser beams to transfer data at 1.6 terabits per second over 1.1 kilometers (0.68 miles).
        In both cases, the principle at play is called orbital angular momentum. In essence, electromagnetic radiation — whether it’s a wireless signal or a laser pulse — can have two kinds of twist: spin angular momentum (SAM) and orbital angular momentum (OAM). If you picture the Earth, SAM is equivalent to the planet spinning on its axis (producing the day/night cycle), and OAM is equivalent to us rotating around the Sun (producing seasons). In every commercial network topology, we only modify the SAM.
        What Bo Thide of the Swedish Institute of Space Physics proved in 2012, however, was that we could modify both the SAM and the OAM. In effect, this creates a three-dimensional wave that’s modulated in one plane (SAM), but also twisted through another (OAM), creating a vortex or corkscrew (pictured right) As you can probably imagine, by shifting from a 2D wave to 3D, you gain a huge amount of spectral efficiency. In fact, if you have enough control over the OAM, you can effectively transmit infinite amounts of data on the same carrier frequency. This is what led to a group of researchers, headed by Andy Willner at the University of Southern California, to create a wireless network link capable of 2.5 terabits per second — or about 40GB (one Blu-ray disc) per second.
        Now, Willner has teamed up with Siddharth Ramachandran, a fiber expert at Boston University, to implement orbital angular momentum in a fiber-optic network. This is slightly more difficult, as optical fibers tend to be single-mode — i.e. they can only transport a single beam of light. OAM requires that you transmit multiple beams of light (or radio waves), twisted like a corkscrew to prevent interference between the beams. To get around this, the researchers used a special kind of fiber that has had special chemicals added to it (doped) to create different, spatially separated pathways. Using a single color of light with four twists, the team obtained a data rate of 400Gbps; using 10 colors, each with two twists, 1.6Tbps was achieved.
          @TA
          That is extraordinary and I find it hard to believe they actually had the insight to understand a three dimensional entity could transfer more information than a lesser one. Now we can inform each other of the mass extinctions, diseases at epidemic levels, disappearing forests, polluted water and rising temperatures even faster woot.
          Tick..Tick..Tick
          In the news Buddy Macmaster has died at age 89. Buddy was awarded the order of Canada for his fiddling prowness... not fiddling with himself but moreso a fiddle. While the world went to hell in a handbasket all around him old Buddy was fiddling away entertaining the ignorant masses...he will be missed.
          AC
            Originally posted by Allcanadian View Post
            @TA
            AC
            Im not an Enviro-hippie. "mother nature" always takes care of herself.
            Even toxic waste and a Nuke plant is natural.
            Its the natural byproduct of natural human invention and creativity.
            Every generation on earth thinks "this is the LAST!"
            Ultimately its superior human destiny to leave this stinking hole, this planet and go elsewhere.
            The world SHOULD be like the movie Elysium. The better half living in space in perfection devoted to pure discovery and invention.
            The other half concerned with getting rich and laid living in hell on earth.
            Humanity will eventually mimic that very movie.
              Thanks for this post Ken. I sent it to our four guys in the IT department where I work. They're forever upgrading cables, switches, servers, modems, bodums... Looks like this will be a whole new revolution.
              I can't help but think of Mehran Keshe's work with what he calls "Magnetic Plasmatic Fields" to produce energy and light (as a by-product, which he maintains is intrinsically related to magnetism). I also think about Stubblefield's Earth Batteries, and the reports that the ground around the SEBs often glowed at night.
              Clearly, there is a link, and perhaps this link is the dielectric. More food for my starving mind.b
              Thanks again for posting your explanations.
              Bob
                Orbital Angular Momentum (OAM)
                In this image, l is -1 or 0 or +1.
                Are all three the same wavelength and frequency?
                Am I to understand that a near infinite number of other (non-quantum) values are possible? At one and the same frequency? Did the research demonstrate this is already possible or yet to be realized? Thanks for sharing your understanding of this technology. It is obviously new territory for me.
                In conventional physics, is this not a quantum attribute called electron spin?
                If possible, try and help me understand this.
                  The Thide like tech has already been deployed near the San Fran area. The bugs are being worked out as we sleep. Public distribution could happen in the next year.
                  Just Sayin.
                  _
                    As amazing THIS technology (above) is,......I have been given privy information (its already been patented) on an upcoming device to be revealed in October of this year that will make this technology above look pathetic by comparison.
                    Ive seen it, Ive seen it work, its been patented and Ive promised not to disclose any details about it until after its unveiling in October.
                    The invention is so divinely simple, and amazing, its just stunning work.
                    I assure I am dead serious about this, and all will be unveiled by the inventor in October.
                    Communication is going to change radically very very soon. VERY RADICALLY.
                    Importantly, is going to be an enormous DROP in power needs for servers and download power-sucking on the users end.
                    Basically (in short) his invention is this technology (ABOVE), except on steroids and operates 'differently' in a few ways.
                    There is no such entity as electron spin, the very premise of the "electron" is a misnomer, a lie, a farce.
                    If you want to know what an "electron" is , see here:
                    https://www.youtube.com/watch?v=Lvc5ns3eI7k
                    Nikola Tesla November 1928 interview:
                    On the whole subject of matter, in fact, Dr. Tesla holds views that are startlingly original. He disagrees with the accepted atomic theory of matter, and does not believe in the existence of an “electron” as pictured by science.
                    “To account for its apparently small mass, science conceives of the electron as a hollow sphere, a sort of bubble, such a bubble could exist in a medium as a gas or liquid because its internal pressure is not altered by deformation. But if, as supposed, the internal pressure of an electron is due to the repulsion of electric masses, the slightest conceivable deformation must result in the destruction of the bubble! Just to mention another improbability...” - Nikola Tesla
                    Article: “A Famous Prophet of Science Looks into the Future” (Popular Science Monthly)
                    “There is no rest mass to an ‘electron’. It is given here the ‘electron’ is no more than a broken loose “hold fast” under the grip of the tensions within the dielectric lines of force. They are the broken ends of the split in half package of spaghetti. Obviously this reasoning is not welcome in the realm of Einstein’s Theory of Relativity.” – E. Dollard
                    “This gaseous Ether is the seat of electrical phenomena through the process of its polarization. This polarization gives rise to induction, which then gives rise to stored energy. Tesla gives a good presentation of his Ether ideas in his “Experiments with Alternate Currents of High Potential and High Frequency.” Mentioned previously, the Planck, Q, as the primary dimensional relation defining the “Polarized Ether”, this as an “Atom of Electricity”. It is however, from the views of J.J. Thomson, the Coulomb, psi, the total dielectric induction is the primary dimension defining the “Polarized Ether”. The lawyer like skill of today’s theoretical physicist (Pharisee) has erased this understanding from human memory, it is henceforth sealed by the Mystic Idol of Albert Einstein. If Einstein says no, then it is impossible. What a nice little package.” – E. Dollard
                    “Unfortunately to a large extent in dealing with dielectric fields the prehistoric conception of the electro-static charge, the ‘electron’, on the conductor still exists, and by its use destroys the analogy between the two components of the electric field, the magnetic and dielectric. This makes the consideration of dielectric fields unnecessarily complicated”
                    - C.P. Steinmetz (Electric Discharges, Waves and Impulses)
                    The idea of electricity as a flow of ‘electrons’ in a conductor was regarded by Oliver Heaviside as “a psychosis”. This encouraged Heaviside to begin a series of writings
                    “Electrons as a separate, distinct entity…doesn’t really exist, they are merely bumps in something called a ‘field’.” - Dr. Steve Biller
                    “Here we will dispel the "electronics nerd" concept that a capacitor stores "electrons" in its plates. Taking the pair of copper plates as in the previous experiment, but now we have two pairs of plates, one pair of plates distant from the other pair of plates. Upon one pair of plates is imposed an electro-static potential between them. The cube of 10-C oil is inserted between this "charged" set of plates. This hereby establishes a dielectric field of induction within the unit cube of 10-C oil. Now we then remove this cube of oil, withdrawing it from the space bounded by the charged pair of copper plates, and taking this unit cube of oil, it is then inserted into the space bounded by the other uncharged pair of plates. Upon insertion it is found that the un-charged pair of plates have now in fact become charged also. It here can be seen that a cube of dielectric induction can be carried through space, from one set of plates to another set of plates.” – E. Dollard
                    Also consider the J.J. Thomson concept of the "electron" (his own discovery). Thomson considered the electron the terminal end of one unit line of dielectric induction.
                    “To describe an electron as a negatively charged body is equivalent to saying that it is an expanding-contracting particle. There is no such condition in nature as a negative charge, nor are there negatively charged particles. Charge and discharge are opposite conditions, as filling and emptying, or compressing and expanding are opposite conditions.” – W. Russell
                    Recently scientists discovered that light can be twisted like a corkscrew around its direction of travel. This unusual quantum feature allows photons to whirl around in a vortex, even when no external force is applied to the beam. Now researchers from the RIKEN Frontier Research System in Wako have shown that the same kind of vortices can be produced in beams of dielectric rayss1, promising novel applications.
                    “When a light or dielectric rays beam is twisted, waves at the central axis cancel each other out forming a dark core, like at the eye of a storm (Fig. 1),” says RIKEN scientist Franco Nori, also with the University of Michigan in the USA. His RIKEN collaborator Sergey Savel’ev, also at Loughborough University in the UK, adds: “As the photons or dielectric rays spin around the axis, they carry orbital angular momentum that can rotate an electric dipole.”
                    To explain these properties, the researchers solved the Schrödinger equation of quantum mechanics for a twisting beam of dielectric rays. This produced new dynamical equations that are highly analogous to those found for light. The similarities arise because the twisting angular momentum of the dielectric rays interacts with their forward motion in the same way that intrinsic angular momentum (spin) interacts with the motion of photons, which is known as spin-orbit coupling.
                    The theory implies that vortices in dielectric rays beams have all the features of optical vortices. This reinforces the famous concept of wave-particle duality, which states that all particles have a wave associated with them. More importantly, it means that the useful applications of optical vortices could be replicated at much shorter wavelengths.
                    In practice, optical vortices can be made by passing a laser beam through a fork-shaped computer generated hologram. Dielectric rays-beam vortices could be produced in a similar fashion, using a thin crystal plate with a dislocation. Such vortices could power tiny nanomotors and nano-engines, or could be used in telecommunications by storing information in the optical vorticity, or the intensity of twisting. The vorticity is robust against perturbations, so this potential future technology could reduce the loss of information during optical communications.
                    Furthermore, dielectric rays vortices are predicted to cause a shift of the dielectric rays beam at right angles to an electric field. “The unique dielectric rays microscope developed by Akira Tonomura's group, also at RIKEN, could observe this unusual effect,” says Nori. “Such work would considerably expand the textbook analogy between matter and waves which Tonomura helped to establish in pioneering experiments.”
                      Bob
                      Ask your guys in IT if theyve ever REALLY SEEN a magnet "working"
                      broken ring magnet:
                        @TA
                        Tick..Tick..Tick
                        AC
                        i see all this and, you explain it a bunch. but, i don't see the point of it.
                        im more into someone giving me the gist and me understanding it even able to backwards reverse engineer you. so, let me try to give my gist here. its a wireless :rf: field 1/1000 less electric and 1000x faster?
                        so more compacted :rf: radiation where dealing with here? woopty. mabye ill move into the country. in the woods. lets not beta test anything here, they got 100 million morons+ 100m is just a good #, to walk around with their phones, like idiots. never giving anybody any respect worthless *******s. and encouraging it they where. too. and now we've.. got it 1000x more concetraded well wooptee freaking doo sounds wonderful.
                        a couple questions, if im right on everything.
                        is my internet bill going to go down?
                        is my car going to use less gas? ... see these are seperate. im not sure on my gist is it just wireless. or what?
                        is this technology going to be transferred to other things?
                        is this just a wireless technology? what? rf? cuase thats all they use. and THIS DOESNT SOUND GOOD AT ALL. worry worry ALERT ALERT.
                        ****. cheaper faster? i thought this would go through a wire. if its tranferred by rf, then i dont like it at all. i dont like the idea of me sitting there with someone passing a movei their watching lit up on their screen through me. especially if now they want to pass them to 20 tv screens in high def streaming or something like that.
                        the more theyy screw with anything the more it turns into boredom. a television or somethign like that. all these thigns all these sites talking all this crap seem all like ebaumsworld stealing all their content. thats all they are. when people used to ***** at people for stealing content or not coming up with anything themselves. repeat. thats all they do. theres no new ideas.
                        ... so the point of this, technology, is for what? so they can spam up p2p programs more?
                        if my car doesnt get more mpg then how can i use this technology. you said 320g per second. if my car does, thats great. 1/1000 fuel use gas price awesome. if not then. but anyway.
                        whats going to use it? 320gb/s that means you use 320gigabytes of information a second. how? whos going to use it? who? and how is it going to be stored? for that speed, you can write that on a hardrive. you could use ram which im reading somthing around .. i dton know im guessing here 40gb/s speed. but also its going to fill up very quick. who or what is going to use this? who and how?
                        and if cheaper is the answer, well, sure i bet so my internet bills gonigto go down 1/1000 of price. fine. good. yea im really sure thats going to happen since htey dont want you to use the internet unless you pay by the minute. and never have wanted anything like that. answer why the usa hasnt gotten fiber over here until recently and why it has been out like over in sweden and over in europe at 30 dollars a month since 2000 that i know of at least. widespread. whats it worth? price? sure, theyre just wanting people to share information oh wait thats right they spam p2p networks.
                        cant see a reason for this or use unless its making cars use less gas hardrives faster. cuase its unusuable as that. and there is FIBER and its NOT NEW its been out forever.
                          @TA
                          I guess the obvious question is what makes you think you would be invited to their oasis in space, you do think you would be invited don't you...why?.
                          Your posts are entertaining and all but in reality the things that matter are tangible and make a real difference. As I inferred in a previous post, you think your smart? How about I cut your power and gas and we will see just how smart you really are.
                          That is the reality we live in and I think it would be really hard for anyone to feel all smart and superior sitting in a cold dark house with no water.
                          I guess it might help to mention I'm a Power Engineer, a specialist in energy systems including application and control. Were the people in the power plants who keep your lights on, the people in process plants who provide fuel for your car, gas for your house etc... and we also work in large scale water treatment facilities. So if you ever have any questions concerning Energy and the reality of why you can live like you do I would be happy to answer them for you.
                          AC
                          • #14
                            T.A.,
                            Mother Nature could "take care of herself" that is correct...the problem is...We, Humans are not included in that "package".
                            Mother Nature "resolves" issues related to environmental toxicity by RECYCLING Herself...and that for Us all means Chaos...Destruction of Humankind.
                            Toxic Waste has become "natural" to Animal Humans, Sheeples...not to intelligent and real thinking ones.
                            Can't believe You are saying all this.
                            Oh yeah!...and We are such developed and High Civilized, Advanced Race...We have all kind of Massive Transportation Crafts...We could travel the speed of light...and have no abnormalities even felt in our bodies...we learned such a long time ago about this...We could establish in any other Planet and start from scratch in a bit...right?
                            United States of America is actually "THE ELYSIUM ON EARTH"...for TPTB, the "ESTABLISHMENT"...and If You care to look at South America, India and Africa...will convince even more about this reality.
                            Yeah...A wider scope of Earth Elysium will come soon...Including the rest of the "Developed Countries" in Europe and Asia...then they will "throw the steel curtains"...so no one , but absolutely no one could pass the Borders of Mexico...
                            I love the Movie Elysium...but the best part I love is the End of that Movie, where everything comes out to be...
                            Eventually, We either have that SAME EXACT END...or NO ONE will survive this Toxic Planet....including the TPTB...and the "High Classes" from the Establishment.
                            • #15
                              TA, That's awesome sounding news. I'll take faster with less power any day despite some other concerns posted. They must have some hella' fast computers to be testing those speeds. My own computer is very fast and even my RAM disk maxes out around 8 Gigabytes per second. I'll assume this technology will be used in computers also to speed them up otherwise current hard disk speeds would probably put a serious bottleneck on those breakneck speeds
                              Look forward to October
