Eolic Car
  • Eolic Car
    Auto eolica, la Corea ci crede - Repubblica.it
    In practice, the drive is powered by a generator which, with an internal mechanism very particular (looks like a flag flying) converts the wind energy by exploiting the transfer of electrical charges between different materials.
    According to the Korean researchers this system, mounted on the roof of a car (would be the size of 7.5 cm to 5) could produce an amount of energy equal to 0.86 megawatts.
    "Transforming the air in energy - the researchers explain - is a mechanism very simple and cheap, based on a kind of 'flag' obtained from a flexible material similar to a cloth, coated with a thin metal layer. Agitated by wind, flag bumps against a hard surface, of a metal of a different type: it is this movement, through the rubbing, to cause the transfer of electric charges ".
    It 's more or less the same principle of operation of this wind generator:
    http://www.nrel.gov/docs/legosti/old/2277.pdf
    _________________________
    Negative Energy Forum
    0,86 milliWatt no MegaWatt!!!!!
      No, Tutanka, 0.86 milliwatts it's impossible: j phink 0.86 KW....
        fuel (power) eolic car: nothing
        EUREKA
          EUREKA
          This is written on article posted from you: Auto eolica, la Corea ci crede - Repubblica.it
          Secondo i ricercatori coreani questo sistema, montato sul tetto di un'auto (avrebbe le dimensioni di 7,5 centimetri per 5) potrebbe produrre una quantità di energia pari a 0,86 milliWatt.
            with a canopy of solar nanoantennas 2 square meters, that also work at night, you can add 1,600 watts ...
            ______________________________
