Originally posted by Bob Smith
The electric traction motor is the component in charge of supplying the system’s electromotive force necessary for its functioning: the generator is in charge of supplying energy to the system. With its mission being producing a recharge of the battery and feeding directly the traction motor, in cases where it is required by itself, or when the battery is charged, it will find itself functioning always when the traction motor is [functioning], and will be able to go connected directly through the pulleys and transmission belts, gears or whichever other means. This principal generator will find itself connected electrically to the battery and to the traction motor and in mechanical form, to the traction motor.
The auxiliary generators are in charge of supplying the reserve energy, and can be constituted by helixes or in turbine form, functioning by way of wind action or by gears joined to a flywheel set in the traction motor.
The battery has as its mission to portion out the power necessary to enable the motor to start and to provide the extra energy demand which the motor might require during its functioning, and will be recharged directly by the principal generator, being connected to the motor for its [electrical] supply.
The charge regulator has as its mission that of regulating the battery’s charge, to avoid over charging.
The velocity [speed] regulator is the component responsible for regulating the velocity of the traction motor.
The present Paten of Invention offers the advantages which have been self-described anteriorly, in addition to others who will easily deduce from the example of realization [drawing?] for the system which will be described in greater detail further along. To facilitate understanding of the preceding explained characteristics, recognizing that at the same time various details and accompanying to present memory, such that some drawings which, only by title of example and not limited in reach of the presentation, there is here presented a practical case of the same [invention?].
Brief description of the drawings
In the drawings:
Figure 1 represents a schematic of the system which conforms to a practical case for its realization.
Figure 2 shows an alternative for realizing the system.
Description of a preferred realization according to the invention
In agreement with what is represented in the drawings, the autonomous system of energetic regeneration, according to the pagent and in agreement with a realization of the same, comprises an electric traction motor designated by (1), a principal generator designated by (2): various auxiliary generators designated by (3); a battery or accumulator designated by (4), a charge regulator and power distributor, designated by (5), and a speed regulator designated by (6).
The electric traction motor (1) is the component in charge of supplying to the equipment the electromotive force necessary for the functioning of the same. The power and tension will be determined by the usage in the system for which it is being applied.
The principal generator (2) is the component in charge of supplying energy to the system, being its mission effecting a recharge of the battery (4) and the direct supply to the traction motor (1). In the case in which it is required by…
