Basic Free Energy Device
This topic is closed.
  • Skepticism, research and thoughts....
    Several years back I played with the battery switching circuits. A couple switches I designed and built, diagrams, were posted earlier. I was pretty much convinced it was working as I was seeing it - a very efficient use of energy. In the back of my mind I knew something wasn't right in my interpretation of the events. I purchased a couple watt meters and placed them in line with the battery switching process and cleared up my unanswered questions very quickly. I was very disappointed in what I saw and moved on to other projects quite abruptly.
    After a while of pondering I started calculating what I thought was the problem(s). With 4 batteries switching from parallel to series connections gives you a gross mismatch of passive storage and you always loose energy in the transfer from high to low. In the case of the 4 battery switch, if each battery is 10ah you end up with a 20ah parallel and a 10ah series. The 3 battery system is better - a much closer match - series 10ah into a single 10ah.... 1 amp in 1 amp out. Still the problem exists with the higher potential series into the lower potential single - 1 amp at 24 volts to 1 amp at 12 volts .
    The objective is to maintain an imbalance to drive a load between potentials. Charging the single isn't a problem, driving a load between them isn't a problem... maintaining a charge on the series batteries (is in my mind) the main problem. The load needs to not only run between potentials but also assist in restoring the higher potential series batteries. The 3 battery system allows 1 battery to charge while discharging 2, or more closely, one battery in the series is charging another battery while the second battery in series is running a load.
    It gives us the appearance we are gaining something because we are charging the single and to some extent this is correct but are we really just deceiving ourselves? Maybe were overlooking the truth with false belief's/hopes that there is some magic going on here.
    Ok then, let's put the hopes, dreams and beliefs aside while remaining mildly objective and dig toward the truth....
    The series batteries are being drained through the load into the single battery and back to the series through the neg connection. A basic DC circuit. We switch the charged battery periodically with one that is being drained more that the other to maintain a higher potential and recharge one that has drained. Seems logical...
    Let's turn it around a bit and look at from a different angle... Lets say we don't switch batteries around, instead let's maintain the voltage of the charging battery by removing the amount it is being charged to assist in charging the series batteries. Everything that is being added to the charge battery is being removed to maintain the source batteries as well as keeping the charge battery in a charged state.
    A boost circuit to drain the charge battery and add charge to the series. 1 amp into the charge battery and 1 amp out to the series battery - It then boils down to the overall efficiency of the circuits and load to maintain both series and single charge batteries state of charge.
    One of the simple experiments I did while running with this train of thought was using 2 identical 7ah 12V batteries, a simple JT circuit between the positives. As long as there was a potential difference of .5 down to .25 volts the LED's would light quite brightly. It takes a very long time to equalize the batteries through a JT circuit. I noticed that by simply tapping the high pos/ low pos with a 1v battery would offset the potential enough for several more hours of run time. It occurred to me that a boost circuit with an RC time constant of several seconds would shift the potential sufficiently to maintain a continuous potential difference while the JT circuit tried to equalize the batteries. In this particular case there was probably more losses to the ambient and internal battery resistance than the circuits but I did prove to myself there was potential in this process. ( pun intended)
    I've tried a multiple of variations and found that it basically boils down to the efficiency of the load ( use of energy ) and the efficiency of transformation from low to high ( pumping the water uphill). The larger the potential difference between the batteries the more looses will occur in the transforming process.... this being the key process. Matching the load wattage to the transformation wattage maintaining the potential difference as efficiently as possible.
    • Position #1
      Please hear this loud and clear....
      This circuit is NOT the final solution. Matt's motor is NOT the final solution. Matt's motor run on this circuit is NOT the final solution. Adding the boost circuit is NOT the final solution.
      You need the switching to rotate the batteries through the five different positions when battery 3 is charged up. You need five GOOD STRONG fully charged batteries that are not old and worn out. Each one will move through these five positions in this order.
      1. Position One (as Battery one of the two in series)
      2. Position two (as battery 2 of the two in series)
      3. Resting Because it has been DISCHARGED in BOTH the previous positions)
      4. Position three (in parallel with one and two, charging)
      5. Resting
      You need a generator run by the motor that can put out power so you can ADD a little power back into the system when it is needed. Nothing lasts forever, and cold and heat are the ENEMIES of batteries. Without a generator you have NOTHING here that is going to get you what you want.
      But any decent generator is going to give you an over unity device if all these things are in place. It just IS.
      Good luck. There are some folks on this forum who could put together a switching circuit to share with everyone else without half trying, if they will.
      Dave and All,
      I've switched out rested and charged batteries to position #1 and still get a faster drain on this position than #2 battery. Is this correct? If so do I just need to switch out this position? Anyone else have this happen? Of course will test more. I have plan to add generator to the system later.
      So much going through my head to test out,
      wantomake
      • Interesting
        If you line everything up in a row and you have two batteries in series (with the positive of the battery near the motor turned so that its positive is toward the motor) and then the motor and then the third battery (with its positive toward the motor) I call the battery in series that is closer to the motor position two. The positive on it is connected to the positive on the motor. In my experience, this battery ALWAYS drains faster than position One. Always, so I am surprised by what you have reported out.
        • My mistake then, I thought position #1 is next to the motor, then in series is #2. So the battery connected to the motor is the one I was referring to losing voltage.
          My mistake,
          wantomake
          • Confusion
            Not your mistake. Mine, for not being more clear. I had discussions with Bob French for a year before we realized he was calling a battery "number one" while I was referring to that same battery as "number two".
            • Up and running
              First test!
              Ron
              [IMG][/IMG]
              • Why would you want 5 batteries???
                1. Batt 1-First battery in series
                2. Batt 2-Second battery in series hook to the load
                3. Batt 3-resting
                4. Batt 4-Charge Battery
                5. Batt 5-resting.
                Now just cycle the batteries 1 at a time.
                The reason to rest the batteries is so they can switch states easier. If you take a battery that just discharged then try to immediately charge it you have to spend a little energy turning the ions around.
                If you put a battery in a discharge point that has just been charged you loose alot of the surface charge real quick and loose energy turning the battery around.
                You do not need 5 batteries but it helps.
                Matt
                • I thought it was Dave's typo..... just checking....
                  • So what are the disadvantages of having two batteries the same ampere hour rating and one different?
                    Are there any advantages?
                    • confidence builder
                      Yes Paul, that is what I had! and the advise was start small. This works, now I have the confidence to spend the big bucks on expensive batteries.
                      Ron
                      • Originally posted by i_ron View Post
                        Ron
                        Its good advice I promise you!!
                        Matt
                        • to bad i have order the less winding turn boost converter like the first Dave show in is video... But as i understand it may work..? I will see it when i recive it!
                          • They work just fine.
                            Matt
                            • 4 big battery being charged by 2 smaller battery wile runing a small inverter to light the room...
                              I just really love it!
                              • A bit later... 👍
