Originally posted by Duncan
![Confused](http://www.energeticforum.com/core/images/smilies/confused.png)
And on side note it has been defined on several occasions now that this is a builders thread. Comments and questions are welcome but long drawn out theory is not. Thank you for understanding.
Originally posted by Turion
The real goal for me is to reduce the motors ability to pass current. This will happen by pulsing it with a solid state driver and doing recovery on those pulses to feed back into the positive side of the motor. What ever ends up going to battery 3 is then captured there.
The motor then turns the gen, and I am going to release the specs on that soon, with models and diagrams in case anybody else wants to print one or just build by hand. I am waiting till I get mine going to make sure that it will be relatively tuned for a lenz free run, and also to see the output is correct.
The gen is used to charge battery 3. Based on the total amount of current going to battery 3 we will be able to adjust Boost 2 to move current up to the primaries. If all goes well the primaries and the b3 will be at the same voltage, hopefully something between 14-15 volt. At that point the output of the gen minus 20% will the standard load for the system.
For instant the gen put out 125 watts we would be able to pull a constant 100 watt load between the potentials while keeping the batteries charged. No rotating, no fuss, just usable power.
Maybe IF I can can all this going then I'll try to add in a computer to do some Shortest Path AI and make the thing self tuning and interactive.
I'll share as much as I can if anyone else is interested.
Matt
***PS One thing I forgot was the ammeters may not show the same amp draw. You may have 2 amp between the potentials and 1 going back up. By looking at the amps and the voltage in the batteries you should be able to formulate a ratio that keeps everything balanced.***
