Guys,
IF we can build coils that will accelerate under load, and I have four examples of coils that will, so am trying to figure out the commonality that allows this to happen...
I have no trouble making a generating device that has no slowdown because of magnetic attraction of the permanent magnets to the metal in the iron core as the rotor passes and tries to pull the magnet away from the core. As with many things, once you understand what you have, you can figure it out.
There are ways to build both motors and generators to ensure that the forces that act against you are neutralized or actually ASSIST you.
We're working on prototypes that do that.
I have not shared everything we know on this thread or on this forum. We are constantly building prototypes and testing, trying to move this thing forward. Quite OFTEN I share where we WERE rather than where we ARE simply because it might spark something with somebody, and where we ARE is usually in the middle of trying things that blow up expensive parts. A while back I let ALL the smoke out of a board that cost me a couple hundred dollars. That is an experience I don't want to SHARE with ANYBODY.
When we have something that works, and when we have gone BEYOND the point where we know it is safe and are taking it to the next level, like with the boost circuit, I have no problem sharing where we WERE. The surface of the potential of that basic circuit and how it can be applied to the running of motors and generators has barely been scratched. In fact, if you shined a light on that surface, you would see no marks AT ALL.
Think about this for a moment. You have a 30 coil machine, like some of the ones that JB sold. You have set it up so that there is NO MAGNETIC ATTRACTION of the permanent magnets to the cores of any of the iron core coils. (Or you could use air core, but might not get as much output) You can spin that baby with your pinky finger.
You have two motor coils that are 180 degrees out from each other. How MANY sets of motor coils do you think you will need with a machine that turns that easily? Let's say you need three sets. So six coils as motor coils turn 24 generator coils. Remember how you could cascade the motors in the latest circuit diagram? Do you think there is a big difference between cascading MOTORS and cascading three groups of two MOTOR COILS on THIS machine?????? So you PAY to power two coils as motor coils, but ENERGIZE 6 coils, and still collect back better than 80% of what you used to energize the first TWO coils in your charge battery. Since you have NO magnetic attraction you need far FEWER amps to kick the rotor right on by.
Oh, and the generating coils enable the thing to speed up under load, so you get higher rpm's and more output from the power you ARE using. As I said, this is not where we ARE, but where we WERE. I built a little two coil unit to PROVE the elimination of magnetic attraction, which it did. And Matt has been building a prototype to share when it is all done. Before we even FINISHED building the prototype, Matt figured something else out that takes us to another level with this stuff.
I posted the boost circuit back in JUNE and I can count on ONE HAND the number of folks who have come forward saying they tried it and what they saw. Why post stuff here if nobody is going to work on it besides us? We can see who is participating by building and contributing. Believe me, Santa is making a list and checking it twice. LOL.
