Originally posted by Aaron
GDS 3 KW generator runs on water
Tnx Tutanka!
@ Sprocket.
From your link we could get an indication what kind of pump is needed.
Quote from link:
" Easily provides 1000 watts of power with one nozzle, 2000 watts with two nozzles. With one 3/4 inch nozzle and 28 PSI (65 feet), 80 gallons per minute, it provides 500 watts output. You can add up to 4 nozzles. "
@Ewizard.
I don't think the Tesla Fountain gives enough pressure. It's more a mass mover... with low pressure and low head.Last edited by Cherryman; 10-28-2014, 03:43 PM.
Originally posted by Cherryman View PostTnx Tutanka!
@ Sprocket.
Quote from link:
@Ewizard.
I don't think the Tesla Fountain gives enough pressure. It's more a mass mover... with low pressure and low head.Last edited by tutanka; 10-28-2014, 04:04 PM.
Just trying to work out what would be the cheapest price you could put one of these together for.
Cheapest 3000W (6000W surge) Pure Sine inverter I've been able to find is here for only $275 - which seems REALLY cheap considering that also includes shipping worldwide! Most other brands are at least $150 more than that.
@Cherryman - Aaron mentioned Tesla's fountain patent might improve things a bit - something like 28W @ 100gpm if memory serves! Since I didn't know Tesla played with fountains, this is the next thing I need to bone up on!
Originally posted by charly2 View PostIn the video while the machine is running I find weird something at 4:50 to 5:02, the fan/rotor of the Pelton wheel is not turning, should it turn?
In the video the bolts that secure the top of the tank are missing if the pump and turbine were working water would be thrown over all the electronics.
Why a demonstration of only inverter power is a red flag.
Yes I thought the same at first, but now to me looks like the coils are the stationary part, and the shaft goes from one side to the other mounted on bearings, in one side is the Pelton wheel and in the other the permanent magnets encased, attached to the fan and the assemble fixed to the shaft.
So if the Pelton wheel rotates, the magnets and fan should rotate as well.
That is my appreciation but I could be wrong.
Why do we assume it is an open tank? There could be compartments, channels, tubes. There could be one section that holds water and another compartment that holds a device that the water is forced past to do the generating. I'm not convinced this is a working device, but I do believe we need much more information before coming to a final decision. Until that happens, I am VERY skeptical.
Dave“Advances are made by answering questions. Discoveries are made by questioning answers.”
Originally posted by Turion View PostWhy do we assume it is an open tank? There could be compartments, channels, tubes. There could be one section that holds water and another compartment that holds a device that the water is forced past to do the generating. I'm not convinced this is a working device, but I do believe we need much more information before coming to a final decision. Until that happens, I am VERY skeptical.
No the pelton wheel is immersed inside , from video no separation.. If isn't an scam device I think the principle applied is different.
For make 3Kw of power you need an great energy source and the only energy source in this device are two batteries of 100Ah 12v for an total of 2400W..
I suppose that the water tank is just an little boiler, I don't think that they use pelton wheel with high pressure but similar to an solar heater.. when man open the tank some condensation is present on the top, the same condition appear only in presence of steam.Last edited by tutanka; 10-29-2014, 06:40 AM.
"water generator"
Also, 2400 watts load on 100ah 12v battery is a C0.5 load, which means it will kill the batteries in less than an hour and possibly damage them beyond repair.
But I do find it to be another red flag if that wheel is submerged in water because I don't think it can spin fast enough being submerged to produce anything substantial.Sincerely,
Originally posted by Aaron View PostFor condensation, my Berkey gravity feed water filter in my kitchen gets condensation on the inside of the lid sitting at room temperature.
But I do find it to be another red flag if that wheel is submerged in water because I don't think it can spin fast enough being submerged to produce anything substantial.Attached FilesLast edited by tutanka; 10-29-2014, 09:54 AM.
If for real then a possible scenario
In the total unit there are 4 motors/generators, two of which are connected by a belt drive, one is a PMA driven by a pelton turbine wheel, and the other is an AC motor of which we do not know what it does!!!!! but seems to be connected to something inside the water tank at the bottom corner.
First the two connected by a pully belt. The dark coloured one seems to be a DC motor and the silver one is a single phase motor driving a high pressure pump on the end (box on end), but the wiring box and run cap have been removed so as it can be wired 3 phase (wires coming out of motor).
Because it is now 3phase and there is no three phase until the pelton PMA is running, it is started up by the 12v DC motor via the pully which is connected to where the fan used to be
Now there is 3phase, and the now 3phase pressure pump is running on it's own, albeit a closed loop with the pelton PMA, which science says it can not be
Now that DC motor is running from the second battery, the battery with the low amp wire, here we have to look at the different possible scenarios:-
1. the motor continues running as a motor and supplimenting the 3phase motor (possibly why PMA and pump can be looped)
2. it has now become a generator and recharging the start battery
3. it is doing both the above depending on load controller (most probable)
4. it was only a start motor and after free running.
The Pelton driven PMA stands for itself apart from water configuration along with motor (AC) 4.
Now the fourth motor, an AC motor as you can see the cap shroud on the casing, and about all that is known about this motor. So what is this motor doing? work that one out, and if this is not a scam you have cracked it
regards
MikeLast edited by Michael John Nunnerley; 10-29-2014, 11:24 AM.
The Pelton turbine works on pressure and not volume of water and can be very efficient 95% if designed correctly.
So we have a loss of 5%min here and has to be made up so as to make the loop back
Alex, your design will not work, it would be very inefficient. Here is the Pelton
http://www.civilengineeringterms.com...-pelton-wheel/
Now the water level gauge is a bit of a red herring I think. Look at the level of the top up tap on the side.
Now what is that AC motor?
1. it is connected to an internal water pump which creates a negative head of water to the pressure pump (feeds the pressure pump)
2. a water circulator from one area to another inside the tank
3. creates another jet of water for the Pelton wheel
I like the first one, makes a lot of logic as to finding a way to recouperate the loss in the Pelton, but then we have the motor power consumption to take into consideration but I think this is what is happening
Now everyone thinks this is an OU pitch I am sure it is not OU, what it is is a way to extend the usage time of a battery to drive the inverter. It has been stated that after 12hrs it needs a 2hr rest more or less ( i'm sure it would depend on the amount of load). Think of this more like a joul thief, I now hope you have got the idea, and really if that is what it is, I think it is great
regards
Mike
Originally posted by Michael John Nunnerley View PostThe Pelton turbine works on pressure and not volume of water and can be very efficient 95% if designed correctly.
Pelton wheel | Parts of Pelton wheel - Civil Engineering Terms
regards
Mike
Probably you don't have seen better my diagram. We have just one water tank with inside an pelton wheel.. I have identify the compressor pump as an scroll compressor but can be other, one port make compression and the other port make vacuum in all case the fluid (water) work in LOOP. More devices you add more energy you spent. how many solutions there are? Auxiliary water jet compressor don't have more sense inside an water tank.. You need just one compressor, in this way you obtain the synchronization of compression and vacuum for obtain the rotation of pelton wheel inside the water!! Think to sea waves on the beach and applies this principle inside to an closed box..
Thanks to SilvertoGold for share this video SELFRUNNING FREE ENERGY MACHINE - YouTubeLast edited by tutanka; 10-29-2014, 03:37 PM.
