Nice build!
Hello Dragon,
Nice build Friend!...would love to see it running soon.
Related to the number of Inner Poles...You are right, you can set there as many as Geometry allows...but you still have Two Rotating Iron Elements...about the same exact size as OEM Poles circumference right?
In my understanding of this Original Concept, He uses the same exact number of Poles (4) as the OEM Generator had, and same for the iron elements which are also four. I believe if you 'fragment' the OEM number of poles into more number (whether magnets or electromagnets)...and -of course- they must be of smaller circumference to fit in even a smaller diameter as OEM...you will be weakening the OEM output because of reducing the magnetic field strength in a 'per pole' basis.
What I think this could do is to reduce cogging... the more number of inner poles you could fit there, maintaining the same number of Iron elements as OEM have of Poles.
And that is just my opinion...am not saying that what you are doing is wrong or whatever else...only the real testing will tell.
But you could modify anything later on...like you have said...building the main frame is the big deal...after that is done, everything could be interchanged or modified...and you are doing an excellent work there!, and very professional!
