Looking good JimBoot
To do a power (watts) calculation on your resistor you will need the RMS voltage value and not peak to peak. So select RMS in the display menu.
Also, make sure to check the position of the switch on your probe if it's set at 1X or 10X and make sure the software probe setting is set at the same 1X or 10X, if not the numbers will wrong.
Then you can download this software which will calculate the watts if you enter the resistor value and RMS voltage: http://www.electronics2000.co.uk/assist/assist.exe
EXAMPLE
EXAMPLE
