Some Doubts
Looking at the videos in poor quality !! i could make out somethings that the inventor is not communicating but writing on paper which is barely visible.
ok! no problem , then the video is shot by some other person in some takes and in some by himself and later edited -- - so it is not a single take.
- Here is something that projects a doubt - the 1st video where he rotates the wheel and drill kicks in , listen to it carefully , the kick in of drill is like full power is given to it , like it is plugged in , so it is not a small fade in noise , but a regular noise ------ Cause a doubt that the generator is switching some relay to the drill.
- Second video , where he shows the generator 200 volt reading by moving with his hands , - i bet no generator can do that , the reading of the voltmeter are crooked , it might be 2 volt- 12 volt but not 200 V and then same with shorting the coil , many has pointed this out. This is later shown when coupled with a motor , the reading goes off the scale of 200volt because it is now producing some volts depending on the rpm of the motor .
- Third thing is the clay or dirt on the floor , it can be used in many ways , firstly to hide the live wires under it and hook them back in using the capacitor.
Secondly a whole metal cage can be built under , many pointed this out when there was tension in the belt while inventor shows load runs .
- Fourth thing is when he takes the load of the welding unit and then hits it , it caused a drop in the main line which can be heard as the motor speed drops, happens same way when a mixer is turned at home etc... shows clearly the motor is on main line, generator is just a decoy running idle. The welding unit is at main line.
- Fifth thing is when the inventor starts the generator /motor with his hand , watch careful how easily it starts the first kick it did not work and second was like instant at full power , no up and down , as if someone switched the motor on, it is carefully timed but can be filmed correctly.
- OK i have spoiled the party early , but anyone can do math later and show numbers ,since he has the CAD software and electrical background , he must have tried this and thought about those number earlier.
-Last piece of dismantelling , now this part is not there , here you see the aluminium rotors and the iron pieces and the 4 electromagnets .
- If i try to be sherlock homes and investigate the crime scene , this was failed attempt by the inventor to mod a generator (maybe the mod worked but did not produce the excess power as claimed ) and all he did was to post the edited video on youtube to boost his ego ..------ nothing else. ------case closed.
This is not new on the forum , we have seen this too many times earlier, if this is so true why not take orders and replicate this for all the people in the world , why hide under the names of indonesia inventor and old patents of James w german. - also there is 10k prize challenge for a person who shows overunity -claim it.
yours welcome
yours welcome
