  • @John
    in this technique we will use as discussed a third coil with discharge mechanism for amplification purpose, this will avoid the need of extreme tuning since it's difficult to achieve, the natural resonance will be ensured in the active ETBC as you know, the quality of this resonance will be good if high inductance will low capacitance is provided, i am still thinking about the positions of earth connection, here maybe we will follow Don Smith schematic, one earth connection in the minus of electrolyte capacitor and another in third coil in one of discharge legs, this will help forming the standing waves if two well determined voltage are provided ( they are the two earth grounds ) , the distance between those ground have to be more than 3 meters ( this is a guess ) to allow high frequency oscillation.
    • Hi Med.
      High inductance with low capacitance -Tesla builders (Eric Dollard) would say: "The self capacity of the coil is minimum when the diameter is equal to length, roughly 1 uuF per centimeter of diameter".
      Just as a matter of interest on the picture below one of the devices I am building. It is a new Tesla transformer for my previous build (on the screen) One would guess how many common rules and principle those our devices have. On the other picture is my previous build of the E-stress generator. Not sure what I did wrong, I just couldn't get a voltage on the middle capacitor. I might to take a look at it again.
      • Hi John, Hi everyone,
        yes there's a lots of common characteristics in OU devices, the E-stress generator seem to be a complicated device, in my opinion the upper and lower electrostatic capacitors must have a higher voltage, in other hand the shape of these capacitor will play a critical rules, sometimes the fundamental rules can be modified, for example gauss law surface can be modified to be a no asymmetric surface:
        take an example the following virtual capacitor:
        you have two cylinder capacitor with some deformed shapes as shown, gauss law tell us if the integral is zero, the sum of charge is zero, but in the above virtual capacitor this integral will no equal to zero due to concentration of charges in the lower plate, you have D1 and D2 , D1 is very small compared to D2 , the integral will no take D1 into consideration, you will end up with more negative charge than positive charges and this is a kind of amplification !
        • First of all i would like to express a good wishes for Eid ul-Fitr (celebration when the fasting month Ramadan is finished)
          In this post I am going to share some thoughts about electromagnetic induction compared to electrostatic induction and the difference between the two methods used to generate electricity using either an electromagnetic transformer or electrostatic transformer....
          The word electrostatic transformer isn't new but the concept here is different, some info about the known electrostatic transformer can be found here:
          Patent US5187421 - Electrostatic transformer - Google Patents
          electromagnetic transformer use a core to transfer the magnetic field from primary to secondary, here we use the magnetic portion of the two coils, this mean the mutual induction have to be relatively high for better magnetic energy transfer, low speed is better to reduce the generated electric portion ( less radiated electric field ).
          In electrostatic transformer we have to use effectively the electric portion rather than using the magnetic portion, the two coils in Tesla wireless power transmitter do this job when they form a kind of capacitor (the spheres), the secondary large number coil ( in the transmitter for example) are for generating a very high electric potential using a pulse technique …after that it’s important to have the sphere for better transmitting the generated radiant electric field ( radiant energy stream)
          The following drawing show a transmitter and a receiver and the values of radiant electric field where it has a max value in the transmitting sphere it take a min value in the receiver coil ….
          More comments will come soon !
          • Hi Med,
            Below is my replication of Ruslan's device. It also should work on he basic principles of high potential field and right timed pulses (creating standing waves etc...) I am not sure about that Tesla's "capacitor". It looks to me more like extension of the Tesla coil . Ruslan says there should be max voltage peak on that capacitor (the end of 1/4 wave). From your point of view, is there any reason why to use the thick wire and not a bar with the ball at the end, inside of that tube? The aim of this device is also to have voltage aligned with the amps, like in your ETBC
            Thanks for your advice.
            • Originally posted by John.K1 View Post
              Hi Med,
              HI john,
              please give me the time to reply your request , you are welcome !
              • hi John
                can you please give the schematic you worked with ?
                • Hi Med,
                  Below is simplified drawing of the device and my sketch fom what Ruslan said.
                  In fact it is working like that:
                  You tune the grounded pick up coil and the current coil to common resonant frequency. (standing waves)
                  Tesla fires only at every 2nd (positive) amplitude on the coils. - synchronisation is necessary.
                  My Tesla is driven by one transistor Brovin's Kacher, and push-Pull is made from the signal generator and CD 40... divider driving two Mosfets.
                  Thank you.
                  • Hi John,
                    Code:
                    after reviewing the schematics i think it's normal to use the thick wire rather than using a ball... a ball in the end is suitable for back to back system which form a kind of serial connection but in your replication it's a parallel interaction when there's some stage for current collection , the thick wire and it's diameter prove this ( at least what i understand )
                    • Thanks med.
                        Thanks med.
                        you are welcome !
                        • Sorry for this late post about the last discussed idea concerning the conception of electrostatic transformer, we still need more contributors to this thread especially replication .
                          electromagnetic transformers are based on coils and magnetic field changing speed, they work better in lower speed where the electric portion is small.
                          electrostatic transformer are based on electromagnetic scalar field, they work better on high voltage ( more electric field ) high speed is needed too, this mean we need high voltage high frequency, the magnetic field in ordinary transformer isn't similar to the magnetic field generated using scalar waves, if the magnetic field form a closed loop in ordinary transformer here in electrostatic induction form a kind of open loops !!
                          i don't have a proof about this but an ordinary capacitor is an example of the complexity of this special magnetic field which work in harmony with the electrostatic field inside a capacitor even if this field is changing in AC mode but it's still an electrostatic field regarding the separated plates ...
                          the capacitor form a kind of electrostatic transformer, one plate is the primary while the second plate is the secondary, in my opinion this explain single wire power transmission, electrostatic induction follow logarithmic law where the logarithm of zero lim log(x) = -infinity, so only one wire could transmit the power while the zero point go to - infinity and can be taken from the air, earth ground or even the empty space, zero point is any point outside the active circuit .
                          if we take the earth ground as zero point the electric current don't flow directly in the active circuit but it's hidden under the ground !
                          the above is an introduction to the new plan to extract the power from the ETBC , this device follow electrostatic induction concept, in the previous posts i suggested some circuit to extract the power from this device but they all lack some needed steps, the objective is to find an easy but affective way .
                          the past/future light cone which describe the work of this device is still needed, we know with good details how this device act but in order to take the power from the ETBC it's better to know how to reverse the operation.
                          in positive side we manage the power from A to B passing through X point but due to the wrapped time-space field in negative side everything start from X point ( this is the virtual short circuited AB points)
                          in other word we have to find a way to end back again into AB point in order to have a useful electric power, we have to reverse the operation by forcing another passive ETBC to work in reverse mode compared the active oscillating ETBC , the third large number coil is still needed for amplification purpose, the active ETBC have to be larger than the third coil for performance purpose, this will avoid completely the problem of lanz's law because the third coil will work only with the one dimensional capacitor in this situation we will have the third coil oscillating with the one D capacitor ( this is discussed and tested previously using two parts of ferrite rods inside an ETBC)
                          the new idea will be as shown :
                          the SG2 can be a neon light bulb for discharge purpose, in practice the circuit can be modified or tuned, for example changing the position of active ETBC across the third coil will lead to changing the frequency ...
                          • the evidence about Don Smith resonance device !
                            what's really behind Don Smith device STILL can be found on his famous PDF!
                            http://www.free-energy-info.com/Smith.pdf
                            there's a strange schematic i didn't noticed very well until today , the schematic prove that the ETBC is what form the primary coil !
                            please notice the element number 9 in the following schematic :
                            in the description number 9 is the reactor or induction coil but there's a minus and plus in that coil! so it's not a coil ! it's a capacitor but it's not possible to induce a voltage in the secondary with only a capacitor !!
                            the following zoom describe more !
                            the only positions are not visible are the position of spark-gap but in my opinion it's a sign!
                            • The importance of reversing the operation in order to extract the power from the resonance E-TBC
                              In this post I will try to explain the particular characteristics of an oscillating E-TBC and why it’s important to take some serious reservations for better accessing the available power.
                              in a previous post i discussed a proposed circuit about reversing the operation in order to extract the power from the E-TBC, now we have to know why this operation is needed.
                              the ETBC work in both side, it work in negative side to produce radiant energy and also in positive side to produce electromagnetic radiation which flow in divergence , radiant energy flow in convergence which made the active vacuum to supply more power to it , the mutual induction inside radiant energy do exist, the fact that the current flow in vertical direction of voltage flow explain why amplification is possible using this kind of energy , the following drawing show the process of energy conversion :
                              the process of conversion look like adding another light cone to the original existed cone which make the ETBC work as energy producer device, without proper method radiant energy ( cold electricity in the wire ) will end in the active vacuum very soon due to its convergence behaviour, this explain why we have to use 3 coil rather than 2 coil , the third coil work as energy transfer for reversed operation purpose now i am thinking about the resonance ?!
                              any ideas ?
                              • Hi to All,
                                just to put two schematics of DS, one i found it here in the forum , the other from the old video Donald L Smith 1996 Tesla Symposium, the two schematic are incomplete, the following is the second one which show a capacitor in red circle, it's clear we are working here with cold electricity, conventional electricity can't be treated like that, here we have a kind of one wire power transmitter exactly like Tesla wireless system but in the output stage DS changed the frequency back to 60HZ ! here there is no resonance like Tesla system!
                                i think the red capacitor do this job, it provide a kind of resonance or discharge mechanism( discharge mechanism provide a kind of natural resonance ) radiant voltage flow in serial from GND1 to GND2 while radiant current can be supplied using one diode or full wave diode bridge, radiant current is a kind of electrostatic potential , for this system to work in optimal condition we have to provide a kind of resonance, OK let's give the first drawing here :
                                the second drawing seem to be more advanced system with standing waves working in it ...
                                please notice the earth connections and the red point ...
