achieving the resonance using a high voltage power source if CD is closed in an oscillating E-TBC will without doubt produce an over energy device!
Hello everyone,
just to add some theoretical notes about the E-TBC concerning the positions where the voltage and current take action, there's another point where the matter particles will enter the device, it's point X or where the junction CD are situated, the voltage is the power carry the electrons, the current is the number of electrons, the matter particles point is the location where we need heavy inactive electrons.. this is why we need a center tap to be earthed!
Hi Med. I have also several of these at home. I use them for "danger" experiments when I do not want to kill my proper signal generator. Here you just change chip 555 and continue in my workI have also connected one of these with my signal divider chip two mosfets and made a lovely push-pull. I feel happy with them. Just do not expect nice signal from higher frequencies. Schmit trigger can help if need.
Originally posted by John.K1 View PostHi Med. I have also several of these at home. I use them for "danger" experiments when I do not want to kill my proper signal generator. Here you just change chip 555 and continue in my workI have also connected one of these with my signal divider chip two mosfets and made a lovely push-pull. I feel happy with them. Just do not expect nice signal from higher frequencies. Schmit trigger can help if need.
just a quick reply, if you are able to test the resonance with the E-TBC if CD is closed please do it ! you don't need a high value HV capacitor, if you use a toroid inductance like the previous proposed circuit i want to know how the E-TBC act when surrounded by other inductance, i guess the internal capacitor of E-TBC can't be seeing by the resonating system so it will act just as ordinary coil with small inductance of course.
some mistake have to be avoided when dealing with the E-TBC
the most critical point in the E-TBC is the junction CD or the one dimensional capacitor, this junction have to be closed in order to achieve the serial resonance, the serial resonance inside this device is the electrons spin mechanism, when the E-TBC pass through this point CD junction act like an open circuit, in other words the 1D capacitor will act like a coil, AB will act like a capacitor... serial connection have to be done in dynamic state, this is very important so the oscillation can grow up, super conductivity can be achieved in room temperature, negative resistance effect can be seen also where the device is able to attract ambient electrons for free... all these effects can be achieved only if CD is closed ! now the only way to benefit from this device is to achieve the resonance in this condition !Last edited by med.3012; 09-07-2015, 11:48 AM.
Matters particles, electric current and the voltage are the three players in the resonance induction system, they appear in a resonating E-TBC, electric current is the synonym of magnetic field, voltage is the electric field, matters particles is both together, the magnetic energy can be expressed using L, the same about electric energy when we use C, matters particles is the equilibrium between magnetic and electric energy, now we could introduce the third parameters as R.
in a resonating E-TBC the third parameter is situated exactly in the center, this energetic balance is the secret key for the over energy behaviors in this device, heavy inactive electrons is forced to enter the device without effecting the energetic balance between the magnetic and electric power !!
the quoted from Smith.pdf
since magnetism and amperage come as one package, this suggest, that the electrons in their natural non-ionic state, exist as doublets. when pushed apart by agitation one spins and supplies electricity and the other spins and provides magnetic (amperage) energy,........Last edited by med.3012; 09-09-2015, 11:59 AM.
Hi Med.
Sorry , didn't get a chance to sit and experiment for last two weeks, as very busy at work due to holidays.
You was saying something about the resonance of ETBC. What resonance do you mean?I might to suggest you not to overlook the resonance of open air column too
Maybe to use the common frequency of both?
Cheers,
HI John, Hi everyone.
the resonance inside the E-TBC has a long story..., in theory the device is complicated, the capacitor as we know it don't exist at all inside this device, this is why i call it a 1D capacitor, serial resonance has the same frequency as parallel resonance both together give the multiplying electromagnetic flux... the device has the ability to change its shape using electron spin mechanism !!!!
so it could bypass the short circuited capacitor using another resonance called serial resonance, again this is possible only due to electrons spin changing behavior... cold electricity is able to work with hot electricity in this device since they are out of phase if one give the current the other will give the voltage, now we have to close the junction CD in order to achieve serial resonance...
Originally posted by John.K1 View PostAcoustic pressure dragging free electrons -> current -> magnetism ? Yes/No/MAYBE?So I would try to run it ALSO in acoustic resonance.
i don't know which device you want to use the Acoustic pressure, so maybe YES ! in the E-TBC when CD is used as spark-gap the electrostatic discharge change the geometry of the E-TBC, the device produce a sound , this is of course if we ignore the sound of spark discharge, if the E-TBC change the shape even slightly the frequency will change so far since it produce double normal resonance frequency, this is another reason why we have to close CD !
How the E-TBC can change its shape during oscillation ?
this point is confusing a little bit, let's explain this, please see the following drawing where we have two observer in front of the E-TBC viewer 1 , the other in the rear end viewer 2, in the same drawing we see the voltage electrons in red, current electrons in black, in the middle we have no-ionic state electron in blue, serial resonance is the way where the device change its shape! this is strange but possible because the electrons work in two spaces, positive energy space and the twisted negative energy space, the time when all the electric energy change into magnetic energy serial resonance start just before the second half oscillation, this is why this device provide twice the frequency of ordinary parallel L/C circuit, the twisted negative energy space exist everywhere, when the magnetic field collapse the electrons just change its spin direction, the red electrons in side view 1 will just change as black electrons in side view 2 !! these electrons change their spin across point X since it provide the symmetry between magnetic and electric side inside this device, the red coil in the drawing appear to be CCW from side view 1 in side view 2 it's CW, this is not possible in ordinary solenoid coil, everything in the E-TBC is related to electrons spin direction, the coil and capacitor is nothing than energetic elements !
Just want to share with you some interesting free 2D magnetic (FEMM) simulator Finite Element Method Magnetics
Also, I just watched some interesting video in which you can get quite nice understunding of the different types of energies :
https://www.youtube.com/watch?v=vODUGjRaSxw
