I replicated some weeks ago a patent from Dr. Imris and, in theory, you get a magnetic field using an oscillating electric field.
Originally posted by AetherScientist View PostI replicated some weeks ago a patent from Dr. Imris and, in theory, you get a magnetic field using an oscillating electric field.
yes Imris patent is very important but it's very difficult to make such a primary coil that resonate in 50 hz, keep in mind the resonance frequency of your cap/coil is doubled if we take the following parameters :
in the capa/coil we need the double capacitance and double inductance , say 200 mH and 200 uFAttached Files
Originally posted by tesluh View PostIf you had to guess what range do you think the high voltage dc pulse frequency would be?
For that I have an automotive ignition coil, an iron core nst stripped of it's gfci, an ac flyback, some dc flybacks, a pvm400 or a handmade neon sign transformer (69khz). I have created many circuits most of them using spark gaps, that get the coil to ring and disturb ambient (shown by a voltage detector stick) but I don't think they are ringing it the right way, or at the right frequency.
it's not a guess, it's what i have in my hand, flyback transformer seem to be a bad choice due to the position of diode in these transformers, the response in it can't be predicted also due to the parasitic capacitor in the secondary side ... if you want to try something with the ETBC i suggest using square waves with very small duty circle 10% is good ! also try to work bellow 300 KHZ as resonance frequency of ETBC, using ferrite core will help decrease the resonance frequency and also help to achieve magnetic ringing .
Originally posted by AetherScientist View PostHello med.3012. Researching a little bit more.
How are you?
Yes, a magnetic field can be created using capacitive displacement power.
In the following video, the input to the transformer is single wire from Tesla's coil. You know the output from Tesla's coil is displacement current. An alternating electric field.
[VIDEO]https://www.youtube.com/watch?v=VRQkRYXtob8[/VIDEO]
all is Ok , thanks for asking , you didn't clarified your request in PM, i am also researching a little bit more as a lots of ideas pop up but it's not easy to experiments because every-time i make new coils changing something to see what happen.. , securing some needed parts etc ...
most of us here want an easy but effective way to produce significant electric power but we forget the mind produce such things is very rare or at least we have a few of them in this world ... collective work is a must here ! as there's a strong connection between over energy devices it appear to be the same thing in different forms or names ...
thanks for the above video ... there's some kind of music that have to be heard in these devices to work ...
the electric field is the magnetic field itself ..seen from another frame, the proof about that is the ETBC itself when it oscillate in a specific frequency even there's no capacitor since it's already short circuited .. the coil is opened also, the charge and discharge mechanism is there in electron's spin separation mechanism , the geometry of Tesla bifilar coil when extended help the electrons to stay in its place doing it job perfectly , in other words it's the equivalent of permanent magnet in a dynamic state.. the problem with electric side is it's a dissipater component that have to be stored in a capacitor banks for a perfect usage .. the latest test show this capability when using the ETBC directly as a tank for mazzilli driver and then taking the power from a single wire ( the hv side ) some interesting phenomena appear because the excitation appear to be very high but further test have to be done to improve the things to an acceptable level ... i really don't know the next step ! maybe trying plasma excitation system using the ETBC as a source of more balanced energy .. maybe the gas will amplify or provide a good medium for energy transformation ... who know ?
After reading your pdf on the etbc I understand more than the first time I read it. I have battery/mazilli driver/dc flyback/ spark gap/ capacitor bank/pile of caps for impedence matching. The bifilar coil looks easy enough to make and I get how to make it now.
Referring to fig 45 on your pdf, Do you have any suggestions on what the L2 is supposed to look like? I have an l2 for a Don Smith device ready to use. (edit.. nevermind, I just found it "The coil length is about 25cm as shown in Figure 42, the diameter is 6 cm, and the thickness of the wire is 1.18 mm (AWG #17 or swg 18) and the number of turns is about 200. "
"Some applications may not need an inverter. An electric heater can be fed directly from the capacitors banks but we have to prevent the Alternating Current coming from L2 to enter the heater by using another high inductance coil. "
Very interested in this, where would the high inductance coil be placed in the circuit? I don't care if I had a "self runner" if I could power i.e. 10kw worth of heaters for 100w and no easy way to get the power back to the source I would still be very very happy.Last edited by tesluh; 02-19-2017, 03:27 AM.
Originally posted by tesluh View PostAfter reading your pdf on the etbc I understand more than the first time I read it. I have battery/mazilli driver/dc flyback/ spark gap/ capacitor bank/pile of caps for impedence matching. The bifilar coil looks easy enough to make and I get how to make it now.
to be honest there's some errors in my pdf even though the overall idea is correct , this is why i am here to expand and correct this system.
L2 can be a combination of CW and CCW set of coil where each side have to have 4 time the length of ETBC ( the two foils ) moving L1 inside this coil can help in tuning and eliminate lenz's law effect , standing waves have to be seeing in order to success in this , sudden change in wire diameter / material can help in the creation of reflecting waves
L2 can be also a large turn coil exactly as Tesla coil, the self resonance frequency of it have to be equal or less the frequency of ETBC, i did a test where the Tesla coil frequency = 500 khz and the frequency of ETBC = 1.5 mhz , this is a disadvantage since the parasitic capacitance work as a hidden load even when using single wire harvesting technique ..
L2 can be a plasma tube where the excited gas atom work as amplification or transformation medium radio-ionic
about the application that don't need an inverter there's a lots of things to consider here , not only the power but the electric current that generate the heat ! in this case it better to step down the voltage to get even higher electric current ..
Originally posted by tesluh View PostIf I run out of other experiments to try I might measure one of my don smith l2 coils and make an etbc 1/4 length of each half and see what happens.
good luck with your experiments, if you love the idea behind the ETBC you can try either the Mixed ETBC or the serial ETBC , about me i am doing some calculation before going so far in experiments.
Originally posted by med.3012 View Postmotivation from John Bedini ..
https://youtu.be/4iccJ0Uxdq8
[VIDEO]https://youtu.be/4iccJ0Uxdq8[/VIDEO]
"motivation from..." This video is no longer available due to a copyright claim by Energetic Productions, Inc..
Sorry about that.
How are you?
i just tested this experiment with an ETBC and it worked perfectly,the details about this is attached.
Hi Wistiti !
the Battery offer a virtual ground for the electrostatic induction to work better it's there to help cancelling the induction of large coil L2 even though you can do the experiment without it but it help to get the bulb brighter ...
there's a strange relation between the electromagnetic inductance and the electrostatic induction but it's obviously Don Smith used this circuit , please take a look at the following drawing referred to Don :
the coil 6A and 8 share the same magnetic core , it's the small ferrite torroid used in this test , because electrostatic induction work in serial this is an old Tesla schematic used for light experiments but there's a small change in Don schematic to blind our eyes about the source of this vital information !!!
the following from Tesla old writing !!
welcome !
there's more details about this will come soon Insha Allah , i decided to replicate this circuit when i read about it in Tesla writing but the most impressing thing is that Tesla gave a strong hint about free energy and this circuit ! !
