First, you said that we need to have SG in HV, now you said that SG is not here?
Originally posted by Pidja105 View PostFirst, you said that we need to have SG in HV, now you said that SG is not here?
if you read the previous post you understand ... the SG in CD as desribed in the PDF can't give the desired results.. so we need to make the SG outside , if you are good in electronic you could resonate the ETBC in HV using mosfet .Last edited by med.3012; 04-18-2017, 05:17 PM.
Originally posted by Pidja105 View PostI dont understand l2 coil, is it one normal coil or some kind of receiver transmitter coil, if it is R T coil how to wound it?
Maybe...
Hi Med!
I don't have the time to test it now but if you have, I think using the "JackNoskills" coil capacitor with open end as the primary and wind your ETBC over it, with open end either, as the secondary it might give interesting results...
Sincerely!
Sincerely!
thanks for your input, each experiments will teach us something, at the moment i am taking a long repose, i think i am tired and need a little rest, any advance will be published at real time !
Hi Med!
Just let you know today I have some spare time to test what I have suggest to you in my last post but have no good results with it...
I archive better results with multi layer bifilar coil open secondary.
Will let you know if I reach interesting results.
Sincerly !
Sincerly !
hi Wistiti !
thanks very much about your interest in this technology , the idea behind the ETBC is very simple.. how to convert voltage into current, more voltage is better especially in the primary side , this is why this experiment show something very important when we rise the voltage in the secondary side to see the effect of this amazing geometry ..
i attached some photo to see the simplicity of the experiment, the distance between the ETBC and L2 have to be small to see the effect ( the bulb will light ) the reason for this is the low voltage in L1 , 12 V is still very very small to see a significant power so a little amount of power is a proof, L2 have to be not in the center of L1 so you can take a good amount of radiant energy ..
Originally posted by Pidja105 View PostHi again,
Med, from which insulator you made ETBC, I wish to make it from wax paper?
i already gave all the measure of ETBC, about the insulator i am using it's only good in low voltage but in HV i heard an internal spark inside the ETBC!so i have to change it when start again in HV
read the previous posts , any question please ask :-)
