    Hello Bob ,
    yes valuable info can be found there but there's also a minor mistake like :
    We see this everyday when the electric power company uses their high voltage – high frequency system in transmitting energy into their distribution system. Typically they use from the source, 100,000 to 500,000 cycles per second
    power company use high voltage ( but low frequency ) to minimize the loss since the current goes to low value.
    another point is the use of spark gap he said : A: spark gaps and lightening arrestors, spark plugs included when I use them are not used as a or frequency or device timing. I use them for spike, overload and lightning protection. I use high quality capacitors, resistors and inductors.
    but in the following video he talk about the possibility to use any SG as switching mechanism :
    https://youtu.be/tASY07r9AD0?t=2291
    the two statement make it unclear how he used the spark gap
    Thanks Mohamed
    Yes, that was my impression about the power companies as well, that their frequency did not have to be as high as Smith states.
    As far as spark gap, I have seen gas discharge tubes and lightning arrestors used in different setups, as well as tungsten or SS electrodes. It is my understanding that the spark gap in effect renders a setup an open system.
    One of the things I've been trying to wrap my head around is the idea that magnetism is key to the approach you are taking in this thread. I am reminded of the famous Borderlands Eric Dollard video from the early 1980s (I think) showing how resonance separates dielectricity (voltage) from magnetism. https://youtu.be/LwFWx5RkwDE?t=1384
    You have made it clear that resonance brings about big effects that should only be experimented with by properly prepared persons. It would seem that this is crucial to arriving at the desired output effect.
    I need to go back and read some of the earlier posts to reconsider what I read with less understanding.
    Bob
    • Originally posted by Bob Smith View Post
      Bob
      Hello Bob,
      Yes this is true but the problem remain difficult to solve in this case because i am focusing in disturbing a great amount of power using a very special coil geometry ( THE ETBC ..) in the secondary side i am using ordinary coils to pick up the power, in other hand Don Smith used his unique antenna dipole to collect the power ! he also explain that most electrical appliance we use today generate a huge electrical power as wasted energy .. this energy return back to the ambient back ground , if my analyse is correct i was using the ETBC in the wrong way since any electromagnet coil when pulsed it generate a huge amount of wasted power , if we could gather all this wasted energy over energy device can be built as simple as making a simple light bulb circuit !!!!
      a friend of mine sent me a photo when he used ordinary bifilar coil as energy receptor, he used induction coocktops to generate the needed electromagnetic flux , most of us saw something similar to this but i think it's the time to reverse the things ..
      regards
        if my analyse is correct i was using the ETBC in the wrong way since any.......
        i don't mean it's totally wrong but sure there is another easy effective way to do the same thing .
        • Another way
          Hello Med.3012,
          And, a Merry Christmas to you for tomorrow! If you get into the seasonal action.
          I come back to my point made some time ago, colloidal suspension. How can we make a small vacuum in the aether ( the colloidal suspension), without any walls, that will such the aether energy into it, but, without ever filling the vacuum? An oxymoron? No. In reality, isn't this what we are trying to achieve? Sucking energy out of the aether with a minimum of fuss. Like picking an apple off the tree when ripe?
          I think there was a device proposed some time ago by a Karl Schappeller, which was a spherical device, which in hindsight, might be a useful starting point for your revised approach.
          I shall dwell on this over Christmas Dinner! A Christmas gift/present to myself.
          Bon Noel
          Dwane
          • Originally posted by Dwane View Post
            Hello Med.3012,
            Bon Noel
            Dwane
            Hello Dwane !
            have a great Christmas!, i don't have all the answers but the idea of Don isn't that difficult.. we only need the correct reasoning , the dipole we need work as a half inductive while the other half capacitive cancel the inductive effect ! the primary coil can't see what's going on since you have two opposite current .. this cancel lanz's effect and you can take as much current as you can :-)
            the magnetic core will enhance the process.
            take your time and enjoy !!!
            Mohamed
            • hello everyone ,
              as i see most visitor here don't post anything .. the information here is very valuable so we need more contributor, i am not asking attention but i ask help to make the thread grow ..
                hello everyone ,
                I hear you loud and clear!!
                It would appear that forums have a greater attraction for the talkers'. For myself, I always seem to be looking for parts or waiting for them to arrive. For those living in USA, there seems to be an abundance of parts for assembling Energy devices.
                For this interesting experiment, I am trying to track down what I think are suitable ferrite cores that I could use to replicate your efforts. The closest I have seen are on some Russian site. The shape of which which appear similar in size and shape to the one used for your multiple wraps. I am still waiting for a couple of large ferrite cores from the Ukraine! Over a month now. Looks like another lost in the post syndrome!! And as you would be well aware, experimenting and prototyping is not a cheap exercise. Therefore, I submit to you the old English adage "Talk is Cheap!". In this case literally. Perhaps why, forums produce a lot of hot air and experts.
                I shall keep in touch when I am able to show something worth looking at.
                edit:ferrite toroid core coil concentrator
                Dwane
                  Dwane
                  Thank you Dwane !
                  i agree with you 100% !
                  regards
                  • info request :-)
                    Hello everyone ,
                    i need some info about the best stainless steel suitable for high frequency, i don't have experience with such material but some test show it got hot, this mean more wasted power ... any idea ?
                    regards
                      Hello everyone ,
                      regards
                      Stainless steel is not magnetic. I guess thats why it gets hot. the inability to produce magnetic field equals resistance (not sure but it seems logical)
                      resonance is based of the transformation between a magnetic field and a dielectric field.
                        Hello everyone ,
                        regards
                        This might be of help in answering your question - knowing the composition of your SS and its magnetic or non-magnetic properties:
                        https://www.bosunsupplies.com/StainlessInfo2/
                        Bob
                        • Originally posted by evostars View Post
                          yes some kind are not magnetic but other grade are magnetic.
                          regards
                            Bob
                            Thanks , i think it's better to start with ferrite since it can handle high frequency after that we shall see how to use another material
                            regards
                            • Hello ,
                              i am glad to put the following video which explain another step , another new coil technically it's a Dual ETBC , the drawing show its details
                              the YouTube video explain much more !
                              https://youtu.be/GuvJfAV1UA8
                                Hello ,
                                the above idea need a little polishing, everyone interested can examine this model so the little gap can be filled
