  • Originally posted by Dwane View Post
    Hi med,
    Thank you for your reply.
    I deleted the last post as I thought it might have been inappropriate to critise your helpful advice.
    If I create SG between CD I get better response at light globe! I have not used SG because your Serial ETBC video says it is not needed in ETBC. There is other solution.
    I am next trying spark gap in tube. The issue I see for SG is replacement with wear.
    I do not seem to have Part 2. are you talking Mohamed.pdf part 2?
    Rergards
    Dwane
    Hello Dwane !
    it's the same PDF www.free-energy-info.com/Mohamed.pdf , part 2 describe Tesla wireless system and how related to the ETBC using part of prof K.Meyl work, this is a fast reply i will explain more later.
    regards
    • Hi med,
      I have been going over the early comments in the thread.
      My wrap is never going to work at the level we re expecting. Inductance 31.5uH, Capacitance 92nF. F = 94+Khz. My Mazilli is running at 42.5Khz. Not even 2:1. I can adjust the Cap and get close to 2:1.
      With the SG sound is very loud! Like an old Gatling Gun! Need to get up to Mhz. I do not think that this is going to be possible with the quantity of materials I have used. However if I close the gap of the SG to minimum, I get plasma effect. I have made a parallel SG using two straight wires, thinking that this configuration might give longevity and even quality of spark.
      With wider SG gap get big voltage spikes, with small gap get higher frequency smaller spikes. I suppose, it evens itself out. When SG in tube, there does not seem to be any amplification back to Wrap. Have not wound L2 yet to test mutual coupling with SG. Is it possible that L2 connects across the CD/SG?
      Dwane
      • @Dwane
        Hi !
        the ETBC resonate in double frequency, in case of Inductance 31.5uH, Capacitance 92nF. F = 94+Khz X 2 = 188 Khz !
        the SG between CD give a powerful respond due to low resistance , it's a capacitor discharge across itself to form a coil , it's expected some electrons near CD region see a very tiny resistance which lead to very powerful respond with big sound .
        there's a good scenario that you can test, i want to share my idea and you can choose !
        the ETBC with open CD can be used as excitation coil but you need another ETBC as explained before , here you are the drawing again :
        the power can be taken in star position in large amount , this is the best coil to take the power , about your question : Is it possible that L2 connects across the CD/SG? yes there's some amplification when connecting CD with L2 .
        regards
          @Dwane
          Hi !
          regards
          The above coil should be named as the twin ETBC OR T-ETBC , have to be used with great care with an ETBC since there's a danger of high voltage high current which can be lethal ... ( warning ) , the excitation ETBC better to follow the T-ETBC geometry , the following drawing will show the correct usage :
          it's the pick up coil or the T-ETBC , in the excitation coil we can use ABCD , the only diffirence with T-ETBC is the place where we take the power .
          • @ med.3012
            " there's a good scenario that you can test, i want to share my idea and you can choose ! "
            I have sent a message!
            Dwane
            • رمضان مبارك كل عام و انتم بخير
              Ramadan kareem
              • duplicated post !
                @ ilandtan
                hello !
                it maybe interesting to you and other researcher in this field to share the following drawing which prove the ultimate relation between Don Smith and the ETBC !
                to the right my model the T-ETBC , to the left an image token from Don 1996 presentation :
                don smith system appear to be a 4 layer ETBC, this mean two layers form the primary but another set form the secondary which can be a perfect arrangement to cancel lenz's law ( maybe to extreme level ..)
                the conducting foil appear clearly ! i watched that video several times but never noticed this until recently !!!! ( maybe the reason is the length of that video which exceed two hours ... )
                regards
                • Hello everyone ,
                  just to add two Don Smith videos about his resonance device :
                  https://youtu.be/BHr3eDELyHk
                  https://youtu.be/_8JwIlHLOUI
                  in the first one he talked about the infinity loop which is in my opinion the vital key to his device , i would like to thank Rick Friedrich once again here for posting such info to continue this long road research !
                  • Originally posted by Netica View Post
                    Hello Med.3012
                    I was interested with your pdf but I don't understand what the diagrams are symbolizing in fig's 5,6 and 7. The red and black dome shapes.
                    You are talking about coils and capacitors but I can not relate what you are saying to these diagrams.
                    Can you please explain what they are supposed to be and how they relate to what you are trying to explain.
                    Thank you
                    Netica
                    hello again
                    in Fig 5 i just explained the geometry as explained by Don Smith a CW coil with another CCW , since the ETBC is a kind of flat coil both side can be seeing from one face , it's just from where you start taking the beginning of this coil , from the outside it's a CCW but from the inside it's CW , if you turn the coil things will be reversed .
                    in fig 6 it's an analysis of ETBC , a simple capacitor charged and discharged through CD
                    fig 7 a static electric field is secured .
                    regards
                      hello again
                      regards
                      Hi med,
                      Sorry but because I can not physically understand what those black and red cup shape things are or supposed to relate to or what they are supposed to actually be it is impossible to understand and follow what you are trying to explain. Because what they are in the drawing is what matters as to what happens. If they are supposed to be a particular coil or a particular capacitor and particular orientation then show exactly what they are and how they are orientated. Or if they are something else which is attached to something else please show it.
                        Hi med,
                        Hi !
                        the black cup is a negative plate, the red is positive plate , both is a charged capacitor , after discharging it and because it also a coil there's some interesting phenomena happen .. the following is what i wrote in my PDF :
                        Let us start by analysing how the extended Tesla bi-filar coil
                        works. Imagine that the following drawing is a
                        charged, extended Tesla coil with the positive and negative parts, shown as red and black plates respectively
                        the cups there is just a plate , the drawing also help understand the inductance behavior, this is why i have to draw them as a cup using office Microsoft word .. 3D model will be amazing but not easy to draw but the idea is simple, when we connect the red plate with the negative plate an electric current will circulate and build a magnetic field .. the nice thing here is we secure a static electric field from the induced E field .. this is an extra power wasn't present before , this was the most easy model to understand the ETBC, another model describe it as a compacted Tesla wireless power transmitter ,
                        we have also a third model still not analyzed but anyone read my work here can see it :-)
                        regards
                        • Etbc
                          Bought a couple of rolls of Au duct tape and will wind a transformer/cap with it to see just what this is all about. These are 1.89" wide and 50 yards long. Should make quite a coil indeed. And one heck of a cap too.
                          • Originally posted by thaelin View Post
                            Hi !
                            the ETBC is a wonderful device that convert reactive into active.. the sad part in all this is the lack of volunteers...., the process is very easy, we just need good circuit to create such reactive power with less tuning ( self resonance ) ..
                            anyone can help please do it
                            regards
                            • hello !
                              the work still going on ! you can follow us here
                              https://www.facebook.com/groups/1317678255044790/
                              regards
                              • Still here
                                Hi there buddy,
                                Have discovered the importance of the dielectric separator for the ETBC!! Here are some shots of my "Success". Very noisy though. This set up is not tuned yet, although I have had 98uT out of it, which makes it pretty darn god. The photos just show the basic set up as per the Mohammed.pdf with the exception that I can only get the output keeping the spark across CD. If I close this and advance to last details in pdf,I get dismal spark with hissing sound not the big thunderclap sound. My wife keeps shouting what is that noise! Hmmm.... Need to quieten it down some how. Happy wife happy life.
                                Unfortunately bright spark is suffocating camera lens. Will see if I can get a clearer picture of the brightness and strength of the spark.
                                Could not understand the Arabic on the above facebook link, even with English selected.
                                Dwane
                                ab
                                Edit: Not across CD but AB. Enter ETBC through CD. Also, caps do give good running. without caps, gets bit jerky!
