The tear down was good to see and the circuit is everywhere on the web. I am afraid that the very simplest form of OU circuit construction plans will fail because 99 percent of the people on the web can't build simple circuits.
They went to school and ended up in a job that did not require electronics or the circuits they did build were 555 timers and PIC stuff but they don't really have enough background in old time radio.
Someone should have been able to replicate AKULA's stuff by now. I think when no one will follow their work anymore because the answers are hidden then they start showing more details.
I know some successful tpu builders and they use the vertical and horizonal winding as AKULA has shown. This is good to see. One guy I know says that just a few winds in the right way is all that will be needed to run the electric microchips.
Once that is out of the way then getting the 1 watts becomes only a matter of input/output/recirculation on the main windings.
Seeing the copper foil and windings will help a great deal to inspire many inventor types.
You need to make up your mind. When I posted in your thread that Gerard didn't have a clue about what he was talking about you basically said all my years of experience and education were blinding me to the truth. Now you are saying people aren't being successful because they don't have enough experience of exactly the kind I do have. I have an advanced class amateur radio operators license (Ham in other words). I have built my own transmitter and many other electronic and electrical projects. I started repairing radios when I was 14 years old.
So which is it? Is education and experience a handicap or a benefit? You need to make up your mind about that. I already know the answer. My over 50 years of experience helps me to spot the fakers and also helps me to see when something holds real promise. Without the education and experience everything looks like magic.
Mikey
Respectfully,
Carroll
Sorry Chet for derailing your thread.
I guess you made up yer mind already huh? I think that answering the question as to whether or not you have ever witnessed anything OU is first. Is it a Yes or is it a No?
Yes and No is unacceptable to me. I don't care about how many degrees you have or don't have as long as you got the OU.
Well, do you? And that is why you attack me because I uncover your guarded responses. Show me an OU project of yours as you say in the past 50 years and that is the answer as to why you are upset with me.
Yes or No? Show me.
Take care now.
Calm down and post a working project so the younger guys have something to follow or let the young guys lead you. It's up to you now. You may not be able to do this and there is no shame in saying you were never able to achieve OU, most of us have not, you know.
Either you got it or you don't but don't get mad at me for you inability.
Similar to Akula here is a replication of this type of work powering LED's
Self running circuit, he pulls the cover and shows you it's start up using
a double AA battery.
If you are sincerely interested in learning about powering led lights with a simple circuit or about radio in general and have a limited knowledge of radio, and electronics in general, I would recommend
"22 Radio Projects for the Evil Genius." It's easy for beginners to understand, and you end up with some really cool builds that you will use for the rest of your life.
The Ambient Power receiver in chapter 17 does EXACTLY what they say it will do. I have built a couple over the years. It is absolutely "free energy" except that it isn't. It converts one form of energy that YOU don't have to pay for to another that you can use. Batteries are NOT included because batteries are not needed.
I bought my copy because that's the kind of guy I am. I like having copies of good reference materials. But it is available to download...at least for a while. PDF of the book http://www.ik4hdq.net/22RadioPro.pdf
I have burnt some mosfets plus drivers but the modular design of my output stage makes the replacement easy.
Nothing to report so far. I played a bit with JLN's config but could not get enough juice because primary inductance was too high.
I had to rewind the primary and decided to go straight to Akula's topology from this video
The magnetic coupling of the side resonating tank circuits to adjacent output coils is a bit tricky to adjust because of uneven air gap.
I think I'll use some epoxy mixed with black iron oxide dust to glue those firmly in place having equal coupling measured with the LRC meter.
All is left is the primary exciting coil in the center section for my push-pull driver on IGBTs. 8)
... and some time
Aligning black sand magnetically is an option VS just mixing up
a batch without alignment. Ordering dust all is the same direction
makes a much more better core material, I have heard.
The only thing I have not decided is how I would setup my field on a C-CORE geometry.
Very powerful neo's could be used or I thought to use 2000volt MOT coils to setup a concentrated/directed magnetic field that would be strong enough while the epoxy sets up.
... and some time
