Gerard Morin's Video - The Doubt about OverUnity is Over
  • #46
    Originally posted by lotec View Post
    Well timed shots of the right pulse duration from a magneto, with sympathetic vibrations filling in the gaps may setup your longitudinal or stationary wave.
    The output may need rectifying and reinverting perhaps. I saw some valves but was there an unexplained inverter kicking around. Just a thought.
    According to the wiring diagram of the McCulloch generator that I posted on this thread, there are no diodes of any kind in the generator.
    Additionally, it appears from the video that Gerard Morin posted that no semiconductor devices are being used in his set up. Of course, if he were to use an inverter as his prime mover, then that wouldn't be true.
    I do believe you are right about well-timed, right pulse duration from a magneto.
    Personally, I believe that cold electricity is produced by collapsing coils.
    Consider the method proposed by UFO for producing cold electricity.
    Diagram was found on Patrick Kelley's free energy web site
    Consider UFO's video on Radiant Electricity: https://www.youtube.com/watch?v=W1KALMgFscg
    VIDBID
    VIDBID
    • #47
      New Gerard Morin Vidoes Found
      https://www.youtube.com/watch?v=LAhQxwwXgxM
      In this video, Gerard is using an inverter instead of a generator.
      The problem is the video seems to cut off in the middle.
      VIDBID
      VIDBID
      • #48
        Minute 18.36
        Okay here it is Matthew
        Minute 18.36 I went through it a few times and finally found the correct minute. I am not against you. I like everyone and if I have to add a word of confidence I will. You are a great mind and I hope all is well.
        But the fact remains that he did say in minute 18.36 that he was feeding 120v at 2800 watt. In another shot he shows the connection diagram in physical form by saying that he is only hooking up ONE SIDE. Any one who understands electricity in the form of AC knows that if a specific winding does not get the designed voltage into it the output will be all over the place.
        I will direct the remaining portion of this message to whom it may concern because I don't think that the people responding here are the only ones who understand AC transformers.
        If you want to quote the man wrong and get all upset with me for pointing this out then that's to bad. I don't like disinformation so next time do the math based on what the man said and not your fantasies . People look up to you Matt and many of them believe everything you say even if you are wrong. This is very bad for and open loop experiment.
        Swallow some of your pride sir and just say that you were wrong. It ain't nuttin. I will address disinfo as much as I hate to, but I won't pet a man who is wrong or deliberately puts out false information. I don't care WHO he thinks he is. pouting about me picking on you only makes me laugh. You can handle a little criticism, you can sure dish it out.
        Beware of putting out false statements. Buck Wheat will strike, count on me. Show us a video in your lifetime about anything.
        Okay let's continue. @All
        Not only in minute 18.36 does the man say it is powered at 120vac @2800 watts, but also by saying the generator is connected to only one side "ONE SIDE" of a line transformer that has 3 poles for power.
        Anyone who has wired up a simple house main box knows that there are 3 connections. The white center connection is neutral, The other two outer connections each produce 120volt from the neutral wire. The two outer poles are 240vac.
        From this we can see that the man in the video is running 120vac to one side "ONE SIDE" meaning from the center neutral connection to a single hot lead.
        I don't know what minute this is spoken of, but if people are going to comment on such a complex discussion they should be sure their ability to comprehend is sharp enough to retain the subject matter.
        To do this I had to re-watch the video many many times. I am a slow learner .
        Remember that if you are going to do transformer work you must first get a small one and experiment. If you power a 120v winding say with 40vac and the output is rated at 20 watts normally you will not get much more that 5 watts out if that and your voltage will vary all over the place.
        The point is that a transformer must be run at its designed voltages or you will have wild swings in your output. Swinging voltages and amps of worthless power to use for anything.
        The point is that man in the video is smart enough to know that and is running one side of his pole transformer on the designed voltage of 120vac as he has stated in minute 18.36.
        I hope this helps to keep focused on what the man said and not the miss quoting dis-info speculation that has nothing to do with what the man said.
        The man in the video said that he was running a genset at 2800 watts to the line transformers. Two 500 pound transformers that output over 5000 watts.
        Now that is what he did say.
        The problem is he didn't show anything working. There is no relevant facts. Its just a video with claims. He didn't even try to show you anything.
        But do what you want. If you believe its an equatable investment to see it work than jump. No more video's are going to help.
        Matt
        • #49
          Me too. And also aggressively discharging or shorting caps.
          My connection doesnt allow me to watch all the videos. So I shouldnt say too much. Alot probably could be said about one wire longitudinal transmission, one wire rectifying of secondaries and reinverting back to usable frequencies along with tweeking the transformer connections, I get the feeling it may not be so relevant in this case.
          PS Thanks for the info on the cold stuff.
          lotec
          • #50
            Vintage McCulloch Generators for Sale
            Kijiji: Free Classifieds in Ontario. Find a job, buy a car, find a house or apartment, furniture, appliances and more!
            Apparently, there are some places where you can buy these types of generators.
            VIDBID
            VIDBID
            • #51
              Direct Download of the Video: The Doubt about OverUnity is Over
              lotec
              That's too bad.
              Maybe you can download the video:
              Middle Quality, MP4, 360p - 153.9 MB
              Low Quality, 3GP, 240p - 54 MB
              VIDBID
              VIDBID
              • #52
                Dang it! I was following along quite nicely and I guess they ran out of memory on their video stick.
                What I was seeing there though, is typical hot electricity matching one for one as would be expected. No obvious magnification. He was only measuring voltage, so it's hard to say. He did mention in the other video that only two things matter: voltage (pressure) and radiation. Still a little confused be that, but I'm certainly willing to learn more.
                I hope the #2 video comes out soon with the punch line, because I have a hunch it will be important.
                • #53
                  That's too bad.
                  Thanks for taking the time to post that.
                  I got the small one without getting bumped off.
                  lotec
                  • #54
                    Your right Mikey. I made mistake, I missed what he said just like you did when you went to look for it. I still won't believe an ounce of it until I see it work. But I am capable enough to build it. How bout you?
                    So I got a generator that will work that puts out 120 vac from 12 volt and its mechanical and smooth. Its bipolar and that is what he said is require from the generator. Its easy to build for sure if anybody else wants details.
                    I think the best way to test is to use the Tesla type transformer. At least thats the best way to up the voltage. Flat pancakes don't require much to make and it already has precedent in wireless transmission.
                    OS:Tesla, Meyl, and Jackson's Wireless Aetheric Power Transmission - PESWiki
                    And the fellow in the video sited the patent himself.
                    At minimum it should show something.
                    Is anybody else going to try anything? Got any plans? Discussion can only go far.
                    Matt
                    • #55
                      lotec
                      Awesome. If there are any future videos that you would like to download, you can go to Grab online videos for free with Video Grabber, Grab video from YouTube, google video, Dailymotion, vevo, Vimeo and many others and download your video there.
                      Code:
                      http://www.videograbber.net
                      Another option I use to download videos is to use a video downloading plugin for my Firefox browser. It's free, and there are several to choose from.
                      If you're using Firefox, select Tools, then select Add-on, and then enter "YouTube Video Downloader" in the search box.
                      VIDBID
                      VIDBID
                      • #56
                        Wide Bandwidth High Voltage Probes; Ignitron, Thyratron Drivers
                        I don't know if this type of device will work with cold electricity.
                        VIDBID
                        VIDBID
                        • #57
                          Matt
                          Thanks for the information. I have been looking for good instructions on how to build a Tesla coil.
                          William Reed
                          • #58
                            One thing that might account for the temperature decrease on the transformers' HV terminals is the fact that longitudinal magneto-dialectic electricity (cold electricity) is superluminal (faster than light,) according to Eric Dollard, and I speculate that that fact causes the temperature to decrease as a function of the load being presented across the two output terminals of the step down transformer. Because of the high voltage potentials present in the conductor between the two transformers, the energy (in the form of heat) from the atmosphere is drawn into the conductor and the HV-side terminals and is somehow converted to electrical energy.
                            Perhaps, the superluminal velocity of the longitudinal magneto-dialectic electricity (cold electricity) opens up some sort of domain into which heat energy from the environment can flow into, and there it combines or is converted into electricity which augments or enhances the electricity from the generator.
                            VIDBID
                            VIDBID
                            • #59
                              I had an idea of a simple experiment to see what the wave form of the McCulloch-type-of-generator produces.
                              You could take an old-style vinyl record on an old style turntable and glue a few magnets on the old-style vinyl record, that is, around its circumference and then place a coil or coils over in the following configuration. (See image below.) You could put a resistive load across the output of that coil or coils. You could connect a oscilloscope across that load, take pictures of the scope readings, and post them to this thread.
                              VIDBID
                              VIDBID
                              • #60
                                VIDBID
                                This video show how to build a device the outputs cold electricity, i.e., electricity from collapsing coils:
                                Code:
                                https://www.youtube.com/watch?v=dV-LRAUZ_AA
                                VIDBID
                                VIDBID
