What I have said is that passing magnets over coil produce the "h" wave impulse as pointed out by John Bedini. Welcome to "Energy from the Vacuum"
You have said a lot more than that and chose to gloss over what you put into black and white....it's your call. We are each and all of us allowed our own delusions.
You didn't do your homework so I will see you after class
It's Okayyou will end up with extra credit.
I've seen some cute waveforms.... first and third.... first and inverted third... harmonics so strong they turn into square waves. I never got an extra watt out them. You think I'm behind the curve yet you are unable or unwilling to enlighten me.
It's all good, but I will be back around in a few months to ask for my extra credit when the Gerard techs end up in the crap pile with QEG. I hope I'm wrong. But I'm not. Good luck.
You have made unsubstantiated claims of free energy. I am weary of light bulb wizards and their carnival barkers.
I see now that you were just speaking with "Optimism", and that is all you have. So now I move on back to my own research and leave you to yours.
You seem intent on "coloring" people with doubts or questions as being beginners unworthy of your time or explanation.
You speak with a condescending tone.
That is simply your personality and one that rubs me wrong.
You assume because I ask you a question to find out your opinion, that I do not already have the answer. You can live your life on based on assumptions; I prefer facts. That is why I ask questions and avoid assumptions.
Its been a while since I did but I did a great thing. I clicked "User CP" on the top bar. It take you to your preference page. On the left hand tool bar under "Settings & Options" You'll find the "Ignore List". I added "BroMikey"
To that list.
Since then, the forum has gained back its dignity and the feel of a group of adults congregating to discuss real material to experiment with. It was the best thing I have done in a year. I highly recommend it to anyone who is growing tired of the nonsense and babbling in over sized text.
Its like Aspirin on Saturday Morning.
The making of High Voltage electro-static energy on your desktop. The next phase will be to convert its High voltage down to a usable level. Free energy has been there for the taking.
Positive and Negative electrostatic generators and advanced experiments. Note the "N" and the "P" designating Positive and Negative. Just like in the Pole Pig experiment you have one transmitter and one receiver. A low voltage is stepped up to high voltage.
Found a new Gerard Morin video,
they are asking for ideas and seeking explanations. (Are't we all)
Thought we would share it with the forum. see if we can help him . . .
This is what he posted to YouTube after a visit with Gerard.
Originally posted by Christopher Sparkman
Published on Mar 3, 2015
Visit to British Columbia to meet with Gerard Morin to experiment and understand what he calls cold radiant energy. We try all of his previous experiments with similar or better results in addition the configuration you see in the video. The interesting thing is the effect the capacitors have on the output voltage. You can see in the video without the load we are drawing 144v from the output of the pump and with the entire load we actually increase in voltage? How is this possible? We have our postulations but please weigh in if you have some insight to whats going on. Free energy from the vacuum as Thomas Bearden talks about in his MEG description? Comment Please!! Also if you have questions about components or circuit diagram send me a message.
Hitby13kw
Great find
A big thank you to Hitby for finding this video. I see Gerard has hooked many large LED DIODES in series and series connected diodes show an increased voltage because they act as a multiplier. Now that is a lot of light.
Just guessing I would say his 24vdc motor is pulling about 3-4 amps at 36vdc so Gerard is running 120 watts of mechanical into a 100 watt magnet pump motor to generate. 6000 lumens is good because a 60 watt light bulb is only 800 lumens
As we can all see Gerard has been restored because someone cared enough to show up. Like John Bedini says "YOU CAN"T HOLD THIS STUFF INSIDE" you got to share it.
Van De Graaf machines yeap. Nothing like what Gerard Morins doing.
Where the van de graaf uses the dielectric belt to "peg" charge and carry it up to the isolated terminal sphere, the washing machine drain pump is just a 3600rpm motor being driven as a generator which outputs AC, not Electrostatic energy at all.
Watching the Vid below now. "adding magnets gives him an extra 120volts for free... " if thats the 120v 60hz mains motor, then thats saying he gets an extra 3600rpm for "free" just by adding magnets. I'd like to see the laser tach show that increase in RPM from just adding the magnets. (by the by assuming that this claim is right, hes only got 145volts or so on the motor, which implies that his drive motor is only about 3800-4000rpm .... )
I like the "free electrons going into the tube" of the high pressure sodium light. I'm not sure what to say about that vague comment.
So 20volt per led bulb, all connected in series, and he never notes the actual current draw on just a single bulb... whatever that current is is all the current that his "load" is using then... and its all just volts added up. Total of 5 floodlights so thats about 100volts DC rated in series at whatever unmeasured current.
I'm still not sure why he fails to account for Current. LED's are DC loads. The output from the drain pump is AC and prolly about 140hz.... so its higher frequency than normal going into each led bulb which internally will have a fwbr to take whatever is attached and funnel it in correct polarity to the LED to then emit light.
Someday he'll learn to account for the current and realize he needs both volts AND amps to get watts. If he does this, he'll see he is very much underunity. Its probably why he avoids doing this. Just the same, its what someone who wants the truth takes the time to learn how to do so they can know instead of make claims that they can't even substantiate due a lack of their own comprehension of basics.
All that said, I applaud the guy for Wanting to try... beats sitting on an ass watching the idiot box huh.
@Genessc – Congratulations on hitting 100 posts, like you, I haven’t said much in the past but with this project I felt we could do Gerard’s experiments and show both Voltage and current. Stay tuned.
@Turion - Looking forward to seeing results when your replication gets online. (and if they jive) Thanks again for your support helping to get us the McCulloch.
This was a surprise, but that is actually one of the biggest pleasures in research, when the unexpected happens. We were thinking that we would have a nice clean sinusoidal waveform, but in fact we have a sort of square wave with rounded corners.
In this video we start with a quick display of the scope showing voltage and current from the wall into a 100 Watt load. Then we show the generator running, power going through a big cord driving the same load and the waveform produced. Looking forward to everyones thoughts and input,
Originally Posted by Hitby13kw View Post
Just checked my stock, happen to have multiple 5, 10, 25, and 37.5 KVA pole pigs on hand - have a good workshop and time,
what I don't have is the Generator.
Don't have a 50 on hand, but with all the other sizes we could provide multiple input/output current/voltage readings - we have data logging equipment so it would be no trouble to provide raw data over any time domain you want investigated.
Hitby13kw
Hello HITBY
Hang in there and check out this thread. I am looking for Matt and Turion to communicate with us when they are ready. Please be patient.
I just got in late tonight at 12oc.
We will be also watching for a video of you at your shop.
Thank You. Also it will take some time to ready the McCulloch plus getting a hold of a 50kva Pole Pig.
Plan to power the Big Pole transformers next.
Hitby13kw
Awesome progress dude, you are the man for this job. I about fell out of my chair seeing all of the gadgets in your shop. We are in good hands
I am willing to bet you will be living out in the shop this summer. That shop is like being in wonderland for the serious minded genius.
That is a doggone square wave sorta like a ZVS driver circuit gives. That is incredibly Kool to have that scope shot. So, magnets passing coils have many variations on the output. This presents us with the need to calculate using different formulas because square waves are not sine waves and sine waves are not square waves, Hummm....
This could account for our reason, not being able to decide why this setup can go O.U without a mad scientist at the helm. now that is my kind of gitup.
Pretty decent transducer dude.
6/4 hey? nice wiring, you are the man all set and ready for action.
Did you use the flat ribbon winding? Wow, half square wave and half sine wave this can't be real, what does that mean? How can we look at this wave? I wonder if there is any ringing in it like an impulse wave.
Yes the weather broke today we are hitting 65 hitby I love warm weather, you get outside and stretch your legs, break out a BB grill and steaks. I did it today cooking up some good meat.
So now we know. We are sending a square wave into our Tesla Transformer low side, but what about HZ? Are we running at 60HZ? Maybe I better go back and see the video. Surely it must be designed to run 60hz so it runs appliances correctly.
Some have speculated that the HZ are anywhere from 50HZ on up to 200HZ. The thing about having a Genset that you run modern devices on, is that the system RPM is set to the proper cycles per second and based on that the Voltage is 120vac which in turn the Governor works to maintain this or it is adjusted to maintain a certain setting.
