Gerard Morin Energy
  • Hi All
    Just want post about my findings with the Rf pump set up . As I posted before that was an over unity device with proper parameters of impedence , upon further testing my setup is NOT OU. So maybe is my lack of understanding or ablitys but I can not obtain any better results . My previous measurements were in error which lead to my conclusions. I would hope that Gerard can give more info on RF pump or is maybe that is he did not mean to imply that it was . But was only demonstration of energy generation . If anyone else has measurements that conflict with mine please let me know as I am interested in how you got the results.
    Maybe Gerald can tell me where I go wrong in making the device .
    Thanks all.
    Jeff
    • Hi Majestic
      Thanks for the video of Marc doing the replication of Gerards pole
      transformer experiment. I did a search to see if I could find this video
      and Google is not showing up over here so we should all see the
      advantage of having others help find this stuff. I have seen Marc
      do video in the past. He calls it PART ONE.
      [VIDEO]https://www.youtube.com/watch?v=t6ucFJJGSmc[/VIDEO]
      Part one of gerards transformer experiment showing no overunity using a conventional field excited generator. This proves that the generator's rotor has to be a permanent magnet rotor to manifest aetheric electron channeling for the provision of overunity.
      Marc Belanger 2 days ago
      I've just watched this for the first time and learned the audio was not recorded for whatever reason. I will add captions, but, since the generator is a conventional generator, no overunity is found. The generator works by exciting a coil with it's own power, forming an ac waveform of approximately 60 hz (conventional power). Gerard's generator uses a permanent magnet rotor and it outputs a square wave with a high voltage spike (spike is cold electricity) at the leading edge of each wave, causing an abundance of additional energy which outputs 5 to 6 times overunity. The HV bushing here does not read a negative temperature reading, so, the channeled energy from the aether is not present as in his video. I will record part 2 and give all of the necessary readings to either prove or disprove the function, then, post it, but, before then, I will have to fix the audio issue I am experiencing. Thanks for watching.
      Joseph Richardson 1 day ago
      I like the level of detail you've provided. As far as using the temperature gun goes I might recommend two things. One is to put black paint on the area you intend to show a low temperature. Secondly, place another object painted with the same paint several inches away. The goal being to show the transformer is cold and the object several inches away is not. By doing it this way you hopefully remove electromagnetic interference with the temperature gun as being a distraction. There might still be interference but you would expect the interference to be equal between the transformer and the object several inches away. Another thing you might consider once you show a very cold temperature is to blow moist air onto the transformer to see if you get frost buildup.
      They make 20 dollar electric stoves you could put in a cooler with a pot of water w/lid on top. This would serve as a convenient backup to the electrical instrumentation that's showing power. The temperature change in the water can be converted to kilowatt hours.
      Marc Belanger 6 hours ago
      the bushing isn't showing interference because its the same temp. what I'm trying to show is that when the permanent magnet rotor is used for generation, it completes a channel of energy from the sky all the way down to the HV bushing, making the temp close to the same temperature. since the generator is using conventional alternating current, its not able to draw this energy in, making it below unity as our current electrical systems are right now.
      I also have to be sure the black paint has a high dielectric because black paint usually contains carbon and could cause immediate failure since the HV bushing would be compromised if we painted the insulator. I do have black rubber dip made b plasticoat which could serve the purpose.
      • Here is an incredible radiant response for the Gerard magnet
        Generator pump using a choke type toroid setting in water.
        This thing sounds like a welder. Then he moves the arc around
        to show what the normal spark looks like and back again.
        Truly a phenomenon that is drawing in the Aether.
        [VIDEO]https://www.youtube.com/watch?v=A1dRuOGoxcA[/VIDEO]
        • GEORGE CHANIOTAKIS
          Published on Aug 31, 2015
          This is a demonstration AC in to DC out, a experiment of an Electromagnetic Motor a newly Exceedingly high efficiency setup that it has very low resistance. Electromagnetic Attraction "dual contact" this is a idea I came up from a Permanent Magnet AC Motor (PMAC) "Gerard Morin AC Magnet Generator washing drain pump" and "Perpetual Motion Edward Leedskalnin Magnetic Currents"
          Lets Start to Breaking the law...https://www.youtube.com/watch?v=uGv4f...
          An electromagnet is a type of magnet in which the magnetic field is produced by an electric current. The magnetic field disappears when the current is turned off. Electromagnets usually consist of a large number of closely spaced turns of wire that create the magnetic field. The wire turns are often wound around a magnetic core made from a ferromagnetic or ferrimagnetic material such as iron; the magnetic core concentrates the magnetic flux and makes a more powerful magnet.
          The main advantage of an electromagnet over a permanent magnet is that the magnetic field can be quickly changed by controlling the amount of electric current in the winding. However, unlike a permanent magnet that needs no power, an electromagnet requires a continuous supply of current to maintain the magnetic field.
          Electromagnets are widely used as components of other electrical devices, such as motors, generators, relays, loudspeake...
          Amazing High Efficiency Motor 2
          [VIDEO]https://www.youtube.com/watch?v=Q1HqQduHrl4[/VIDEO]
          • Published on Apr 24, 2015
            We drive Pelex with a WASHER PUMP motor in reverse as a generator which drives a battery charger LOOPED to feed the source batteries successfully driving the circuit infinitely. FREE ENERGY's possible
            [VIDEO]https://www.youtube.com/watch?v=mB1Wtve7aug[/VIDEO]
            • Hey Gerard
              People all get sick right after a HV discharge into their bodies. This sick
              feeling comes from what is known as "DIE OFF" die off of toxins in the body.
              I hope you are doing okay. But everytime I get a poke off of 230vac
              I feel sluggish for a few days.
              Take care now.
              • Gerard Morin test bed
                [VIDEO]https://www.youtube.com/watch?v=w8PHL8lBYQw[/VIDEO]
                [VIDEO]https://www.youtube.com/watch?v=baDB1LXbaQU[/VIDEO]
                • Transformer Bushing
                  Hi Mark
                  Thanks for the offer to support our testing setups. So far we can not find many large units. One big one came available awhile back, but Gerard has shown us that removing the gasoline engine is a good idea.
                  Gerard has shown an electric motor powering the same McCulloch winds.
                  This will enable looping much easier.
                  Yes I agree make results openly, don't hide data. If we fail, post that, if we get it working post that. This is partly why we are in a holding pattern right now, because some of those who had made pledges have never been on good terms with one another partly because they want the data to be secret/private to only people who pay money into the project. I reject that idea.
                  So we can start our pledge all over again as far as I am concerned.
                  I do not like playing favorites either, thanks Mark
                  Anyway let us get down to business. We have determined from Gerard that the McCulloch winding is required. Also hitby is full Rock and Roll. The guys shop is full of industrial supplies.
                  I am sure like anyone Hiyby could do it all himself but we all need to work together and be able to provide materials. Separate test could be performed with version specific devices.
                  Like you say we could do tests with what Hitby already has but might need to get him a single phase pole pig the right size.
                  We all appreciate your encouraging post to add support when the time comes. Right now I am waiting to hear from people who can actively participate in this thread. People who don't speak to one another are not interested in working toward a common goal.
                  I learned along time ago that people say one thing and do another so waiting is an important part of any fulfilled accomplishment. I know that soon we will hear from more men who have something to say and they will be heard.
                  Tests should be made in an exhaustive way and Hitby is a master.
                  As far as you spending money for new ones we thank you for this.
                  However I have found these exact units for hundreds of dollars each while new ones might cost thousands.
                  I can get things for less that are fully functional for these tests and will make sure that the quality is good. I called the local power company here and talked to the big guys They enjoy a good experiment too.
                  Anyway Mark let me find a big winding for openers and I will continue to address the group to see who wants to put out the money for each piece of the bigger puzzle.
                  Mikey
                  Hello,
                  I am new to posting here on Energeticforum, but, not new to these tests and experiments. I have recreated the pole pig test, and I do have access to the transformers used in Gerards test. BroMikey has already commented and asked some questions related to speaking about the tests here.
                  I have recreated the first half of the test... This is by powering the transformers with a conventional generator, and, single bushing transformers. Just to clarify, the transformers he used have single HV bushings, it is not any different from a 2 bushing other than the fact that the second bushing is not tied to the tank instead of offering a single bushing, where the other end of the coil is merely tied to the tank for it's return. The secondary also has one bushing tied to the tank if you want externally, which is the center tap, and, since you think the two are much different, internally they are not. The two bushings would just be tied together to recreate the test, however, we would have to ensure they are the same way as not to invert the polarity since we are not using a sinewave to power these with the McCulloch generator as it gives a square wave output like Gerard's washer pump motor does.
                  The sinewave will not give the overunity as the squarewave and that is because the leading edge of the square wave has a spike attached to it. This is the cold electricity that literally allows the transformer to transform otherwise we would only get a massive humming and rattling from the core. The McCulloch generator is isolated from ground, and, the center tap could be connected or disconnected from the can, it really doesn't matter, however, I am finding that I get way more overunity without the center tap connected, but, voltages are all over the place when this is disconnected.
                  I am having trouble with the engine on my McCulloch generator, so, I will need some assistance with connecting an electric motor to the shaft and I need some info as what kind of lovejoy coupling will mate the two shafts. Once i find out if this is tapered or not, I will post it so I could try to loop the system to see if it is effective and post to the tube for all the skeptics to eat a fat one. I hate when they only run their lips when they can't or won't recreate these experiments as we do , spending our hard earned cash to find out if and when something does work or not. I post it to youtube and all they do is write garbage to contradict anything we say.
                  I have come up with a circuit that allows me to ground the output and i will be posting the circuit functional so the output has a legal NEC ground , this way I am not operating illegally in any way. I have used a case from an old hv electrical switch to cover the transformers so it could be grounded to eliminate injuries or death to people coming into my property , touching the transformers, and, it'll be great once this is all operational so i could show the world that the laws of physics really do have some missing formulas, and those are the ones that Maxwell had originally written and Lorenz deleted only to have his non ovrunity equations published, just as JP Morgan wished so his lucrative electrical grid's income was not defeated by Mr. tesla.
                  I feel Tesla knew this was going to be a functional device as my idea was always based upon his works, and, Gerard has told me directly that he has shown us only what Tesla has given us, it just took some understanding of what it actually is Tesla was trying to say about the waves we are drawing in.
                  It isn't hard to understand, it just takes a bit for somebody to explain it properly, which i will say in my video so i don't have to write 400 sentences down here for all to see.
                  Good Luck, I am well on my way!
                  Marc
                  • unifarads? WTF!!
                    those are microfarads buddy, not unifarads..
                    • zap
                      Hey Gerard
                      Take care now.
                      From years of HV discharges, I guess there isn't any more bacteria to kill.. LOL Been getting hit for 21 years with hv discharges on HV cable. When cable is tested, or energized, then de-energized to work on, I have forgotten to ground the cable after safely identifying the correct cable, then, got into the center conductor to find I have just discharged 5 miles of 500 mcm 15kV cable as the charge remains in the cable until one grabs it. Whoa, I'll never forget the time at Yale university when my eyes went all white, then I was looking to see if my hands were still there.. Phew, it was all good, the bolt of lightning exited my shoulder and eyesight came back. Everybody above the manhole yelled to see if I was ok. It took a few seconds for me to even talk. Got the **** blasted out of me, but, never got sick from the die off. I must have been cleaned up from the previous blast!
                      • Hi Marc
                        Pretty funny on the shock you got. I always remember that story
                        about the old guy who got hit by lightening and he got really
                        sick but, several months went by and he got better. His hair
                        changed color from white to dark hair like when he was very
                        young. His strength shot out of sight.
                        Glad to see someone doing the work. I am not sure if the shafts
                        are tapered but HITBY13KW will be around soon and when he chimes
                        in he can tell you. A few of us here on the forum bought him a used
                        3300 watt McCulloch and the first thing he did was to pull it all apart.
                        I have a break down somewhere if I can find it but I doubt it shows
                        that detail.
                        I am looking forward to your wise input on this system. Did I hear you
                        right? You got overunity? Last I heard in your video that it wasn't OU.
                        Did you do something different since your last video?
                        Either way Marc, I really enjoy your delivery and keep up the fine job.
                        • Re: Where is the evidence for this? look in past posts
                          Originally posted by citfta
                          Where is the evidence that the McCullock generator puts out a square wave? Does someone have a scope shot of this or is this more fantasy belief? I do NOT believe it is possible to get a square wave signal from a mechanical generator.
                          Citfta You ask a good question, I had the same thoughts as you about mechanical generators and was most surprised by the output of the McCullock generator, so a look at it with a scope was one of the first things done.
                          It wasn't a nice sharp square wave, but it wasn't a smooth sine wave either . . .
                          [VIDEO]https://www.youtube.com/watch?v=xcUDEHna7CM[/VIDEO]
                          Christopher Sparkman got a nice square wave with his pump motor
                          [VIDEO]https://www.youtube.com/watch?v=dLvZd5sBKZw[/VIDEO]
                          Breakzeitgeist was the first person I saw publish a square wave from his pump motor ( back on 12/14 )
                          [VIDEO]https://www.youtube.com/watch?v=Lq1ZNlmIsDk[/VIDEO]
                          The field of a magnet moving past a coil has to increase in strength and then decrease in strength. It does NOT suddenly turn on and then turn off. And instant turn on and off is what you have to have to get a square wave generated. More garbage added to a thread that is already full of misinformation.
                          For the most part, people seem to honestly share what they find as we all try to increase our understanding of truth, if any given nugget of information is either behind or ahead of your current understanding you may find it unsettling, but feel free to disregard it and move on to the next bit of useless data. It's all part of the charm of an open forum.
                          Hitby13kw
                          • Originally posted by Hitby13kw View Post
                            Hitby13kw
                            Hey dude
                            Good to see you battin a thousand as always. Oh boy I can't
                            hold it.
                            Did you see Marc's question about if the McCulloch had a tapered shaft?
                            He may have already tore it down, i don't know. Said he was waiting to
                            see how the break down looked so he didn't mess it up.
                            Either way maybe you might remember if you ever pulled the rotor off?
                            God Bless You HITBY and big double whammyGreat posting.
                            • Hey HITBY
                              here is what Marc is doing
                              Marc Belanger
                              9:58 PM
                              +Bro Mikey Hey Mikey,
                              I got the generator and freed up the seizure . so far it is very smooth spinning again. It sat so long that the gas tank was shot from internal rust, valve was plugged solid, so I replaced that , the carb needed rebuilding, and, after all that, I spun it over and no spark. I'm thinking the flywheel and the magneto are rusted up, but, when It seized, the spark was fine, so, since it worked, I am hoping it just needs to be derusted, magneto adjusted, and, there's also a makeshift shutoff switch added to the flywheel cover that may be grounding out the magneto, but, I have to disconnect it to osee what's going on with it tomorrow. Hopefully I'll get it all running after work and all will be well. I'll post the video links on Energeticforum. Thanks Bro Mikey for the interest. I have all sorts of test gear to use and try to prove what is happening between the very specific secondary winding and wire primary being wound around that with the dual steel layered core, during the resonant output voltage of the McCulloch. Much more happens with the generator when the ground is introduced on the other side of the load instead of a return. Nobody has tested this yet on Youtube, however, I have combined the ground and have successfully tested across to it with a massive difference in potential so far, but, I haven't transformed the voltage given from it's output yet to see if it has any ass. I used a small alternator PMG with an electric motor, and, because it wasn't axial flux driven, the input wave is only half of what is needed to create this effect. When I have the McCulloch running, I will show what I have come up with on the scope, I just have to make 100% sure the weather is clear because the channel it is induced through from the upper atmosphere becomes extremely conductive to high voltages. Lightning may not be one of the voltages we would like to attract to this, and by utilizing ground to gain potential as I have in the past, we just may do so burning up all i worked to get outputting more than we put in.. However, I am perfectly capable of making my own very tough core and easily making it function with this rotor, so, I just may take the chance, I just have to put some protective devices to work such as lightning arrestors, which i intend to connect the output of the center tap to the hot side of the lightning arrestor, and, ground to the other side with large porcelain insulators good for 400kV.. I do not want the path to be directly in line or close enough to the place the energy is channeled in from because It may be a bad mistake, ;like Gerard's capacitors installed between the hv bushings, the cap amplifies the voltage like a Marx Generator and it could be as destructive itself as lightning if any amperage close to 1/10th of an amp is initiated into the system. 15kV x .10 amps = 1500watts, if we boost the voltage like the Marx generator, we could increase this exponentially and create a scenario like this= 440kV x .10 amp= 44,000 watts . This would blow limbs off, and, the arc would blast around insulators through the dry air, giving an amplification of 30 times in amperage to keep it at .10 amps at 440kV . I have experienced a 50 times increase in voltage putting the correct capacitance with the Hairpin circuit, such a high voltage with near no amperage. Since the circuit is capable of cold electrical overunity, it is surely possible to do the unlikely, as physics equations certainly miss what is happening in this type of phenomenon. I wish I could calculate or i wish I knew what the calculations would be, but, we don't have a math system created for different energy or electrficity types yet. They aren'ty plausible to any engineer unless one , such as myself could prove this and earn the recreation by many college professors from places like Yale. If this is exponentially amplifying as i say, I will post every bit of it, every detail of how I acquired it, and then, i will be sure to get the scientists and electrical grid engineers I know to look at it and make comments after they are allowed to study it and measure things to credit or discredit me for my experiment. I completely agree with Gerard on all of his findings, but, I also understand what he means if he makes a slip up in his explanation, I have enough background in the field to see what one means. For people to say this stuff is impossible, they have to see the proof, or show the proof that it can't happen by correctly recreating the circuit. By us thinking he is correct in the original videos without seeing the HV bushing temperature reading and the sky's temp, we'd have to have our head's examined, however, the thermometer is the real deal, and, it doesn't do what his did with my conventional input. It will only do so with an axial flux permament magnet generator, that does not utilize a shunt winding.. These generators are extremely easy to build, and are used for wind systems all the time (usually 48 volt systems) . The system could only be 2 pole, but, it has to have a dual charge path, one opposite the other side so both the top and the bottom of the core gets the correct plus and - charge, not allowing this to get a true sinewave., it will actually be a dual inverse square wave , one wave basically on top of each other so the circuit oscillates instead of buzzing. This genset has always given good power output, however, it has not given a true sinewave as it is not possible being a 2 pole magnet generator. The magnet generaator like the washer pump is a square wave generator with a high voltage spike at the leading edge of the wave. if we take two inverted square wave outputs and inserted them into the same set of conductors, one over the top, we would have opposing polarities in one hot leg and one return. This is why we are getting a doubled input, and, it is another reason why this style generator is not sold to civilians any longer since it has been known to create an aetheric overunity by way of induced atmospheric energy in an ungrounded system. No other system has the ability to deliver this kind of energy anywhere on the planet, and, we now have to all figure out the safest way to use it. I am on my way to doing so, but, after I prove this, I'd like to speak about it with a few free energy experts such as Sterling Allen (and others, such as Tom Bearden, Eric Dollard, John Bedini, Peter Lindemann, and Aaron Murakami) The reason I say this is because I may be wrong in my interpretations of the phenomenon, however, there is some sort of connection between the transformer's bushing temperature and what the sky's temperature is. This isn't a coincidence, but, there is a very important informational tie between the two since it won't do this with conventional electricity. The experiment also does prove that there is an entirely different type of electricity out there than what science believes, and, it is not static electricity, nor amperage driven current.
                              I do not care for skepticism, so, during any interview, whether online, or offline in person live, in attendance, if there are people who badger or try to pry something other than the truth out of me while being interviewed The interview will be over instantly and that will be that. I don't mind honest questions, I just expect them to be asked respectfully as i can't stand sarcasm. There is always somebody around to negatively bash a project. This is one of the reasons why I have been very thorough with my R&D and show that the experiments are done with different test subjects, such as power inputs, utilizing normal generators, to ensure the conventional methods will not work to power these systems having overunity, and non conventional systems to prove they can successfully provide overunity...
                              We need research specialists to jump in to assist with my research, and those would be people that know transformers , inductors, design of cores for transformers, and, have engineering and physics background to assist with the mathematics we need to modify for cold electricity so we have all of the correct math, test data, and, related best available test equipment calibrated correctly for this to be proven successfully. There are too many people who want to see the correct devices being used and I only have some of the equipment. My professional equipment was designed for High Voltage systems, and, I unfortunatelty can not read directly wired current from a high voltage system without a $3500 current transformer system that's used to monitor troubled HV systems and the correct dielectric oinsulators, braces, bakelite switchgear insulators, etc. I do have line hardware , dead ends, and porcelain insulators to assist, just not the correct instrumentation other than low voltage metering that is only designed for conventional power. These devices will NOT be accurate for cold electricity as it works oppositely for resistance, so, the entire "electricity type" needs to be studied and equations need to be created or modified specifically so meters/instrumentation could be calibrated or manufactured accordingly to give us accurate readings.
                              Add a comment...
                              • Status of Marc Belanger
                                Bro, Thanks for the update on Marc, we have been wondering how he is doing since he introduced his PELEX looping.
                                Even his earlier disclosure seemed to be inundated with trolls
                                [VIDEO]https://www.youtube.com/watch?v=uIk_24tOAf4[/VIDEO]
                                There are Three paths that lead to Knowledge
                                • The Path of Thinking is the Most Noble Way
                                • The Path of Experience is the Most Bitter path
                                • The Path of Imitation is the Easiest & most Fragile
                                This unfortunately seems to be the only path people of today want to walk, they will follow, but have lost the ability to take responsibility and think independently.
                                We would love to be able to help him in his research, and we could in turn use a sharp mind such as his to look over my work (perhaps we have been underground for to long)
                                The motor shaft on my McCulloch was drilled an Tapped, it was NOT tapered.
                                With bucking coils and capacitors you can regulate the Muti kV spikes common with cold electricity and prevent runaway. We could help, many things are NOT the way of the text book.
                                You have my Blessing to give him my Skype name and number next time your connected.
                                Iamzpe
                                Blessings & Light to all
