Gerard Morin Energy
  • @BroMikey & hitby
    I'd only tend to use contact cleaner on expected power contacts. I'd tend to
    use non-flammable solvent liquids on wide area jobs. Mainly because of
    powder oxides may absorb fluids and dry slowly or other small reservoirs may
    retain fluids. I'd test the non-flammables to make sure they don't soften coil I
    insulation too much ahead of time.
    One should dedicate an hour engine testing time or so to make see how much
    oil the internal combustion engine uses. Excessive oil consumption is still
    usable but you can't ever let the engine run completely dry.
    I'm beginning to feel bad about the lack of precise energy metrics
    using internal combustion engines. but we do need to run these
    test first. Maybe other people might want to think about what we
    would need to do about replacing the ice engine with an electric
    motor. We have a second chance at OU doing a Qmogen with a
    lower powered electric prime mover.
    Also to newbies;
    These transformers like all other device have manufactures specification
    sheets showing all the options. I suspect no one of us wants to admit we are gringoes
    at power electronics enough to ask for them - they will vary between manufactures.
    Also the nameplates on the transformers are heavy duty - strictly useful information
    for determining if you've got a 25Kvar 14.4KVAC capacitor vs. a transformer.
    :S:MarkSCoffman
    • Answering the basic question for the DIY
      Let me start by addressing Mark and Hitby
      You guys are making some very valid points and I want to say this is
      the proper way to help all of us DIY guys. A definite thumbs up.
      This is good because each of us have our regular jobs and in order to
      proceed in our quest for doing the impossible, we must do a dress rehearsal.
      Okay having said that I didn't know some things so I went looking for the
      answers. This takes effort and some may not know what to look for. I found
      that there are many types of sprays on the market today as Mark has
      suggested using, in the event we need to clean electrical windings and I agreed.
      However in our case it looks like that the Mite E Lite winding is coated with
      resins, take a look at this one by McCulloch. I am not surprised. It looking
      like these windings could run in a rain storm and not short out.
      One less thing to do.
      After this post I will submit 2 more dealing with transformer issues. BRB
      • Transformers on Poles
        If you are desiring to do the Gerard Pole Pig experiments in the purist form do not buy used transformers with double high voltage insulators as shown below.
        Also the big reason I am making this post is to point out the wrong way. You may do it this way at your own risk but we want to start with Gerard's setup and this is not his instruction.
        DO NOT USE.
        I have known all of this for years but not working with this stuff everyday I needed to revert back on my master set of encyclopedia.
        I was rusty. DO NOT USE THREE PHASE FOR GERARDS TEST.
        Here are some diagrams that show possible 3 pig connects to form either a WYE or DELTA circuit for three phase operation.
        You will note the circles are individual pole pigs and each one connected in some way to the others to form some kind of a circuit. Many versions exist. H1 and H2 are high Voltage connectors at the top of each circle.
        The main consideration here is that you can see how the high voltage double insulators are connected,
        One more post for finding the right pole pig transformers. BRB
        • Single Insulator Pigs only
          Here we can see a more simple set of diagrams that we will be using.
          If you are desiring to do Gerard's pole pig transformer experiments, then
          you need to look for this type of unit.
          This transformer is all by itself having only one insulator at the top side.
          Next we will have a look inside.
          Look at the top of the circle at the H1 and H2 high voltage legs. one of
          them is missing now as compared to the double insulator units.
          This is because it is connected to neutral case ground or earth ground
          so the ceramic piece is gone. Look at the dots on the circle and follow
          the connection path.
          Much of what is on the web is missing and unless you already know this
          stuff you better stick with us.
          Thank you for your time in reviewing our materials on how
          to DIY experimenting and in this case Gerard Morin is our focus.
          Here are a few extra's
          Look at the "N" marked on the side half way down, This is the neutral
          and the other connection to the H1 or the High Voltage terminal.
          The lower insulator is a safety device not part of the windings layout.
          • Replication
            All,
            I have managed to come up with two of the McCullouch generators. I will be taking the larger one into the machine shop next week to see if we can get the gas engine removed and a 120 volt AC motor in its place. This will make it very easy to see if the system actually puts out more power than it takes to run
            I will be picking up two of the pole pigs (brand new) from a local dealer a week from this Friday when I get the check for the sale of my house. It will probably be a week after that, if not longer, before I can get enough stuff organized in my NEW shop to do any experiments. I am working as fast as I possibly can to get the shop organized, but there is just a lot of stuff stacked all over the place out there, and I want it organized before I embark on any more experiments. I have enough of them going on all over the place right now.
            I just wanted to update you with what I am doing to contribute to the effort. I have been footing the bill for all of this, which is why I have not volunteered to contribute any money to the effort, even though I said I was good for $100. Whether I am the 1st to replicate of the 5th to replicate, I will still be replicating.
            • Replicating Fast
              This is great to know we are going to have 2 examples of Gerard's work ASAP within months we could start comparing results. The mini experiment keeps going through my mind of KURT'S two oil filled car ignition coils. It is similar to this.
              This is the combination of two forces, bipolar genset winding phasing energy sent to be stepped up producing a high voltage electrostatic field for harvesting O.U. on the step down side.
              I have talked to Hitby for hours on this and he thought of some additions for interfacing Gerards system with an average house grid supply. 4000-6000 watts coming from our mock up should be plenty of juice to to give us some kind of indication before tuning to maximize.
              Thanks-A-Million Turion for your donation of $100. I will mark you down for when the time is right, of course right now we are moving to slow trying to acquire the needed components.
              So far we have $200 counting your offer and this is much appreciated.
              I have cracked a few tapered shaft unions with small engines. Naturally you want to soak them with oil, also a brass post to strike the portions of the shaft area visible can be gently struck as you rotate.
              Then as one other has suggested you can carefully fit grease rags and grease around a tool that fits into the opening to use hydraulic forces.
              If you have never scene this or done it you will need help.
              If the tapered union is struck to hard it will wobble later.
              Let us know about your new genset when you can. I know you have been on the run. Still fighting for the answers
              Mikey
              All,
              • Mini Pole Pigs with high COP
                Look at this video from an excellent researcher. Kurt has given his all to thousands of circuits with video to prove it.
                Here you can see the very same type of transformer as the line pole transformers. They are in oil, step up to produce electrostatic energies and back down again.
                So of you have not watched Kurt, I have. Kurt has embarrassed the entire global university level higher learning departments with his very simple experiments.
                In this video take note first to the darlington pair, meaning one NPN transistor and one PNP transistor working together to pulse voltage to his first mini pole pig.
                So why am I saying that? Because the oscillating set of semiconductors are in the place of the McCulloch. The McCulloch barium ferrite magneto bi-polar genset windings function similarly.
                Now, look at the meter. What do you see? What did Kurt say the voltage was? What is Kurt powering? How much in and how much out? Aren't these the right questions?
                Answer.
                Look at the 4 Lights. These are brighter than they normally would be running on dead electricity, in the first video. You don't know this because you didn't watch Kurt's video's yet so I will provide you with what you need.
                Looking at the meter showing about 50ma maybe, something so small about the needle thickness at 24vdc from the two batteries. Kurt is saying less so I am over estimating.
                Yet Kurt is driving 4 lights rated at 3 watts each for a total of at least a 12 watt output. Yet his input is phenomenally small.
                How much is the input?
                24 or 25vdc most likely coming from Kurt's two batteries times amperage looks like this.
                25 X .050 amps = 1.2 watts
                Wow that is a huge COP of at least 10X yet Kurt is reporting as high as 50X.
                These experiments are very real and show how the larger pole pigs could actually provide enough useable current for an average home.
                The second video is thrown in to show it running the mini pigs on 12vdc and plus he talks about the lights and their ratings for his load. Plus he pulls the battery and loops it so it just runs on and runs on with no power source.
                This is called ringing down as the looping energy going around the system being recycled many times slowly diminishes. Yet it is without a power source other than a cap to capture and resend energy.
                I must be a weirdo because i get greatly encouraged with that test.
                https://www.youtube.com/watch?v=QoYDbHhbaNY
                https://www.youtube.com/watch?v=pDXKnk9hFMI
                • BroMikey,
                  You have a right to be encouraged.
                  Here is a simpler one; The Imhotep emergency lamp:
                  https://www.youtube.com/watch?v=EPoJ9gCk2Rk
                  If you wanted 1200W you would only need to build one hundred of them.
                  So this project is much more practical, if it works. It's active region
                  is only one meter long, easy to protect. Also if you tune it away from 60Hz.
                  frequency it will be easily claimed to not be intercepting utility power.
                  Since the transformers are only being lightly loaded it should last forever.
                  :S:MarkSCoffman
                  • Morse taper shaft adapter.
                    Web link show and tell about a morse tapered cone shaft adapter.
                    A Free DIYer Generator Head? | UtterPower.com
                    Any electric motor would give a good energy readout mechanism.
                    But if one wants to try for high efficiency self running motor generator
                    one may want to try a selection of drive motors.
                    :S:MarkSCoffman
                    • kdkinen videos
                      BroMikey,
                      Thanks for calling our attention to Kurt’s Radiant Oscillator Circuit, I remember replicating his work a few years ago with auto ignition coils from a scrapyard. The Series he created was very good and relevant to what we are doing today;
                      Radiant Oscillator Circuit: 0 Amps @ 12 Volts= Huge Light? Part 1/
                      Radiant Oscillator Circuit: 0 Amps @ 12 Volts = Huge Light Part 2/
                      Radiant Oscillator Circuit: 3 Watt Bulb & Proof of Operating Meter Part 3/
                      Radiant Oscillator Circuit: Running on Capacitors Alone Part 4/
                      Radiant Oscillator Circuit / Don Smith Amps X 12 volts =12 Watts ? Part 5/
                      Radiant Oscillator Circuit / Don Smith Part 6: C.O.P = 50?
                      Radiant Oscillator Circuit / Don Smith Part 7 A: One Minute Run Time WITH Circuit 1 Farad Capacitor
                      Radiant Oscillator Circuit / Don Smith Part 7 B: One Minute Run Time NO Circuit 1 Farad Capacitor
                      Radiant Oscillator Circuit Part 8: Digital Meter Reading
                      For a better schematic of this see Replication Imhotep Radiant CFL Oscillator and Self-feeding?? Part 3 with new SCHEMATIC
                      The most significant bit of information is the added text from part 6 @ 5:34, but all of it is good work.
                      With our replication of Gerard’s Pole transformers, of course our plan is to tickle the first transformer with the McCulloch generator instead of his Darlington transistor pair, but there is data to be learned from others work.
                      Hitby13kw
                      • Radiant
                        Originally posted by mscoffman View Post
                        BroMikey,
                        :S:MarkSCoffman
                        Yes I missed that video after all these years. Glad to see it. We really should be grateful for all the work Aaron has done with Peter Lindemann and John Bedini.
                        All of these experiments are off shoots. This work is finally blossoming. I have noticed that when people find a slight variation of an invention based on THIS WEBSITE and all of the LEADERS here, they run off and do not give credit where credit it due.
                        It really is a shame. These guys like Aaron and his pal's who run the show around here have worked hard for pennies for many years.
                        I hope we can somehow make up for lost time. At least give them credit.
                        I noticed the video did that.
                        I heard he got it to run forever.
                        I have a battery in GENMODE right now, since last night on one strand of my big coil. Nothing compares to radiant energy, it is the good stuff.
                        I run lights off the stuff and it looks far better.
                        I wind my own coils like Lasersaber does. I have one big E-core with more wire mass made into a ringer that, when you shut it off it keeps going for a few minutes. I didn't even plan it that way but after making enough of these gadgets I see why.
                        I will sit and play for hours/days with one single transistor. That is the only way to learn the new tech.
                        Mikey
                        • Nice line up of video's, I think these are a must.
                          I just got an email from New York and that McCulloch is snowed under in his shed. He is still working to find his driveway. He is using a snow blower today he tells me.
                          I told him no problem and that we were sitting in the sun at around 70 degrees. I use to live in Detroit, no thank you. The weather in the northeast can be grueling.
                          I think he likes your new shipping address better.
                          Let me go through all these video's, I gotta make sure I didn't miss any gold nuggets
                          When I strike a new find I always seem to freak out and all excited with everyone looking around at me like "What's with him"??
                          Mikey
                          Originally posted by Hitby13kw View Post
                          BroMikey,
                          Hitby13kw
                          • Genset Shipping
                            So far we have a pledge of $200 after restarting our test group. This group has specified that results would be made public.
                            Also Mark has opted to fund this project as well.
                            The man with the Genset "David" has gotten a ball park shipping figure. FEDX, UPS, USPS ground. David got out of the snow and made some calls around town.
                            He is way up in the north east and the genset needs to go clear across the entire continental USA.
                            One price is $380, another is $350, another is $230 if he buys a pallet, wraps it with $20 worth of clear plastic shrink plus drives it many miles to a special location. That way David will need to be paid as well so it sounds like the high cost of living.
                            David did say it was only a guess because the shipping companies were only quoting for a pallet sized item but said it could be less and he would send the extra money back.
                            Let me know what you guys think of David's phone calls around town for shipping estimates.
                            Mikey
                            • Project Genset
                              Okay David weighted the Genset and now the shipping quote has dropped to $200. It does not need to be on a pallet.
                              Also I am not sure where this project will be conducted til I reach an understanding with all interested parties.
                              Compliance with what I specify as a test will have to be complete.
                              We are not going to set up an experiment and guess what has been tested or not. Active concern about what I want in the test is very important.
                              Hiyby has a lot going right now and we don't hear to much from him about his willingness to perform exact tests. Salvaged transformers that are not in someway approved by transformer specialist would be considered unknowns.
                              Thank you for your Time.
                              Michael Rowland (Central Kansas)
                              • See Attachment
