Gerard Morin Energy
  • Free energy school
    Cold electricity schooling
    https://www.youtube.com/watch?v=rT6MTNNIBMk
    • Motor Generator demonstration.
      Showing the generator collecting power while the motor is running
      on a tiny input, with no increase in power consumption.
      https://www.youtube.com/watch?v=Ari2MPdpscc
      • Magnet motor generator looped investors only
        Large pancake motor/Gen just like Gerard.
        https://www.youtube.com/watch?v=2M89QnJaPY8
        • Big corporation uses very large pancake motors and generators
          to loop their systems for free power.
          https://www.youtube.com/watch?v=y6q_l6FpacU
          • someone sent me this video.. I am trying to get a hold of Kirkwood.
            He appears to speaking the exact language that I am... similar conclusions and effects. As well as what I've always said. We need new instruments to read this type of output.
            https://youtu.be/h2V_rygJ738
            Description
            ● Kirkwood: Semiconductor industry expert that the PHDs go and see when they dont know what is going on. Kirkwood has designed specialist methodology and apparatus necessary to validate "gain of a system" and to find a way to promote accurate metrology in measurement.
            ○ Video of working with Kirkwood (YouTube...) testing the Abha coil at his home where he keeps the most incredible old analog gear for testing.
            • Originally posted by Gerard_Morin View Post
              I knew I picked a winner,
              you are a winner Gerard. It is like some
              people know when they are betting on a good horse
              You have my full attention Gerard. We are all right in there
              with you all of the way.
              I don't know jack about this pancake motor when it comes
              to OU but if John Bedini built one it can't be wrong. Basically
              when we look at many of the great big pancake motors I have
              always had a gut feeling about the mechanical advantage in
              torque plus the added mass for the flywheel effect.
              Then the easy of access of coils to replace during normal
              maintain programs as well as experimentation.
              Our standard conventional motors do not permit easy access
              to coils and winding connections.
              Also i saw a Bedini Ferris Wheel magnet were shaped this same
              way with the slight arc inwardly called concave. There is
              something special about this short arc in the magnets that
              improve efficiency. Bedini puts two more magnets behind those.
              Just another work horse sort of a day HEY GERARD? I can tell
              you have always worked hard for what you have earned. That is
              the way it is for honest men.
              You may have your moments Gerard where you go off the
              deep end But who don't???? When you start weighting
              it all out so many people care nothing for the other man and
              as you pointed out this makes it an uphill push all of the way
              with the weight of 100 years of dinkweed pencil pushers, with
              a close pin on their nose, saying "IT CAN"T BE DONE"
              No matter, it won't stop you.
              Just keep at these guys and you will get what you need.
              They tell us that work work work is the only way to understand
              this new tech. I think this is the right way too.
              What grinds me the most is when one man looks at his work
              as if it is worth $20,000 per day and that same one man
              looks at another's work digging sheet in the chicken pen
              only worth $40 per day. Beat the slaves and bury them fast.
              Keep after those pencil pushers and hope for the best.
              I am digging up the smart drive data and experiments.
              I am counting on you Gerard
              BroMikey
              • 2.5 hours into the video research replication
                verification is good stuff. This sharing of experimentation
                live is wonderful. A perfect example of how one man is
                getting 3X COP and does not know how to explain
                everything while the other man can shut everyone's
                mouth who is a professing high level engineer.
                • Kirkwood is showing a blocking oscillator that has a waveform that looks pretty close to the Bedini SG which was an oscillator that would charge caps to voltages much higher than the source voltage.
                  Kirkwood is using the named references correctly, versus you're all over the place buzzword commentary. You might learn something from him if you can empty your cup. (or not, whatever at this point.)
                  It IS a good vid from Kirkwood... plainly spoken.
                  Cheers.
                  Gene
                  • Kirkwood talked out of the corner of his mouth in the
                    background so as not to be heard by the man on the other
                    end of the phone because he thought the guy was in complete
                    confusion about his OU.
                    Kirkwood didn't want to come right out and say that so he
                    said that to the men on his side of the phone only.
                    Basically the man who claimed OU was told his meters
                    were not working so KIRKWOOD proceeded to put out
                    one large analog meter after another only suited from
                    a given range.
                    Also Kirkwood talked about phase angle such as we see
                    engineers use to calculate the COS PHASE ANGLE for
                    power conditioning.
                    So Kirkwood said it is not OU.
                    Then Kirkwood said he does not have OU either. Kirkwood
                    said his conical coils were high efficiency but still no OU.
                    Kirkwood is still searching for OU and does not understand
                    it yet, so he says.
                    Kirkwood claims he is looking for OU and this is the purpose
                    of the phone interview to see if he can find someone
                    with any kind of legit OU experiment.
                    Kirkwood talked about his credentials that made walking
                    on the moon look like a piece of cake. Kirkwood thinks he
                    is the best choice for judging an OU project because of
                    his knoweldge.
                    Kirkwood is good at rolling his eyes and walking off to prevent
                    direct confrontation when he takes a measurement and it
                    does not look like OU to him.
                    Also told the caller he would have to fly him over in a jet
                    to verifiy his work jokingly as way of mocking him.
                    The caller left in disgust at the end and KIRKWOOD could
                    not give the caller any answers why the meters did not read
                    properly in some cases. Only that meters are the problem
                    and OU is not there. The caller ended kindly but you could
                    tell he wasn't being heard. I mean Kirkwood wants to use
                    failure for OU but the same meter reports UNDERUNITY and
                    that is the reading he excepts. Picking and choosing
                    which read fits his schooling.
                    Bottom-line everyone wants to judge OU projecting but the
                    same people can not get OU either.
                    That makes no sense at all and anyone who is an engineer
                    should know this.
                    Telsa got OU, Bedini gets OU, and many others so thinking
                    that this Kirkwood is a good choice to judge OU, when
                    he can't get OU himself is confusing to me.
                    And as far as emptying out one's cup so as to fill it
                    with Kirkwoods knowledge base would only give them the
                    same empty cup most searcher have today.
                    The only good judge is someone who has a confirmed
                    successfully operating OU device and even then there are
                    more OU collection possibilities that no one man can
                    understand them all.
                    Kirkwood is good for the university grad's who think like
                    he does. Meter failure, measurement failure, calculation
                    imperfection. Kirkwood thinks he has seen OU and hopes
                    to find OU as he continues his quest.
                    Who knows at his age he may find OU in the next 20 years
                    without signing any non-disclosure agreements. "NDA"
                    But Kirkwood doesn't have anything other than his school
                    training.
                    • citfta
                      A little Christian morality lesson in the morning is a great way to start the day!
                      I have gone down a similar path with Mikey before (excluding the Christianity angle) and just concluded that he is a light heart, fleet footed character. Is that wrong? It might be wrong for you and your style - but less dogmatic characters can be closer to new possibilities than others that are deeply rooted in traditional dogma.
                      So like all things, I have chosen to see the light of possibilities with Mr. Mikey, now his presence/style doesn't aggravate me in the least. Maybe you could adopt the same?
                      The greatest potential for innovation, still resides in the counter-intuitive.
                      • Originally posted by DavidE View Post
                        citfta
                        Thanks David
                        You are a very wise man and most of all the thing I would
                        like to say to other folks is that they shouldn't wear their
                        feelings around their shirt collars.
                        @snoppy
                        I am not interested in quibbling over who thinks they are
                        the best Christian. Or who is the bigger sinner for that matter.
                        Now back to @ DavidE and all
                        Gerard speaks more than one language and his English is okay
                        but Gearard can not see everything that I DO. I am here to
                        help Gerard and Gerard knows that. What little I can offer
                        I give freely.
                        It is true that in conventional university terms I have never
                        allowed their dogma to take it's deep rooted path and if
                        that means I look stupid to the University High Dogs? Then
                        so be it. Keep in mind that when I post a smile like this
                        it is because I am really smiling.
                        I look at the overall attitude of people and have a way about
                        my speech that draws out the Rif Raf, it is a dirty job. It is
                        better this way so i don't get stabbed in the back.
                        Front and center always ready.
                        Gerard you don't have to worry, you know that. Certain
                        folks love to start trouble. I am what would be Gerards sons
                        age group and Gerard missed some things about Kirkwood.
                        Kirkwood is a good choice to go to for those who really do
                        have an OU device IF IT CAN BE LOOPED.
                        Otherwise Kirkwood will just wish it away. Bad meter readings
                        and so on. I am not on anyone person side. It is the collective
                        that shall prevail so those of you who are always right and
                        know everything all of the time "GOOD LUCK WITH THAT"
                        Thanks DavidE for your kind heart. You are another sweet
                        person just like Gerard.
                        • Originally posted by ldrancer View Post
                          so, if electric is really, rf, then whats ac, and dc?
                          I just caught this by looking a couple of pages back. So, I'll respond to it.
                          Electricity isn't RF.
                          RF is in reference to frequency, not of electricity as in Alternating Current (AC), but of magnetic wave motion. It however is the motion of the magnetic wave that will cause the generation of electric current.
                          The spinning magnet in the pump motor creates an alternating magnetic wave form relative to the wires that make up the coils in the pump. Thus AC current is generated at a corresponding frequency. But, the magnetic wave doesn't stop there. It continues to be detectable from some distance away given the right pickup equipment.
                          • Motor bike conversion, Good one Gerard.
                            https://www.youtube.com/watch?v=JOIkp-23dYs
                            • Here is Lasersabers motor generator
                              https://www.youtube.com/watch?v=43lxNJjIKD8
                              • powerstrip loop free energy
                                I tried the free energy power strip loop but it didn't work with me I know it is a true thing how it works what I missed in my experiment in the power strip loop?
                                help.
                                thanks.
