Duality is a basic attribute of the universe. There are forces which cause differentials, and forces which equalize these differentials. Two separate properties of nature which use energy in opposite ways.
The trick is how to create a differential with less energy than it takes to equalize that differential.
For example: I can switch the flux of a powerful permanent magnet between two paths with far less energy than it takes to cut off the flow. You would think that a simple motor could be constructed with this principal (such as the Flynn motor claims to be). Not so easy! Yes you can switch the flux path, but unless you have a solid, continuous path (which is not the case where the armature is moving and not connected), the flux takes it's own sweet time about changing direction. It is a cascade effect, which happens very quickly in a solid path, but not so fast in a pathway with a variable permeability, such a motor gap. This causes all kinds of problems, since the faster the armature turns, the less effective the PM flux is.
These are the types of engineering hurdles we must solve in order to harness these energies. Theories are great, but a solid understanding of the nature of the energy, where it's coming from and how to tap into it is far more important.
The whole idea of the universe starting with "X" quanta of differentiated energy and slowly winding down to equilibrium is BS in my opinion. This type of thinking got us to where we are today. I think there is unlimited energy available, and only limited imaginations.
