hi mate. i think blocking osc. is where the magic can be found. i'm new to chris sykes stuff, but i like it a lot. from what i've read,elsewhere,it sounds a lot like when you light bulbs with what textbooks describe as an open circuit that is radiant energy and it means you have standing waves and the connection point/s is/are a current node.you are seeing cold electricity.a challenging process generally initiated with abrupt d.c switching events on the primary side, but being an assymetrical transformer, it could work the same or better when driven with sine waves. i read that chris is leaning towards ac sine input, but your blocking osc is delivering the goods anyway. see how far you go with that first. simple but effective is often the best way. if i got most of that right,then with a 3.5 v input your achievement is quite incredible. replicators out there are playing with thousands of volts to try and manifest the cold stuff. it's not hard to make an led glow off 1 wire with an av plug,but your putting out a fair bit of light there. if your results are replicatable, this could be the start of something big.
a variable resistor or trim pot to base would help to optomise the performance, unless you have already zeroed in on 220 ohms using one or the other.
like sputins suggested,after you have optimized it, make it permanent and presentable and maybe keep it in a display case or something.if it turns out to be a breakthrough project it should be kept intact and preserved. too many people have taken parts out of working projects and later they can't get it to work like before. you will build bigger and better ones and who knows, it could be a piece of history one day.
