A1Mo-Gen: Tesla's Gift "The Electromagnetic Reactor"
Here it is. Lifted unedited from UFO's thread.
It wasn't my intention to post further on this topic but I promised to wait a few days after my comments have been misrepresented.
I will not dilute my point by picking apart UFO's interpretation of what I have said and drawn on this topic. Suffice to say that interpretation is wrong.
I will reinforce what I have said firstly by thanking Jeffy for correctly stating my point and thereby assisting UFO in creating the 5 frame film strip. Which I agree with and this does represent what I have been saying.
And secondly I have uploaded another graphic to further reinforce the following paragraphs.
There are fixed parameters in our motors and there are variable parameters.
Fixed being -
1) Stator Bisectors
2) Comm Segment Width
3) Brush Width
4) Number of Poles and therefore Pole angle
5) Choice of Coil Structure (pairs or groups) establishes the Coil Bisector Angle. That is the angle between the first coil and final coil bisector
Variable being -
6) The 'sweep angle' or 'time on the brush' where the comm segment sweeps over the brush.
For Single Coil and First Coil Pairs or Groups, we set the bisector at 5° past the North Stator Bisector (NSB) as the 'ON' time. This means that ALL coil structures attached to that connected comm segment are also 'ON'.
For Pairs and Groups the Final Coil extends towards the South Stator Bisector (SSB) by an angle dependant on the chosen wind. For the image below I have used a Coil Bisector Angle of 120° which would represent a '4 Pole Pair' on a 12 Pole motor.
The discussion on this particular aspect of winding, for me, was to estimate when P2 coils are 'OFF' so as to avoid the P2 'ON' coils bisector being within 20° of the SSB or possibly even past the SSB. This scenario will cause a drop in efficiency of the chosen wind.
It becomes obvious when considering the mechanics of this, that one can consider the P2 'OFF' angle from when P1 just attaches to the brush, OR better still, just calculate it from the P1 'sweep angle' as it connects and disconnects from the brush.
It is clear that the angle of ONE comm segment 'sweeping the brush' is the angle that the Final Coil Bisector advances towards the SSB from connection to disconnection. There is only ONE SWEEP ANGLE for a motor and it is a direct function of the OEM motor given by the width of the comm segment and the brush width in degrees.
The image below, as before, indicates the comm segment is just 'ON' by 1° and 'sweeps' for 57° where it is 0° 'OFF'. It indicates where a Single Coil will be 'OFF' after 57° and it indicates where the Final Coil of a Pair or Group will be 'OFF' after 57°. For a 12 pole 4 pole Pair wind, we can see it passes the SSB and is unsatisfactory for 12 pole motors.
[IMG][/IMG]
Happy Hunting
mark
Originally posted by citfta View PostFor all practical purposes there is no delay in the flow of electricity from one end of the coil to the other end. The wire is not like a pipe where you put water into one end and have to wait for it to get to the other end. It is more like a pipe that is already full of water. So as soon as you put water in one end it pushes water out of the other end.
Originally posted by citfta View PostYour idea of winding a coil on the armature with one end being clockwise and the other end being counter clockwise will give a north pole on both sides when the proper polarity of voltage is applied. However, you failed to consider what happens when the armature rotates 180 degrees. Now the brushes will be supplying a voltage of the opposite polarity and so you would have south poles on both sides of the armature and the motor would try to reverse.
ok, thats settled then, lol, dual comm is superior
how do neodymium mags suit this design ?
could you possibly open up a motor, and sling the 4 ceramic horse shoe mags, and fit rectangular neo's in ? ... for more power ?
i heard a few people say you can get more power this way, but apparently they dont generate electricity as well as the ceramics ?
i dont know much about it tho, just what ive heard from a few people.
Originally posted by HuntingRoss View PostWith respect grounded, all this proves is single comm can't do all north.
Happy Hunting
mark
Yes Mark you are right. It's just the nature of you motor... You know that you have an excellent platform for testing designs and it's easy to work with! Have pride with your work. You doing a great job!
Keep it Clean and Green
Midaz
GroundedLast edited by Midaztouch; 05-22-2015, 12:02 PM.
mark, that petrol scooter sites pretty good. ive seen a few of those same motors on ebay, and was interested in one for a pedal bike trial.
theres a much bigger choice on that site tho, and the prices are a bit better.
shopping there, i guess your based in england too ?
I have a major important question that everyone seems to be quite about or just ignoring.
If a North facing field coil(on attract mode) and a South facing coil(on repel mode), are sharing the same armature pole...
Do they cancel eachother OUT leaving the armature pole/leg neutral or working together?
I need clarification on this point.
MidazLast edited by Midaztouch; 05-24-2015, 12:29 AM.
Originally posted by Midaztouch View PostIf a North facing field coil(on attract mode) and a South facing coil(on repel mode), are sharing the same armature pole...
However it seems to be a design flaw to have the north field attracting on the south magnet with the south field repelling on the south magnet at the same time. With both coils on the same pole.
Hunting
mark
Edit: Remark in RED added. Otherwise my comment made perfect design sense.Last edited by HuntingRoss; 05-25-2015, 05:26 PM.
Originally posted by HuntingRoss View PostI'm not certain that I'm understanding the question fully. But as it is presented, I would say the stronger field would be diminished by the value of the weaker.
Hunting
mark
More people need to address/talk about this topic.... I don't want to assume/estimate incorrectly. What is the truth!?
MidazLast edited by Midaztouch; 05-25-2015, 01:01 AM.
My final conclusion for Sampojo's 10pole & 4 Magnet motor
8 out of 10 armature legs at full torque driving the motor, sounds great to me! IMO
Some of you my be surprised by my conclusion but, here's my thoughts...
[VIDEO]https://m.youtube.com/watch?v=Zqw4gp3DlNc[/VIDEO]
Sampojo, you know what's best for you. Good luck with your motor!
Midaz
Dadhav, feel free to comment.Last edited by Midaztouch; 05-25-2015, 11:11 AM.
Originally posted by Midaztouch View PostSo, we have the "Giant Pink Elephant" sitting in the middle of the room and it effects the torque of these motors directly Underload.
I'm having a problem imagining the scenario.
Happy Hunting
mark
Originally posted by HuntingRoss View PostWhen you say "these motors" what design / schematic are you looking at ?
Happy Hunting
mark
The north magnetic field and the south magnetic field are sharing the same armature poles/legs when motoring.
That weakens the magnetic fields strength/torque some how. How can two opposing fields share an armature(s) without a conflict? That's one of the reasons why I have been very critical about most of the past designs and CADs.
That what I want to avoid or minimize with the Singular Coils = A1MoGen
Midaz
Mark, when your ready, post the CAD & info for you latest build.Last edited by Midaztouch; 05-25-2015, 01:05 PM.
Originally posted by Midaztouch View PostTake a look at posts #6, 53, 54 & 55....
The schematics are for all north coils which are projecting towards the magnets and the corresponding south fields are projecting towards the shaft. Unless that is the point you're making.
UFO makes this point :
Originally posted by Ufopolitics View PostDual Commutator Machines generates a "One Way Flow" within rotating fields...this has long, very long implications that range from flux flows to electrical fields flow...besides no constant colliding of electrons/flux...
Originally posted by Ufopolitics View Postconstant personal failures on dual commutator machines...
Happy Hunting
mark
