Well, the "Brush" companies can do anything but for the amout of time, money and CAD designs for new brush plates and wider brushes..... It's not worth it for me at this time.
Time for my original plan, first plan, PLAN A!
1.) We will Do everything with the parts that we have already for the P56 frame kit!
2.) We will have over 4000 Rpms @ 36v
3.) we will have superior torque than the OEM
Keep it Clean and Green
Midaz
Need a drill or drill press, a commutator pulley & 17awg
A1Mo-Gen: Tesla's Gift "The Electromagnetic Reactor"
A1MoGen: 7 phases/7 coils
Dual commutator Tesla motors that used standard OEM brushes, 2 commentator segments = 2 coils energized
It was a very simple process to run the motor in series connection.
Pos to Neg to positive with the terminal cables.
For the A1MoGen, I don't recommend that the coils be run in series the traditional way of positive to neg to positive with the terminal cables...
I have reason to believe that the traditional way may hinder performance or maybe burn out coils.
A better approach is to actually making the coils look more like the three-phase motor's coil phases...
One wire makes two coils 180° from each other. This will allow you to use a thicker gauge wire.
*Important* You can Only use 1/one commutator!
MidazLast edited by Midaztouch; 07-22-2016, 11:39 AM.
Look at the boost converter it pulses the coil then the bemf is routed through the diode, your coils are the same except the comutator is pulsing the coils, take the bemf an run it into another coil set but in the pos dirrection.
When you have time, post that drawing later.
I have some questions.
Why would it be important harness the BEMF Spike?
What would it do to the performance?
Where is the best location to catch it?
Is it easy to do?
Has everyone had similar results?
MidazLast edited by Midaztouch; 07-20-2016, 01:21 AM.
Have you tried catching the bemf spike using a diode?
Then run the spike into another coil, your setup is perfect for it.
I like 3phase motors. Each 180° apart poles are winded completely as a phase.
Each phase moves the load independently. 66% of the motor is putting in work! How do you compete against it? It's quite nice...
The A1MoGen has 2 sets of motor brushes@ N-S. They energize 7 coils each.
In my mind, I kind of see it like, 7 phases.
Each of the seven independent coils, almost go through 100% of the 180° rotation from N-S magnets before they disconnect from the power source.
A1MoGen: 7coils/7phases
7coils are all independent that span multiple poles, 8... I think that the multiple poles is a positive attribute.
Start of the North stator magnet that pole has 60 turns passing
Bisector of the North magnet, that pole has 120 turns!
End of the north magnet , that pole has 180 turns of 18.5 AWG!!!
*all those turns interacting with stator magnet have no advantage over the OEM motor!? How is that possible?
7phases is 1 giant phase that that moves the load. The poles are weaved together to create a unit phase to complete the cycle from N-->S magnets
Again, I may not be using the proper technical terms but I'm TRYING to give you my thought process for the winding the A1MoGen.
MidazLast edited by Midaztouch; 07-17-2016, 02:14 PM.
Bi
The examples I gave for Potential and kinetic energy are text book.
Potential energy = max amount of unused energy... Kinetic energy = put that unused ball of energy to work.
In my example, the battery is an unlimited power source... extra coils = Potential energy
(*Many companies use similar examples. Does that make sense now!?)
Generators have magnetic fields that opposes rotation?
What is that opposing force called? Is it CEMF or BEMF or EMF or what is the technical name!?
Maybe I use the wrong term. Please correct me if I'm wrong.
If the motoring action can over power the opposing force of the generator action, when they are used at the same time = MoGen
There are always more motoring coils than gen coils in the A1MoGen
If no one else does, I appreciate you. Thank for coming by my thread. I hope that We've cleared up any misconceptions/confusion that you or I might have had. Feel to ask more questions anytime. It's all about learning and sharing. Through questions, I'm proving my claims and getting a better understanding.
MidazLast edited by Midaztouch; 07-17-2016, 02:14 AM.
P.e. & k.e.
Originally posted by Midaztouch View PostPotential Energy = the Maximum amount of energy that any given motor can handle. It could be a long duration or a short burst.
kinetic energy = putting the potential energy to work... Move a car
I raised the Potential energy by incorporating 18 more coils that do not disrupt the motors harmony.
There are NO conflicts, 0 ZERO, in the A1MoGen!
Each coil works in harmony to support and fortify the magnetic field from the adjacent coils.
Creating one large extremely powerful magnetic field for each brush set = 4 brush sets
A1MoGen: at both north stator magnets' bisectors, the poles have 120 turns - 180 turns of 18.5 awg passing
The previous builds you get a max of 60 turns at the bisectors with 18.5 awg!
As you can 120 ~ 180 turns at the bisector is more the double
If you read some my post from this year about the A1MoGen,
then you would know that the Generator brushes are thinner/less commutator segments than the motor brushes.
That's have the motor brushes overcome the gen action.
The motor has to have some equilibrium and that's through the timing. If you look at The A1MoGen, the magnetic density of the coils is between each pair of the stator magnets' bisectors. N-S-N-S
I'll just standby for the tests; like it'll happen someday.
Originally posted by bistander View PostI have no idea what you're talking about, and I suspect you don't either. To convince me otherwise, explain what you mean by potential energy, kinetic energy and CMF. Then elaborate on why your machine is superior. Or just test it.
There are NO conflicts, 0/ZERO, in the A1MoGen!
A1MoGen: at both north stator magnets' bisectors, the poles have 120 turns ~ 150 turns of 18.5 awg passing
As you can see, 120 ~ 150 turns at the bisector is more the double
That's how the motor action overcomes the gen action.
MidazLast edited by Midaztouch; 07-17-2016, 02:08 PM.
Just test it
Originally posted by Midaztouch View PostBi,
I made a statement.
Here is my claim:
"The A1MoGen has forever changed the complexity of Brushed DC Motors. Raising the maxim "Potential Energy" to a higher new level that gives "Kenetic Energy" that is beyond the standards of regular Brushed DC Motors. The Kenetic Energy will easily overpower the CMF from the generator action of these motors.
Richard "Midaz" Batts"
I just wanted someone to Verify my statement. The generator actions is standard.
Originally posted by bistander View PostKind of demanding aren't you? You refer to this question, right?
I don't like being pushed to respond to a question with an erroneous premise. In your case, "all North coils", doesn't make any sense. A coil by itself has no polarity; no North or South ends. Its polarity is derived from current in the turns. And as to your machine somehow being special, or unique because you have wound all the coils in the same direction; conventional armatures are comprised of coils wound in the same direction.
Just test it, or are you afraid?
I made a statement.
Here is my claim:
"The A1MoGen has forever changed the complexity of Brushed DC Motors. Raising the maxim "Potential Energy" to a higher new level that gives "Kenetic Energy" that is beyond the standards of regular Brushed DC Motors. The Kenetic Energy will easily overpower the opposing force from the generator action of these motors.
Midaz
Ps. I always type things down quickly, then do a lot of editing to make it smooth. Don't take offense.
Read the post again.Last edited by Midaztouch; 07-17-2016, 01:01 AM.
Coil polarity
Originally posted by Midaztouch View PostBi, I'm not here for the BS my man! I've had too many arguments and spent too much money and too many YEARS!
Now answer my question in my above previous post. I need clarity.
But to be more specific about the North coils…
What outwardly polarity would the north independantly wind coils produce between the South going to the North magnet?
Originally posted by bistander View PostThat would be your opinion. But the magnetic fields are set by the magnets and core which are the same as the standard Imperial motor. The use of ceramic or ferrite magnets are mediocre in strength by modern day standards due to the rare-earth magnets available.
As for my statement, which I've corrected... What I should have said..
"The A1MoGen's COILS' magnetic fields are Beautiful and Powerful!"
Sorry, I thought that people would understand that I had posted all about coils.
Originally posted by BiAs far as I can tell, you have nothing for them so far. I suggest you quit patting yourself on your back and posting BS. Get some tests run. The PMDC motor or generator is one of easiest to test. You can get the basic performance characteristic curve with modest equipment. There are numerous articles on the web explaining how to go about it.
Its turning out to quite the task/headache!
So far, we have seen the Tesla's Dual Commutator motors that use factory brushes.
Those OEM brushes can only energize 8 coils! 2 coils at each of the four stator magnets.
The A1MoGen uses 26 coils... Due to the math, 26 - 8 = 18. There is a huge "potential" differance!
I stated a fact.
In past builds, the largest amout of Amps pulled was around 132 Amps. 132/8 coils = 16.5 amps per coil.... Hot!
Now, let's try 132 amps with the A1MoGen's 26 coils
132/26 coils = 5.1 amps per coil! ... 132 amps is a walk in the park for the A1MoGen!
*I built the A1MoGen Dual Commutator Motor the way I believe, N. Tesla himself would have made a motor.*
Bi,
I'm not here for the BS or for self-glorification my man! I've had too many arguments and spent too much money and too many YEARS, 3yrs!
Now, if you would be so kind, please answer my question in my above previous post. I need clarity.
MidazLast edited by Midaztouch; 07-17-2016, 02:16 AM.
Magnetic fields and coils
You said you know a lot about this motor and motors in general.
Can you please Answer this simple question?
Since the RIcoils of the A1MoGen are all NORTH, when all 26 coils are used as a generator...
Will the generator coils produce an outward north or south magnetic field?
The polarity of a coil reverses as it rotates around the field and alternates 4 times per revolution in the 4 pole machine. This applies to all coils whether used as a motor or as a generator.
Bi
Originally posted by BiI have followed Ufopolitic's thread and I am quite knowledgeable on electric machines.
Since the coils of the A1MoGen are all NORTH, when all 26 coils are used as a generator...
MidazLast edited by Midaztouch; 07-16-2016, 05:09 AM.
