Ha! Ha!
Wantomake,
I'm chicken pecking at this keyboard (very , very slowly so it doesn't take off in a thousand different directions at one time.
I be brief - So don't think about this info - just do!
The GDT and run cap ARE NOT NEEDED. The GDT had to be a trial -thought by ARIOVALDO -My opinion. Just get rid of the whole HOT LEAD to the Ground side and it is just the ole fool the meter system PERIOD!!!!
THE B&L actual system OPERATED with ONLY the HOT LEAD to the Toroid!!!!
From that point on is how they were able to LINK the INPUT SIDE to the GROUND SIDE. Think on this- BOTH the Torroid AND the shorted LOOP
have Line side Hot voltage in them. Tomorrow I will make a small shorted
loop with this Toroid and prove my point. I will completely remove the #1.0
shorted loop and and replace it with an #18 AWG one. I already know what it will do - it's called SMOKE & FIRE! That smoke and fire comes from an
AC CIRCUIT with that contains AC VOLTS & Amperage and Has to be provided by LINE and NEUTRAL voltage!
GET IT!
How they were able to transfer the LINE voltage from that LOOP and AVOID any DIRECT lead back to the Toroid original LINE input is what I want to find out.
You and the others (not being de-meaning at all) will be wondering, Why would this frigging idiot say that.
ANSWER: The ONLY INPUT TO THEIR SYSTEM (and was shown onTV and You Tube) Was 0.10 AMPS! X their 220 volt europe sytem = 22 WATTS !!!
No matter what load they put on their system that V/A/W NEVER INCREASED! At the present time with my build when you put a Clamp meter on the Line input and their is a load the amperage on the system input will climb like a monkey.
When you look at my build Pics you will see a HOT lead from the SAME HOT
Toroid input that ALSO GOES straight to load!
That is a GIANT SCREW UP that HAS TO BE OVERCOME!
Until this mystery is solved everything else has to take second place.
Enough slow chicken pecking.
Later J,
Clarence
GET IT!
Later J,
Clarence
