patents
I got them from here:
Nilson BARBOSA, et al. -- Earth Energy Generator -- 4 patents
Additional test results:
From the patent, Fig. 5 #2 schematic:
gnd/captor loop voltage: 1.5v AC
ground wire: 1.6amp
captor loop: 60+ amps, my meter quits at 100, and it hit that - I only tested for a few seconds so as not to burn up the captor loop wire - it gets hot
Mains hot/neutral: 18 amps on the hot side (powering the transformers)
I have an electric drill hooked up as the load - it didn't do anything with this arrangement.
From the patent, Fig. 5 #1 schematic:
Gnd-earth line: ~2amps
Load/output - the electric drill ran full speed
Utility hot/neutral: ~17amps (at 115v AC)
Captor/loop: 100+ amps & got hot - again only tested a few seconds
I had my volt meter connected to the hot & neutral of the load/output, and it registered around 3 volts, although the drill was running fast, so it must have been ~115volts or so AC.
I didn't try the single transformer setup in Fig. 6 yet - however, neither one of these used a "small" amount of current to power the loop.
ground wire: 1.6amp
