Barbosa and Leal Devices - Info and Replication Details
  • Originally posted by Bob Smith View Post
    Hi Guys
    Below is my Spanish-to-English translation of explanation by YT user Hibridor (Wilson Roa) of the B&L Electron Captor posted with his YouTube video
    Hello Bob. I have watched all of Hibridor's videos. I haven't seen anything from him that makes much sense to me, or which indicates that he has anything special going on. It's really hard to tell though from his jumbled videos. Nothing that stands out anyway as indicating he may be on to anything, IMO anyway.
    level
    • Still same ole un-level bs drooling
      Originally posted by level View Post
      I have already explained several times and also fully demonstrated why (for many countries anyway) you can't use the mains to power a Barobosa and Leal device arangement. The power going to the load is coming directly from the mains in that arrangement due to a ground loop. This should give people cause to think why Barbosa and Leal were doing demonstrations powering from the mains then. Are they just common scam artists or did they just have no idea what they were doing?
      Any testing other than with using only a battery and inverter (with no mains connection at all) is completely meaningless. Clarence please stop trying to deceive people with this sort of nonsense about using the mains. You have demonstrated absolutely nothing so far, and you spoke of tests done using the mains, which shows you either have no understanding at all what you are doing, or you are deliberately trying to deceive people for whatever reason. Do you not care at all that people could spend lots of money trying to replicate your setup, when your own setup itself does not work at all? It would be different if you can actually demonstrate a self running setup that runs for many days on a battery and inverter without the battery running down, but of course you haven't been able to do anything of the sort, at least not so far anyway, and instead you just insult people who point out the facts of the matter. Sorry to be blunt, but it really appears that you want to continue to try to deceive people here and give advice on how to build devices without you having demonstrated a single basic thing so far in regards to how your setup can really perform.
      THE ONLY THING THAT IS DECEIVED IS YOU!
      you can find a true deceiver when you go look in the mirror!
      I have a unit that REALLY works and all you have is the same old BULL ****!
      Clarence
      • I think the fellow has a right to share his energy project.
        I don't think he is a deceiver, but then again I am not
        a paranoid person. He is just beginning to learn and share
        results, why run him off of your thread that features
        this awesome free energy experiment?
        Why are you shaming him and name calling? Are you
        against free energy?
        Or do you know this poor man personally and just hate
        his desire to win?
        Level this is a shameful way to treat guests.
        Either way let me thank the gentleman for enduring
        the brutality and commend him for his persistence.
        Thanks for sharing CANGAS, your only mistake was to say
        GOD BLESS at the end of your letter
        Mikey
        • Originally posted by clarence View Post
          Clarence
          You are still advising people to use the mains after it has been explained many times that the power comes from the mains via a ground loop when doing so in this type of arrangement with the hot wire connected directly to one side of the load. Please stop trying to deceive people with such nonsense. Don't anyone be fooled. Clarence was asked very politely on several occasions in this thread to provide some very simple test results so people here could get an idea how his setup is actually performing, and Clarence either ignored the requests or insulted those making the requests. Obviously if his setup was really working Clarence would have just performed the simple tests and provided the details of the results to the members here. There is just no gettting around that. Clarence if you have a 'working' setup, then provide the simple tests results. Otherwise you have to realize that no reasonable person would have any reason to think that you have any sort of working device. If you are willing to give details on how to assemble your setup, there is no reason you wouldn't provide details on how it actually performs in some simple and proper tests.
          level
          • Bs program
            You are still advising people to use the mains after it has been explained many times that the power comes from the mains via a ground loop when doing so. Please stop trying to deceive people with such nonsense.
            The only SUCH NONSENSE comes from your self centered deceiving self and
            all of its BULL CRAP contained there in so put the brakes on yourself!
            Clarence
            • GANGAS,
              If you really want to try this and feel you have to use mains power as suggested by Clarence then you MUST use an isolation transformer. If you do not use an isolation transformer then your tests will mean absolutely nothing. As has already been pointed out using mains power directly just causes a ground loop effect because the neutral side of your mains power is already connected to ground. Using an isolation transformer allows you to work around this problem.
              Clarence I am surprised that someone with your experience would suggest to someone to use mains power to experiment with after they have already said they know very little about electricity. Are you trying to get someone killed? Don't you have any sense of moral responsibility? If you are going to suggest such a thing thing at least tell them how to do it safely and in a way that will give them useful results.
              Hello GANGAS,
              I admire your serious attitude for certain.
              Your definition of the lunatics overcoming the asylum was on point.
              the only way to achieve a tiny version would be by using mains power in order to get a 1.98 unit and even that would cost a little more than 1.98
              but I get your point!
              the other danger lurking in the shadows would be the mile-a-minute el-chepo
              do nothing whiney mouths jumping in to splatter the thread with their usual
              "bear in the woods" donation.
              this week I am finishing my cart unit re-build and then I will do what you speak of just out of curiosity for my self. I already know how to do it it's just a matter of taking the time to do it.
              as always , time will tell all.
              Thanks for your interest,
              Best Wishes, and Respects
              Clarence
              Carroll
              • If you have to use mains supply whats the point , It's what I'm trying to get away from.
                artv
                  The only SUCH NONSENSE comes from your self centered deceiving self and all of its BULL CRAP contained there in so put the brakes on yourself!
                  Clarence
                  Unfortunately just more deflection when asked to provide some details of how your claimed 'working' setup actually performs. You can't reasonably expect people to spend big money to replicate your setup when you won't provide a single detail on how your setup actually performs in a long term test using the battery. Again, your tests using the mains are meaningless. If you have a working setup, please provide some long term performance results using the battery and inverter, otherwise it is just more pixie dust.
                  Clarence, imagine if I said to you that I have a working free energy device that will cost you two thousand dollars to replicate, but I won't provide any details of how it actually performs. Would you just want to blindly believe me before shelling out two thousand dollars, or would you want to have details first of how my device actually performs in some proper long term tests? I think we both know the answer to this question. You don't really know me at all , so of course you have have no way of judging if what I am saying is true without further details. Please stop and think. It is of course not in any way against you for people to ask for long term performance test details. It is just basic common sense. Without such details you are just another guy amongst many claiming they have a working free energy device, but, so far at least, not willing to demonstrate or share even some basic performance test results.
                  level
                  • Originally posted by shylo View Post
                    artv
                    Hello shylo. Also, if it only 'works' when powered from the mains, but not when powered from a battery and inverter, then the power is obviously coming from the mains itself.
                    level
                    • Originally posted by level View Post
                      STILL same old song and dance - you want OTHERS to do the work and THEN have the unmitigated GALL to want them to submit to you the results of THEIR WORK! all while you sit back on a do-nothing butt.
                      don't ever wait on anything from me - it's for sure you'll pass without it!
                      Clarence
                        Clarence
                        I actually spend many hours of my free time experimenting with all sorts of free energy ideas and circuits. Have done so for years. It is you who said you have a working device that you wanted to share here. So if you want anyone to take you seriously you can either provide some details on how it performs or continue as you have been doing here by deflecting and making excuses. Enough silliness already. If you had a working setup you would have done the simple tests and provided the performance results a long time ago. Period.
                        level
                          Keep waiting on your SILLINESS TEST/ICLES!
                          they will NEVER come!
                          Clarence
                          • Originally posted by CANGAS View Post
                            Clarence, I discovered your good work over on that other thread, and followed your trail to here when the lunatics overcame the asylum over there.
                            I just want to say, thanks, thanks, thanks for your good work and your report of it. for many years I have been optimistically looking for free energy in the field of mechanical systems, also including the use of magnets or electrostatic components. My work has NOT been completely fruitless, though it is not yet exactly the right circumstances for me to make any announcements.
                            Your work is immensely reassuring. What would really get the party started is if it could be scaled way down so that even a poor boy like me could buy $1.98 worth of parts and prove the principle for himself on a small scale before spending big money (for a poor boy) to build the real thing.
                            My practical electrical and electronic expertise is very small. I am urgently hoping that somebody who knows their volt from their amp will design a LITTLE demonstration device that might only make 10 watts, or 1, but will do it reliably and undeniably.
                            Best regards and God bless you!
                            CANGAS
                            Hello CANGAS,
                            Just a reminder not to fear the lunatics on this thread.
                            that's exactly what I meant when I said they would be lurking in the shadows
                            itching for the chance to run out and make their "bear in the woods usual crap pile" .
                            Every single one of them are TOTALLY SELF OBLIVIOUS to the FACT that B&L
                            designed their units TO BE POWERED FROM THE MAINS of CEMAR UTILITY POWER COMPANY. KNOWING AHEAD OF TIME ONLY A SMALL AMOUNT OF WATTS WOULD BE DRAWN TO BE THE "ELECTROMAGNETIC EXCITER"
                            FOR THEIR UNITS AND POSSIBLE PHASE NEEDS. THEY ALSO USED THE UTILITY SYSTEM GROUND ROD ITSELF AND PLACED IT IN THE CENTER OF THEIR LOOPED SERIES OF EARTH RETURN GROUND RODS. HA! HA!
                            ITS AMAZING how FACTS like that just blow right past their knuckleheads!
                            but just consider the source and ignore the hell out of the BULL CRAP.
                            you can discern the handles of those who possess such self induced
                            ignorance by the previous group of posts that were made by them. put them on your ignore list and move forward. they never even knew they were being drawn out purposely so you could spot them when the time came! HA! HA!
                            as I said before when the time comes I will arrange what you were after.
                            THANKS ,
                            and respects
                            Clarence
                              Hello Clarence. It has been pointed out to you on a few occasions already that when there is a ground loop when using the mains, that it is possible that a power meter at the input of the device may not correctly detect the actual power being used. If the ground loop bypasses the power meter, then the meter may possibly not properly measure the power drawn in the loop that is bypassing it, depending on the type of power meter being used. This is another reason why anyone serious about testing this type of device arrangement should only test with a battery and inverter. You could possibly get incorrect readings from a power meter, especially the little cheap consumer plug in types, but measuring the battery terminal voltage while it is under load and the battery DC current being drawn from the battery into an inverter, should be a pretty reliable measurement of the true power being drawn from the battery, as long as these battery measurements are done properly with a decent meter.
                              It is interesting that Barbosa and Leal had all their equipment confiscated because they were found to have one or more proprietary utility power company meters in their possession. It seems at least possible they were testing with the utility company power meters to try to find ways to fool the meters. I am not saying that is necessarily what they were doing, but that is certainly a possibility.
                              The bottom line is if someone is using the mains to power a Barbosa and Leal device, you just can't draw any conclusions about how that setup is really performing and where the power is really coming from. A battery and inverter eliminate all the ambiguity around using the mains as a power source with this sort of setup, and so that is really the only reasonable way to test this type of setup. You should also only rely on a measurement of the battery voltage and battery current drawn as a reliable measurement of battery load when powering loads with this setup, as the cheapo plug in power meters that plug into a socket on your inverter could possibly give you misleading results. The battery voltage and current draw measurements while under load should be a good reliable check to determine actual battery power draw.
                              Another very simple quick reality check is if the Barbosa and Leal setup 'works' when plugged into the mains, but does not work the same at all when powered from a battery and inverter, then very obviously the extra power seen when powering from the mains is coming from the mains.
                              I am pointing these things out for people who are truly interested in trying to determine how things really are working when testing a Barbosa and Leal setup. Those who are only looking to deceive themself or others are free to ignore these points.
                              level
                                YOUR WISH IS GRANTED!
                                you are ignored!
                                Clarence
