Core material
Hello everybody.
I am trying to replicate Clarence's revision of the B&L device with no good results at the moment. If it is possible I would like Clarence to answer some questions, please.
Does the core have to be necessarily composed of ferrite? If it is not necessary, which material could be appropiate?
Must the core shape to be toroidal? Why or why not?
Thank you in advance.
One Thousand or One Million - It Makes No Difference
Originally posted by citfta View PostYou only have to post 1,000 times to be a gold member. But of course as you can see none of the posts have to make any sense.
You can even post demands that others show their work.
Of course, all such demands can be readily denied with complete and utter equanimity because they're absolutely meaningless.
Originally posted by djarno View PostStuff is getting freaky now.
1500 heater runs maximum performance ofcourse with an 1000Watt inverter.
I melt my cable, even with an voltage controller.
up 4000 watts at the load.
From what I understand of this CAPTOR system that Clarence
built and tested is that the battery charger must be powerful
enough to keep the battery charged. So let's say I wanted to
power a 100 watt light bulb plus send 250 watts from the
charger to the battery to keep the system a float.
Now I have a 100 watt light running for free because my battery
is kept charged. Remember that you are not doing that.
This is why your inverters catch on fire. Here is what you need.
Using a 1000 watt inverter and a 500 watts charger you now can
send 200-400 watts around the system in hopes that you can get
extra energy to flow. If you have 60 rods.
If you have 1 rod it will be less and so on. But you have to have
something to start with that will not catch on fire plus many rods
to run max COP's.Last edited by BroMikey; 08-11-2015, 05:56 PM.
Originally posted by tvka View PostSeems too lot about electricity to explain to you...
There are AC and DC capacitors...
However, if capacitor shows short, it's rather broken
On both lines amp's drop to 0 (or minimum not sure), which goes through ground loop which is like 90 volt depending on load aswell weather (ground wetness, I don't sprinkle it whole day for wet ground), voltage spikes to 227 volt and the 1500 heater runs maximum performance ofcourse with an 1000Watt inverter.
Only occurred 2 times for 4-10 seconds, while looking at the volt meter varying.
There is no capacitor.
See pictures.
I try to record and replicate it .
Also I removed the second toroid as I melt my cable, even with an voltage controller.
Anyways I'm going to experiment more and more.
Pictures and video's coming
Originally posted by djarno View PostVoltage drops, while current increases.
Disable some grounding means more voltage drop. I have no 12v capicitator only 220 and 450 but 450 will kill the inverter and the 230 doesn't seem to charge to 230.
But the capicitator might be broken, how can I test? Ohm or resistance meter? 😢
Originally posted by tvka View PostFriend, I absolutely believe in your sincerity
Clarence setup will never work- because of voltage source in primary.
I explained in previous.
Yet, as you have grounding, (I have none) can give you idea
Take 220/12 V transformer and series connect it with 50/60Hz resonant capacitor (huge)
Why 12V? resonance has to increase it.
And figure how to disconnect primary- transform will be crucial
May be Yuri_L method.
I understand russian perfectly. Yet video was not assuring.
Originally posted by djarno View PostProtocol ?
Perhaps, I'll still have to try it with sufficent load (thus 1000 watt or less) and disable the ground. If 'amp' building doesn't occur it is more then transformer right ?
I have no reason to spread false information here. I only want it to replicate OR 'debunk'. I also still have to look if more load is pulled when amp building utilizes in the transformer(s).
Any suggestions ? I understand that you won't accept video's as they can be faked, but once again I have no reason to do so.
[QUOTE=wantomake;278467]Thanks my friend and fellow can kicker,
Yes it takes time and energy for life's needs.
I look forward to your next project "alternate potential system instead of ground rods". If I'm reading that correctly.
More later,
wantomake[/QUOTE
Hello wantomake,
I need a PM please.
thanks,
Clarence
Originally posted by JESUS PIŅA View PostThe Schumann resonance is a set of spectrum peaks in the ELF'''''''''''''''''''''''''''''
''''''''''''''''''''''''''''Since 1980 it has risen to over 12 Hz. And now at 14.1 Hz.
'''''''''''''''''''''''''''''''''''''''''''''''''' '''' The system must be in phase with Schumann frequencies?
format. 120vac at 60hz. Thx for the history, I hear this about earths
resonance being higher now but I never have confirmed any of it.
Someone says if I pick up more electrons then my voltages will
go higher but instead voltage is held the same while earth CURRENT
is harvested and used at the load.
I am not to much at explaining this stuff and I am only speculating.
Originally posted by BroMikey View PostNo, these systems use inverter frequency 50hz or 60hz to
collect usable energy so we can run a refrigerator. 7.83hz
is no good for motors. The system puts in a 50hz or 60hz
frequency and 120vac in tiny amounts forcing this small
bit of energy into the ground. Then the earth adds more
to the same format. The Captor sets up the voltage and
frequency, but only provides 5 percent of the load.
The earth energy piggy backs more electrons.
Ride that wave gentlemen. It's like surfing, you get the
board pointed in the right direction and let that ocean
wave carry you home.
You need 60 rods.
The Schumann resonance is a set of spectrum peaks in the ELF (extremely low frequencies: "extremely low frequency") of the electromagnetic spectrum of the Earth. Since its seventh overtone (harmonic) is located approximately 60 Hz. The lowest rate, while the high intensity of the Schumann resonance is at about 7.83 Hz. The detected overtones extend to the range of kHz (kilohertz). The resonance of Earth (Schumann Resonance) has been 7.8Hz for thousands of years. Since 1980 it has risen to over 12 Hz. And now at 14.1 Hz. I think when in 1752 American Benjamin Franklin (1706-1790) investigated the natural electrical phenomena. The particularly famous his experiment in which, flying a kite during a storm, showed electric shocks, I think the truth was not an electric ray, but a burden Schumann resonance induced by the time was 7, 8 Hz. The system must be in phase with Schumann frequencies?
Originally posted by tvka View PostHi!
Sorry, I will not accept videos. Protocol, if you can
This story has nothing to do about ground. It's transformer story.
Yuri_L maybe has solved it. Lenz law is not broken- just utilized.
So voltages in ordinary transformer are in-phase, secondary current lags 90deg. By adding fat secondary shorted and some portion of primary counter winded MAY Be in that portion EMF is induced to counteract primary consumption and fully utilize energy stored in transformers core.
