Yuri L from OU has a 2nd single primary shorted loop connected to the phase or LIVE 500 t primary 0.6 dia and sec 450 t 1 mm dia
Can somebody invite him here
he has a yt video of his set up without earth ground
E_mail
Hello madmack,
are you out there?
need an E_MAIL from you!
Respects,
Clarence
Originally posted by djarno View PostMore rods == less voltage drops.
Need more rods, then rewind like I did before (where the 300 amps actually drop). Though I am using 220 volts load while I get an return of 100-150 volt depending on load.
Need to wait for inverter back, and yes I haven't measured any over unity yet. Though, to me, abnormality's in an way they don't make sense.
Abnormalities or not, the aim is real power gain. Otherwise planting of them grounding rods is monkey job.
Originally posted by tvka View PostHi Djarno!
Please look at my Captor drawing from previous posts.
So do measure currents I1 and I2 and protocol them- with load and in steady state after all transitions.
No need for video.
If I2<I1- no overunity.
I do no understand how this wrapping around secondary can provide coupling. According to classical electromagnetism nothing is induced there.
Same principles about overunity I wrote to you- resonant and open system- stays.
Hello my Friends,
i made the seconderies coils exactly as its recomanded, where the two tops wires is connected and the two bettom wires is connected together.
stil work on the ground rods. is it possible to use a heavy mass like old radiators, insted of groung rods?
what if we change the green wire connection and close it with the earth?
Best Regards
luc2010
Hi Djarno!
No need for video.
Originally posted by Alydian View PostFor those who are unconvinced about the ground field. an informative Youtube video at https://www.youtube.com/watch?v=Yg6G5VUSsWA. shows how little current can flow in a single ground rod even driven 50 feet deep. keep in mind this build requires potential current from the ground of at least 25 amps. to obtain 3 Kw output.
Looking at it this way 60 grounding rods at 10 feet long = .4 X 60 = 24amps.
This might be interesting:
Energy from the Ground - Self powered generator by Barbosa and Leal
Originally posted by tvka View PostGuess pushups is only thing you both are good for!
Its amp building, which should be impossible because when I use on normal net power (mains) its instant amp kick in.
It's all based on clarence/barbosa. With a little difference as you can see.
If I am correct I only powered one toroid. 2 toroids gave less amps while idleing while they are the same winded. Even when I am cross connected and what so ever more.
https://www.youtube.com/watch?v=Sm-gSMGZwi4
My inverter is broken (over volt kicked in), I expect new one next week.
I'm thinking of building an tesla tower alike coil to reach over 200 kilovolt and bang an spark gap, hope it activates the ZPE field.
Originally posted by BroMikey View PostAre you calling Clarence Captor replication silly?
Bad boy, not good. How do you say "Hard Head in 3 other
languages? Clarence is not going to let you call his captor a lie.
Go take readings and come back when you are serious.
No one has asked for your endless wisdom of consultation
Should Clarence maybe drop to the floor and give your Hindass
50 pushup also?
Originally posted by tvka View PostBroMikey,
Oh, great
My english is far from perfect. Yet I can communicate in 4 languages.
Don't worry, I will have my readings. Just not with this silly "captor" setup.
Pretty evident it can not "pump" anything from earth.
Clarence on a new project? This one supposed to be finalized already?
Well, well
50 pushup also?
BroMikey,
Oh, great
Well, well
Originally posted by tvka View PostClarence,
Main want is as stated- please measure currents- incoming I1 and outgoing I2 as on drawing and announce them. It's easy with clamp meter.Originally posted by BroMikeyHi tvka
I have looked at this question and looked at this question and
looked at this question and finally I realized WHAT the question
is. The question IS
what is the current on L1 and L2
The way you typed the question is very confusing.
L1 = neutral and the designation L2 = hot leg
Before when you posted the question it looked like you wrote
"check 11 &12 for me" check current? 11 &12?
No!!!
Now Clarence is very busy and you guys need to follow this thread
like it is posted. Clarence just told you all that he does not
waste a lot of time with those measurements. If you want to
measure, that is fine.
In the future use the capital L1 and the capital L2 please.
It has taken me 2 days to understand you and I am sure
Clarence is on a new project that takes all of his time.Originally posted by tvka View PostClarence,
Could you please measure I1 and I2 and announce them?Originally posted by tvka View PostBroMikey,
Why you say "great", when it's useless?
Clarence,
Don't you really have a multimeter?
You are now hearing me. Your english is so bad you will
never follow directions.
This guy is a hard head also Clarence.
@TVKA
where is your reading? Go take readings.
