Yuri L from OU has a 2nd single primary shorted loop connected to the phase or LIVE 500 t primary 0.6 dia and sec 450 t 1 mm dia
Can somebody invite him here
he has a yt video of his set up without earth ground
Where is his TUBE video? What TITLE did he use? I am looking
hello Clarence...i have being following your posts and it is nice you sharing your experience with the forum, please i want to ask you this , what is the amount of excess energy have you gotten from the device so far,? and what determines the sizing of the device? is it the bigger the toroid the bigger the power output or the bigger the grounding the bigger the output? thanks
Checked. 75A (22W) on secondary loop, 27W secondary winding load.
the hot wire is connected directly to earth ground rods?
Can you explain this a bit??
Best Regards
luc2010
My perception of injecting 120vac or 240vac into the ground goes like this.
A beginners look that probably needs help adding other processes in.
(1) The Captor transformers set the tone or frequency (60HZ) being
connected directly through the voltage headed south to the ground.
(2) The voltage is now regulated to 60hz which will be collected
for use and is an important requirement. Who wants power they
can't use?
(3) The battery sends a tiny amount of DC to the inverter that in
turn sends a trickle of (in my case)120vac to the grounding rods.
These rods are now activated with a tiny portion of energy that will
be needed to power the loads. The rods are energized and waiting.
(4) The earth is a huge magnetic rock so when I inject 120vac that
is made to jump from one rod to the next and so on using 60 rods 10
feet long, the rods will pick up EXTRA.
So the captor collects energy that is usable because that is what it
is told to do.
Sure Tesla collected energy by earth grounding plates and rods
as well as connected antennas to produce a potential difference
but this form of energy, however great could not be used to power
devices designed at 60hz, 120vac.
This device is a step up innovation from the 1890's.
Understand what Tarial Kapman is doing when he goes way out
into a remote region where no power lines exist for 40 miles
and gets the same results.
can't use?
is told to do.
"Earth is a huge magnetic rock" So ignorant- no comment
"Understand what Tarial Kapman"- Kapanadze- for dumb americans - Kapanadze is bull****
Just wonder how many comments one has to apply to become a "gold member"
