  • Hi Clarence
    Nice build. Don't know if I am mistaken (thumpnail 1) but is there a short, red wire over the green ground coil on the captor? See picture.
    • Thanks
      To All,
      I do live in a very high geomagnetic location and have built the original setup and I have tried different ways to make this setup work as Barbosa and Leal said it did. But cannot get the coil/loop to extract energy to power anything.
      If you live in a country that uses the electrical company SWER utilities, then you may have success. This is only my opinion from my personal experiments and thoughts.
      Prove me wrong and I'll help you build your setup from what Clarence was so gracious and patient to teach me.
      I've learned so much from this experience but I too will move on to other projects,
      wantomake
      Hello Wantomake,
      Thanks for the Heads Up on the SWER thing.
      Will work on that.
      Respectfully,
      Clarence
      • Swer
        To All,
        wantomake
        Wantomake,
        Originally I stated out with my own DIY SWER system but abandoned it as time went by.
        So this AM I went back to it with a quick hurry up connection from the
        neutral to three separate ground rods ( none connected to the 60 rod grid
        return). Had to place a run capacitor inline to keep the inverter from growling
        like a mad dog.
        Placed my single household receptacle across the Captor output and the
        Inverter Hot Lead and flipped the switch.
        Plugged in a 4 watt night light I use for testing and a single 13 watt CFL
        and both did light right up.
        Checked the voltage and showed 64/65 steady volts AC. Amps on the Green # 6 AWG showed showed .2 and steady. Also the Amp reading on the Captor
        itself rose a bit.
        However this was the limit that it would power for now.
        Had only extended the lead for the toroid Neutral connection, which was an already dedicated circuit.
        I believe that an non-dedicated neutral lead would allow the full voltage to be captured by the ground return.
        Will try that process next.
        Thanks again,
        Clarence
        • Schematic
          Clarence,
          Could you draw a rough schematic to aid here. Cause I've tried dozens of different connections and I've totally disassemble that setup.
          · Is the green #6 awg connected just to the captor?
          · The neutral is connected to three input rods, is that not still just "fooling the meter" thing?
          I'm sorry to be confused, but I need a schematic or a brain,
          wantomake
          • Help coming brother
            Clarence,
            wantomake
            Hello Wantomake,
            Give me about 45 minutes or so and I will take some section by section photos of the unit with the bulbs now burning . I took you advice and did the SWER thing.
            The photos are better than a schematic and you look at and see what goes
            where!
            I'm on it!
            Clarence
            • Pictures and words
              Clarence,
              A picture is worth a thousand words.
              Thanks ole friend,
              wantomake
              • Here they are
                Clarence,
                wantomake
                Wantomake ,
                Here they are - Hope it helps.
                Clarence
                  Wantomake ,
                  Clarence
                  Clarence,
                  Yes I see, now try this if you don't mind.
                  In picture #5 , disconnect the large green wire in the upper left corner on that smaller terminal block, I assume that is the return from the ground grid, and connect it to the neutral on the terminal block for the lights you have there just below it.
                  See if it's not the same voltage, and the lights will light up? Bypass the loop altogether. Or turn off the coil inside the loop.
                  This is how I found out if the coil/loop captor combo was extracting anything at all from the ground grid. If there's a difference in the voltage/amps then the coil/loop captor is pulling or extracting extra power from the ground grid.
                  Let me know. If I'm wrong I'll assemble the setup today and keep testing.
                  wantomake
                  • Will do
                    Clarence,
                    wantomake
                    Wantomake,
                    Yes Sir - will do.
                    Will post back later this PM.
                    Clarence
                    • Done
                      Clarence,
                      wantomake
                      Wantomake,
                      I disconnected the black hot lead at the small terminal block and disconnected the neutral to the toroid - this killed the Captor and Isolated
                      the green ground return straight thru to the the bulb receceptace like you wanted.
                      Checked the voltage at the terminal block before the receptacle and it read
                      44 volts ac - Same as before - not enough to light anything.
                      What do you think?
                      Clarence
                      Last edited by clarence; 07-20-2017, 03:14 PM. Reason: Forgot to add the IMPORTANT words !
                      • Wantomake,
                        Since the voltage is the same evidently the Captor can't get anything done.
                        Thought about the ground rods early this week. Been in the ground for close to 4 years
                        so have no idea of what shape they are in- corrosion or deterioration or whatever.
                        Late this week I will get two new single rods to use one for input and one for return.
                        Will see what happens then.
                        Clarence
                        • Wantomake,
                          After doing multiple type connections and several additional ground rod input and output
                          attempts I found that all of this was as useless as hell. The basic circuit is Valid except
                          for TWO connection FLAWS in the Ariovaldo schematic. It shows the Black hot lead going to the GDT -Then The toroid - then the out put terminal. WRONG!!!! The Hot lead ONLY goes to the toroid and the output terminal block- nowhere else.
                          It is the NEUTRAL line that goes to the Toroid AND THEN ALSO goes to the GDT.
                          The GDT MAKES the Green ground rod return line serve as the RETURN lead.
                          J , Here are the High points to consider:#! This B&L unit actually DOES work.
                          #2 It is NOT dependent on Location.
                          #3 It is NOT dependent on magnetic anomaly.
                          #4 It is NOT dependent on a SWER location.
                          #5 It CAN be used on a two wire location.
                          ( That I am doing right NOW )
                          #6 It can be used on on a battery/inverter
                          system. ( it will need a HIGH Amp Hour
                          Battery Bank Plus a Smart Charger - the
                          Smart charger CAN be powered by the
                          Captor also - am doing that as I speak.)
                          You definitely need to reassemble your unit . Forget about testing - Just use it.
                          You will need to use some Kill-A-Watt meter on the AC in put to show the difference in Amps in versus amps out through the Captor loop or people will just still think it's only a regular
                          AC circuit . Use an AC amp Clamp meter on the Green wire ground return line also. Then compare the difference in amps in and amps out. Then tell me what you think.
                          Tomorrow I will attach the new Photos of my unit in operation and show all the new connections.
                          Too late to get it done this PM.
                          EDIT:
                          Late this PM I did use it to run my Microwave - The Kill-A-Watt for operating everything showed 11 amps .
                          The Fluke Clamp meter on the Green Ground Return # 6 AWG wire showed 17 amps .
                          So that means the Captor FURNISHED 6 AMPS!
                          Clarence
                          Last edited by clarence; 07-21-2017, 11:17 AM. Reason: added info ; corrected connection directions
                          • Photo and connections
                            Clarence,
                            wantomake
                            Wantomake,
                            Here is the Photo and the connections shown in it.
                            Holler back when you can or want.
                            Respectfully,
                            Clarence
                            • Reverse polarity
                              Clarence,
                              I said if I was proven wrong, then I'd reassemble the setup.
                              But if this is same thing just connected with reverse polarity, I will try anyway.
                              wantomake
                              EDIT: I do see the GDT there, so no direct connection from the hot side to the green return. Nor do I see a input to the ground.
                              • Coffee is slow working.
                                Clarence,
                                My coffee is slow this morning.
                                So your smart charger and inverter are out of picture? I assume.
                                And there is no input to ground grid. That I can see. Only the big green return from ground grid.
                                I WILL post results after I get down to the shop and connect everything.
                                wantomake
                                EDIT: After I have coffee !!!!!
