90 volt GDT
To All,
Just connected the 90 volt GDT to the setup and the 100 watt load light up like it should. Pulling .5 amp from the setup.
But I disconnected the green ground grid wire and there was not gain or loss of power. I found no amp pull coming from the green ground grid wire with my amp clamp and Fluke meter. Amperage on the loop is 67 amps. There's amps on the green wire wrapped two times around the loop.
Therefore I am open to any suggestions.
wantomake
EDIT: The GDT heats up faster as add more load to the system.
To All,
wantomake
