if there is no ground wire in outlet box can i use a gfci?
  • if there is no ground wire in outlet box can i use a gfci?
    Would a gfci ground my outlet?
    Im guessing this outlet can only be truley protected with a surge protector?
      A GFCI will absolutely work without a grounding conductor. A GFCI measures any current difference between the live and neutral wires. If they don't match, current is going somewhere it isn't supposed to and it trips. It doesn't require a ground to do that.
      Dom
        Google knows the answer for this one
        Search:no ground wire in outlet box can i use a gfci?
        Third link:
        2-Wire (no ground) Electrical Outlet Installation Wiring Details.How to wire an electrical plug outlet or wall plug when no ground wire is present
        With a bunch of nice pictures http://www.energeticforum.com/images...s/thumbsup.gif
          Dom
          are u sure a gfci can protect outlets the house catching fire and people if power surge occurs?theres only a ground at the main and no grounds on outlets
            Its a waste using a gfi on a 2 wire system. A standard outlet will work fine as long as its on a breaker. The outlet should match the wire size rating. 15 amp or 20 amp. The breaker needs to be matched too. You dont want a 20 amp breaker on #14 wire.
