Ground/ionosphere induction system; Tesla radiant energy.
Space based solar power station that beams power via (some kind of basic photo-electric laser, maybe ultraviolet or beta-beam; try to adapt to electrolaser beaming system) stays in orbit using magnetic sail
Electrolaser plasma antenna
silicon carbide and nano-celluose coated aluminum and graphene plated sheet diaelectric plates
Iron core grapene coated grounding system
Alexanderson antenna sub-system for two dimensional spacial distribution
Dollard transmission array
Telluric geomagnetic distributor and ground system
Concentrated solar hot water and air; solar heat pump
geothermal heatpump that uses a thermo-electic heat transfer pad to infrared-to-tertraherzt conversion oscillator and then heatsinked to north-wall; tesla turbines to run electric generator and compress methane from bio-decomposer; direct heat-kinetic conversion through nitinol engine
cannabis greenhouse lined with algae growing pockets to make bio-fuel and composites; bio-gassifier to produce syngas and synthesize methanol fuel
electrolytic fuel generator (I.E. hydrogen, oxygen, peroxide, etc...)
lithium battery recycling and element reclamation for fusor fuel
tritium production and beta-battery cells
hydrogen-proton/lithium (anuetronic) fusion
(?Cold fusion?)
graphene photoelectric solar concentration system designed for ultraviolet-blue and infared-to-tetrahertz reflector (Still functions moderately in mid spectrum, perhaps 65% nominal efficiency)
kelvin waterfall water energy harvesting system; hooked up to small gravity-fed tesla turbine and generator; uses water to maintain cannabis crop for bio-fuel; filters water through natural filter and reverse osmosis for drinking (experimental reusable/recyclable desalinization technology)
vaneless ion wind generator (kelvin thunderstorm)
faraday n-machine flywheel with liquid mercury-197 brushes
energy stored on site as methanol/methane, graphene organic super-capacitors, solid state graphene-lithium 'crystal' batteries, photo-crystals,
Energy is sent through single wire earth return system to the radiant energy transmitters that redistribute the single-wire earth return to true single wire earth transmission (Central node is receiver with distributed transmitters at boundary)
(System optimized for dark lighting discharge, capable of handling typical lighting discharges)
(Lighting resistors on al electronics, shelters designed to dissipate energy from lightning strike)
(System designed for scale in size for power density requirements)
(All systems laid out symmetrically to eachother as reactive elements; radiant design)
(natural disaster resistance [including tornadoes, earthquakes, flood/tsunami, nuclear disaster, deep freeze blizzard] focus on easy of repair/maintenance)
First model designed to be a self sustaining system that produces more energy through coupling of radiant energy receiver (I.e. using the solar power input or wind power, etc... fire up the electrolaser and absorb energy through earth circuit, re-transmit the energy well suited for home sized receiver units, those units display more power than is being used to run the main receiver circuit and transmitter in unison) Power is available directly after receiving, but is directly re-transmitted to suitable home sized radiant energy receivers
Entire system monitored and controlled by analog circuit system which is integrated into a computer made robust to the high-potential of the system (I.E. fiber optic control system)
System capable of robotic self-maintenance
Main receiver is essentially a dollard transmitter hooked up to a tesla coil instead of signal generator and
Dollard transmitter is powered by a vacuum signal generator redistributes energy to smaller receiver units; mimics and stimulates lightning discharges for recievers to attain more dark-lighning conversion
Extensive grounding system distributes grounds through 12-conduits comprising of 12-iron bars coated in graphene, making direct contact to the deep soil; A radially dispersing set of 12 bars attach to the tapered end and make contact with all the low layer earth in a distributed fashion of conduction, allowing complex waves to be transceived by the system
The alexanderson system is loaded high in capacitance using 12-conduits comprising of 12-aluminum coated in silicon carbide and nano-celluose separated by ceramic spacers and reconnected electrically in a connector radially as appropriate for the transmission wave properties
The capacitive topload is composed of a wardencliff style dome with a single rod protruding a ball and then three connecting rods to a taurus, with all dimensions spaced out appropriately to achieve maximal capacity for elements in the most similar quantities; All materials are covered in a nano-celluose coated silicon carbide ceramic diaelectric shield (lighting strikes here!) Fixed through the poles supporting the ball and through the torus is an electrolaser that makes connection to the ionosphere, lighting and charges are directed to and from the top-loading system, electrolasers are floated on a virtual nuetral between ground that bleeds through a high value resistor and zener shunt to protect the laser electronics, laser is diaelectricaly shielded with silicon carbide, laser is projected through a vacuum tube window system to prevent lighting from making contact to the laser
Telluric induction system takes many sets of bifilar transmission coils linked to main transmission line by centertapped transformers; Telluric system is in resonant frequency of natural earth activity due to dark-lighting and tuned to reasonable efficiency of around 65% or better for regular lighting; telluric induction system buried in ground and isolated diaelectrically from the earth; center of coil is grounded , the outer winding extends into an insulating shield for connection to transformer
High voltage graphene and nano-celluose/silicon-carbide capacitors.
Inductors are air core (coolant blasted) made of iron core with copper jacket coated in graphene and covered with nano-celluose insulator (made to withstand standard use at room temperature) (maximum conductivity/Q and also inductive boosting through integration or iron into the center of the wire)
All high voltage lines coated in nano-celluose and encased in nano-celluose coated silon carbide pipe
All systems aligned to solar and earth magnetic bubble and magnetic poles of earth with respect to calculated shift to further increase system efficiency
Entire system is capable of being run in push-pull configuration, and the continual production of lighting and lighting excitation in reciprocating loop.
12-phase system capable of running in virtual 1&3&4 phase
Well tuned for dark-lightning range of energies and main purpose is harvest "passive-radiant-energy"
Building facilities for personnel shielded from all types of radiation known to man, made to prevent reverse lighting spikes into open air, ion and particle filters in air duct system, all units grounded to prevent electrical potential buildups within peronel areas. Remote facility controll
facility maximally designed for personal safety and ability to preform live maintenance. Robotic surrogate can repair work by drone pilot or autonomous repair sequence.
Multiple redundant safety systems and systems protection measures
Towers made of silicon carbide beams with nanocelluose coating; beams consist of 12-poles bound by radial connection.
Concrete for facilities made of hemp and bio-cement; all concrete facilities are ufer grounded through iron pipe
Non-conducting roofing with grounding lattice; particle shielding; strong material to withstand emergency or natural disaster
Buildings built like a bunker and weather proofing as well as high temperature and stress rating
Project goals:
supply enough power to pay for the cost of such a system over its lifetime
feed power back into the grid
produce enough power to run an assembly factory
produce enough power to enable a railgun to operate continuously launching satellites
produce enough power to run a city
more range than three times the transmitter wavelength (several kilometers) still produce 65% power
electrolaser will focus in on the lower portion of the ionosphere creating a plasma filament which will be pumped with an excitation signal to create a standing lighting bolt even in fair weather
Main receiver:
Tower height 535.68933613324 meters
Reactive frequencies 559.64Khertz,
Deep UV electrolaser, pulsing baseclock frequency 116 tetrahertz, (minimum wattage to produce standing plasma filament in the air to 3.1890685e+6 meters, not exciting standing lighting)
Electrolaser additive energy; 3,189,068.5volt, xxx(minimum amp to stimulate lighting emission in fair weather)amp, tunable 1.1813Khertz to 14.845Khertz (mobii interval) excitation signal
Topload dome sheets capacitance xxxF
topload spheres capacitance xxxF
topload tourus array capacitance xxxF
Topload capacitance total xxxF
alexanderson system
Main transmitter:
Tower height 10.176 meters
reactive frequencies 29.458Mhertz, (88.375Mhertz sub-signal)
Home radiant energy receiver
unit "tower" height 3.392 meters
reactive frequencies (main carrier signal 29.458Mhertz) 88.375Mhertz,
receiver uses electolaser and voltage excitation at low current to create plasma filament to reach low ionosphere and connect electrically to the dialectric topload separated in 12-phases
transmitter uses single wire through ground with no return, quite similar to wardenclyff tower in wireless power transmitting mode
home receivers are use replicateable with sensibility in engineering diagrams and formulas; receivers should be able to draw 1/12-1/3 of the total transmitter power when transmitter is not maximally loaded; mimic the tesla radiant energy system by manmade driver over single wire earth system. Optimize for earth harmonics and make signal 65% intact from halfway across the world (not net power, just waveform degradation)
chosen frequencies were selected for biological compatibility and similarity to earth like waveforms
("Radiometric analog computer") long wavelength preferred over high frequency
Earth electric circuit:
From ionosphere ceiling;
7.4808 Hertz
700e-6 Farad
0.64662 Henry
200 ohm fair weather resistance
200kE-100ME volt
1kI-100kI amp
~~100e+9 p*s
(Atmospheric electricity)::Global atmospheric electrical circuit - Wikipedia, the free encyclopedia&(The Fair-Weather Atmosphere as a Power Source)::www.electrostatics.org/images/a2.pdf
More parameters of this need to be worked out with calculation and experiment. These are just rough notes on my concept to recreate a tesla radiant energy device capable of powering some sizable load. Current theoretical limitations are the usability in outerspace such as electrolaser conduction and applicability to spacecraft, but the design will be expanded to create an artificial magnetosphere around the craft like a magnetic sail and be capable of harvesting energy through electrodynamic tether.
Please take this post as a guideline in the design of new age tesla radiant energy technology and how to properly implement power systems on planets in general. On mars we would nee to create an artificial magnetosphere with satellites and a planetary electrical control system, possibly a GEM dynamic gravitational field generator to compensate for the 1/3 gravity there.
I will update this post as I work more on the idea but it is rough drafted enough to help guide people in the creation of their own energy technologies.
(?Cold fusion?)
Project goals:
Main receiver:
alexanderson system
Main transmitter:
7.4808 Hertz
700e-6 Farad
0.64662 Henry
200kE-100ME volt
1kI-100kI amp
~~100e+9 p*s
