Magnet motor revelation
  • truesearch
    @citfta
    I believe you probably mean "112" rather than "122". Here is the link to your helpful post: http://www.energeticforum.com/279747-post112.html
    Sincerely, and best of success in the search!
    truesearch
  • Ufopolitics
    The Perfect Balancing Three Point Line...
    Hello to All,
    I have built a few of this Two Module set up...and it was very hard to find a perfect balancing...even measuring rotor magnets at front outer points to shaft...considering perfect 30º angles in both...and even so I still had some issues at 180º one side was fine while the other turn did not do it as the first.
    So, I found out that even considering every single measurement for EACH Rotor Magnet, we still could be off by very small measures...but enough not to reach perfect balancing...
    There is a VERY important Line we must trace when setting rotor magnets:
    On the CAD above is the Red line that runs from each cube outer corners-across at 180º- and this line MUST be passing through the VERY EXACT center of Rotor. So it is a Three Point Line.
    And let me say this...even in a CAD Software...we build all this measurements for each rotor cube...even grouping and center pointing...plus rotating/duplications...we will have the error when tracing this red line...we will notice is off by not passing EXACTLY by the center of rotor...
    Like I wrote above...You may think you have every measurement perfect and correct for each independent rotor magnet related to shaft measurements...HOWEVER, IF You do not run-trace this red line...they could be off by just 1-2 mm (and even much less than that) but would be enough to throw out your balance completely.
    Once this line is perfect between three points, then the sweeping of cancelling forces is going to take place EXACTLY at every single degree of rotation...
    Something else to check once we have rotor magnets perfect...is that each outer corner of the rotor cube should be EXACTLY passing by the same FACE area and coordinate from BOTH stators simultaneously (In the Opposite way, of course). This will tell us that both Stators are also aligned by that Red Line and related to mounting base straight line as well.
    I felt I should write/share about this geometrical fact...to avoid frustration in not reaching your proper/perfect balancing...even though many of you may have considered this line in all your builds.
  • BroMikey
    Originally posted by tachyoncatcher View Post
    Thanks for that resource. Now that's a helpful post.
    Randy
    Yeah Mack is a mad man to have used this non-stop until yer 4 way
    flashers start blinkin. This is my kind of head game. All the lights are
    turning on now for sure. The more I run the numbers the more I see
    what size thickness on the ramps at what distance from the rotor
    magnet. The repelling calculator does not work on square magnets.
    Oh well gonna make it adjustable for fine tweaking.
    So far with 1" X 1/2" X1/2" square magnets the calculator shows 15.89LBS
    of force when two N42 magnets pass at a gap of 90 thousandths. To think
    those itty bitty magnets pack that much wallop. I am dumb struck.
    And it all cancels out and on top of that goes over into the ramps?
    The LBS of pull for steel plate helps but we are also siphoning off flux
    from the stator as well as all of the pull from the rotor.
    Figure 50 percent more than the calculator shows just for openers.
  • tachyoncatcher
    ...Here is the information also in calculator form, pretty Kool
    Good stuff, moving forward.
    K&J Magnetics Blog
    K&J Magnetics - Steel Plate Thickness Calculator
    Randy
  • BroMikey
    Originally posted by MadMack View Post
    UH OH! Now you've gone and done it...
    You've let the genie out of the bottle!
    U-Duh-Man MadMack God Bless You
    K&J Magnetics Blog
  • MadMack
    Yes, exactly. The only ramp I have that does that are the "Y" ramps.
    The rest of them just go past and come right back.
  • tachyoncatcher
    Attraction mode ramps
    That's great Mike. Now try this. Put your 2 rotor magnets and opposing stator magnets back on. With balance. Add that ramp to both sides. On the attraction side bend the tines behind the ramp a good distance BEFORE the attracting magnet. The bend angle should be 30-45 degrees. The attracting magnet's pull should be able to draw the rotor on past the ramp at this point. We want the ramp far enough to minimize the induction from the attracting magnet, yet close enough so when the rotor magnet reaches the end of the ramp the attracting magnet's influence is great enough to continue rotation. Take note, if your ramps are not thick enough, the bend will create a sticky spot. The magnet will see a thicker mass of metal at the bend. We do not want this. What we are doing with the bend is sending the traveling North pole behind the ramp and away from the rotor magnet so it does not slow the rotor's acceleration. This direction is for the attraction side only, leave the repelling side at full length for now. I use ramps on both sides to HELP maintain balance during testing.
    I have not mentioned what has already been discussed regarding the ramp angles, curvature and fork. I assume everyone knows what to do in those previously hashed out areas.
    Onward,
    Randy
  • BroMikey
    So, are you saying that if you are holding the rotor still, near the narrow side of the ramp. You let go of the rotor, it will then accelerate beyond the ramp without trying to return to the ramp?
    Randy
    I made another grain oriented ramp the right size today. I am not happy
    with my round magnets and will have to order some square ones next week.
    The elevation on the rotor is in order so i can get my tines under better
    and give me a little room. I built this unit not knowing my magnets
    would need to be held from the back pole and enough room above and
    below to set up the "Y" ramps. I am cutting in the rotor for
    tighter clearances as well. I am not ready for a video yet. Hang in
    there Mack I hope you don't get bored to death in the mean time.
    Can't wait for monday when K&J magnetics sends me their data
    on magnetic flux contained in iron.
  • tachyoncatcher
    Exactly. No stator testing. The fork window area can not attract as
    there is no metal in the field. When my angle is right the rotor won't stay
    on the leading edge either. My tests show that when moving the ramp
    near the rotor it goes right past and keeps going away from the leading edge.
    It Ramps Everytime, it Ramps, meaning the ramp accelerates the
    rotor forward into the window where no field exists so she keeps
    on going.
    I just landed some huge transformer metal Goodie goodie.
    Randy
  • BroMikey
    Remove your stators and move the rotor past a ramp. Let it be attracted and find dead center. This will show you, geometrically where the magnet starts to find resistive forces to movement. Hand move the rotor magnet in the direction it will be turning and feel the forces at work as it rotates. This will be a very enlightening exercise. I can tell you what to expect, as I have, but until you do it you won't believe it.
    on going.
  • tachyoncatcher
    Magnetic Fields
    Hello Randy,
    I am sorry but there are some points you've mentioned above that I don't agree...
    When we set the Ramp forks that close to Stator interacting pole, according to Mack's design...we can not ignore the field from that pole will be completely distorted/redirected towards the ramp ending forks, and that is Induction from Stator Pole to iron forks...
    Now, by setting this Ramp to Stator Pole the way we have seen according to Mack's CAD...we are weakening that pole strength, related to the other side in repulsion...then repulsion prevails. And here is where the careful work of choosing the right size/mass Ramp that will eventually weaken...but not that much...in order that rotor will gain inertia and give us that desired "power stroke" after passing the attract point.
    For example, the ramp I have shown previously does not work...it is too big...so it weakens the south pole from stator too much, to the point the repulse side becomes too strong to make that "acceleration jump" by itself...so no power stroke shown unless too much force is applied to rotor...which is absolutely not good...ramp should give us that required self acceleration gain to pass without that much effort from just getting slowly rotor magnet close to ramp...it should be like an "automatic pilot" in "resume speed" (self acceleration to previous speed)...
    Mack writes about this when he makes that rig of a plate and a spring to test power strokes...from this point we will find out which ramp mass and shape will and not work...and once we have the right size ramp...then we could calculate the rotor size/circumference.
    If You already have a completely balanced two poles...then you should have noticed that just by getting some way the ramp close to the attracting stator pole...the balance is broken...you take ramp off and balance is back again.
    Hi Ufo,
    I agree the forks are induced by the close proximity of the stator magnets. However, through the experiments I've done I have observed the following.
    • The fork ends will always have a north pole coherency as the rotor moves past regardless of the nearby stator.
    • Balance is regained when both, opposing stators have a ramp.
    Is it perfect? No. But it is very closed to what is was before the ramps where put into place.
    Something else to think about. The magnet will be attracted to the ramp whether it is in front of the pole of the magnet or above and below, on the side of the magnet. Don't give up on your previous ramps just yet. Think about the ends having a north pole polarity and how the placement of that polarity will help us at the right time during rotation.
    Something I have done and would suggest everyone to try. Remove your stators and move the rotor past a ramp. Let it be attracted and find dead center. This will show you, geometrically where the magnet starts to find resistive forces to movement. Hand move the rotor magnet in the direction it will be turning and feel the forces at work as it rotates. This will be a very enlightening exercise. I can tell you what to expect, as I have, but until you do it you won't believe it.
    For the attraction side, when free wheeling, we want the magnet to stop on the ramp closer to where the attracting magnet would be. The fork reduces this back attraction by changing the attraction vectors. Mack is right. He has not shared what is needed to make this machine run. Only the long known principles behind its success. It is up to us to figure out the best geometry for these ramps. That is the key! I had my motor fully assembled and balanced. Twice! It is again apart as I maximize these damn ramps. This is a very dynamic build and we must always think about where those fields are moving. And move they do!
    Mike: I'm jealous. It takes me hours to make those ramps with a jigsaw.
    Good Luck with your build,
    Randy
  • BroMikey
    Yes I call it the magic. There is a place where balance still exists if my ramp
    is not to big. I just made one today to big. But I made them very quickly.
    I can make a ramp in minutes. I have some fancy metal chop table tools with
    14" cutt off wheels. Big Big vices and this metal doesn't have a chance.
    Just 30 minutes ago I have ascertained the same. Too big steels(PUN)
    all the FUN out of the magic. Thanks UFO, Dido
    confirmed!!
  • Ufopolitics
    Mike,
    In my opinion you have to expand your thinking beyond the polarity. If we think only of polarity, we have balance. No rotation. I'll refer to a comment I made earlier in this thread:
    The ramps on the attraction stator accelerates the rotor due to magnetic induction, not because the stator magnet is attracting.
    Mike, when I refer to "magnetic induction" I'm talking about the attractive force between the rotor magnet and the iron, not the polarity. The reasons for the split is to minimize the inducement from the stator magnets. So you see, we are not sharing the polarity of the stator magnet with the ramps. Quite the opposite. The polarities of the stator and rotor magnets will come into play later. Once we have ramps that cause acceleration of the rotor with stator and rotor magnets in perfect balance.
    What's worth repeating is there are two separate forces at work in this motor and are treated as separate with careful engineering and attention to geometry to keep them that way. The attractive force of a magnet to iron/steel and the balanced polarity forces of the magnets to each other. In my opinion, this is what makes this different from all the other "magnet motors" out there. No wasted movement to bias the magnetic fields.
    Something to keep in mind, a magnet will seek the closest point to the middle of the iron mass. This is why we angle the ramps. The rotor magnet keeps trying to get closer by rotating to the smaller gap of the ramp. Simple.
    Randy
    Hello Randy,
  • BroMikey
    Mike,
    In my opinion ----------------- The reasons for the split is to minimize the inducement from the stator magnets. So you see, we are not sharing the polarity of the stator magnet with the ramps. Quite the opposite.
    What's worth repeating is there are two separate forces at work in this motor and are treated as separate with careful engineering and attention to geometry to keep them that way. The attractive force of a magnet to iron/steel and the balanced polarity forces of the magnets to each other. In my opinion---------------------------
    Yes and I treasure your opinion Randy. It is clear that you have looked
    at other magnet motors before, not me. I am a green horn.
    I will have to digest these comments and let me say this after some
    testing. You must be right because the ramps work on either side the
    same way and if polatity is all that we have coming into play this
    makes no sense at tall. Example. When I switch to repulsion using
    the back of the stator magnet I get huge cogging. The smooth transition
    I got on the attraction side is not there. However if I do the same thing
    on both sides it works great. So my conclusion is that you are right
    about polarity not being the source for the power stroke.
    I don't know what to say. I need to time now. My ramps are misshapen
    at present and need to order square magnets as well. Maybe roller
    skate bearings and pull out my plastic sheeting. Brass bolts are cheap and
    my milling cutter will be getting dusted off My lathe is not connected
    up to 240vac but maybe I will spin up this small rotor on the big drill press
    no problem. Very interesting.
    Yes agreed Randy and thanks for your opinion right
    when I am thinking on that subject and testing.
    Induction WITH the forks is MAGIC. All other shapes are trash can objects.
    Now that I have experienced the MAGIC and have felt it's effects I
    will never be the same. Thanks Mack.
    NOTE: I contacted K7J Magnetics for their technical bulletins.
  • tachyoncatcher
    Think Simple
    Mike,
    Thanks for that Mack. It is the direction I have been moving. It has been my thought process that with the polarity in balance you must have another force to cause the rotation. That of inductive attraction, not polarity. If it was strictly polarity, you would have balance, an equal push and pull. Not a formula for movement.
    Randy
