Magnet motor revelation
Ok.That was funny. What about the REAL running magnetic motor in REAL world ?
Btw you didn't realized I posted old patent describing similar embodiment with additional ratched device and lever? Two opposite side magnets must be moved simultaneously using lever and rotor is advanced by ratched device working on the shaft gear. it worked in 1918 and I'm sure it would work now
Newton's law always apply and I deduced "magnetic rules" from them ,one of them is :
if there are no combined forces (like aded torque from gravity or electric circuit) then
for magnetic motor to run in one direction it has to be a part of device moving in opposite direction, the overall movement cancel to zero momentum in outside point of view.
You can call it "bogus-law"
you don't see it because I posted it on overunityresearch.com forum
but I'm not supressing information - I'm spreading it out
So here you have it......Attached Files
Originally posted by boguslaw View Postyou don't see it because I posted it on overunityresearch.com forum
Fair enough Bog-ManI'll try to make heads or tails out of this
patent. I think you are saying that I can learn a truth about
forces from this device? I don't know how good I am at reading
these documents shrouded with deliberate lies. If you could repeat
yourself as to what you have gotten out of this, maybe I will
learn something from it. What do you say about the Magnetic
motor patent? Yes it has a horse shoe magnet and gears.Last edited by BroMikey; 10-02-2015, 09:10 AM.
This is what you are trying to make : https://www.youtube.com/watch?v=lw3iONtBM0E
but what I posted is much powerful based on the same principle, but obviously require very good skills in mechanics
Completely Different Machines...
Originally posted by boguslaw View PostThis is what you are trying to make : https://www.youtube.com/watch?v=lw3iONtBM0E
That Motor you have shown is all about "Moving Mechanical Parts" in order to achieve rotor spin...
The Concept displayed here by MadMack is all about STATIONARY Parts except the Rotor assy...So, Rotor Magnets are stationary/fixed to rotor plate, and so Stators, Ramps, Shunts, etc ...NONE move here at all except rotor assembly.
Stationary Ramps generate a Positive to rotation Unbalance to our previously balanced rotor-stators.
What's the matter?...didn't you watch My Motor Running Video?!...Didn't you notice ALL Ramps were stationary?
The Motor you have seen on video is just a reproduction in CGI from the REAL one...which is still in the process to be finished.
There are many, many other motors like the one you have shown...where stators or ramps swivel/move...and that go faster too.
Take care and be patient...
UfopoliticsLast edited by Ufopolitics; 10-02-2015, 02:31 PM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Nice rotor...
Originally posted by Siggi1974 View PostHi,
Here my rotor design.
Best regards
Siggi
Hey Siggi, nice rotor design...
Just make sure the locking bolts-plastic washers do lock very secure, cause the stator's magnets are gonna try very hard to get them center aligned...basically the attract stage...throwing off your gap and angles.
I used four brass bolts-nuts plus a dual brass bracket to secure rotor magnets firmly.
UfopoliticsPrinciples for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
Thanks!
Hey Ufo,
thanks for the Feedback. Can you perhaps post a picture of your fixing? I am considering to fix the Magnet carrier completely by glueing after adjusting.....
Thanks again mate.
Best regards
SiggiAsymmetry is the Key for free energy
Four Poles...not good.
Thanks again mate.
Best regards
Siggi
I will later this afternoon...can't now.
Now, I wouldn't fix rotor magnets on just the two poles, till you have the next pair ramp, since as you add magnets poles you will have to keep adjusting...
I am also noting that you´ve already made holes at 90º for a Four pole...which is not going to work...the smallest number-combinations that will work is Six poles, meaning every 60º...as per Mack´s first post...
UfopoliticsLast edited by Ufopolitics; 10-02-2015, 05:45 PM.Principles for the Development of a Complete Mind: Study the science of art. Study the art of science. Develop your senses- especially learn how to see. Realize that everything connects to everything else.― Leonardo da Vinci
I have some thoughts to share with those who have a balanced mag-motor
through following directions. Then we can add an attraction side fork
for the number 2 step in this process of moving forward. The question
arises as I have spun my 2 poled cell. How might the other side (Repulsion)
look compared to the attraction? The answer comes back like this.
This answer comes from common deductive reasoning some might
call speculative.
(1st) We must consider what we have been directed to do "UNDERSTAND"
understand what is going on with the first and second step. We see powerful
forces generated by neo magnets set to cancel each other. Always keep
this in mind. Next we divert the attraction side stator magnet pole with
what we call a ramp. This field is derived from the stator magnet, inducing
a rotor magnet into the direction of rotation for a time period until released.
The induction ramp accelerates the rotor magnet and does so without
any reversing effects by passing the ball so to speak. Passing the rotor
magnet through the window of the fork and allowing it to go free just
in time for the cancellation process.
So whatever is added to the repulsion side to create balance must also
release it's effects just in time for the repulsion side cancellation.
So I ask you this, as I asked myself the same question, what might the
repulsion side induction ramp look like? Or maybe you are thinking
that the repulsion side is left empty?
Or maybe it is not a ramp at all?
We know that the system cancellation has been referred to as
BALANCING the cell, so in order to achieve balance we might be
doing the same thing on the repulsion side as we have
been instructed to do on the attraction side? Or almost?
If this is true (Only a speculation) then a single cell needing to be
balanced might have the same induction ramp on the repulsion side to
aid the POWER STROKE. Then the repulsion ramp window would act
the same way to release the rotor magnet just in time to go through
the cancellation process once again.
Since the repulsion side is pushing the rotor magnet away from the
stator magnet a north pole rotor magnet would need a south field
induction ramp. So the forks would go on the back? I don't know if
that make sense. If so this would make a repulsion ramps shape
different. Or would the forks be closer to the stator magnets south?
All healthy questions.
However since repulsion forces are slightly weaker than attractive
forces the feeler gauges would need to come out. Another idea would
be to compensate for the weaker forces by a slight increase in mass
for repulsion ramps. Or changing the angle on the repulsion side to
a closer position as compared to the gap on the attraction side.
Again the feeler gauges come out.
As I said all speculation, but this is the way I think things through.
Balance must be maintained as well as induction.
As I see it now on the attraction side a north pole rotor magnet
is temporarily induced in the direction of rotation by a south field then
that field goes back to it's origin (STATOR MAGNET) for cancellation.
In the case of the repulsion side you can also deduct many things.
Starting with the fact that no physical space has been allotted for
a ramp to be mounted after the cancellation process. This leaves us only
a space to work with before the cancellation process takes place just as
we see with the attraction side.
The $50,000 question is what might the third step look like with these
facts in mind? What it looks like to me is the same process in the reverse
format. Just kidding around. I am only having fun
speculating. For those of you who do not understand, this is called
deductive reasoning. Mikey's Mental Pinball.
Either way this is an exciting moment in history if you ask me and we
will have to leave the next directive to our highly favored MadMack.Last edited by BroMikey; 10-03-2015, 10:03 AM.
Think Simple
Mike,
In my opinion you have to expand your thinking beyond the polarity. If we think only of polarity, we have balance. No rotation. I'll refer to a comment I made earlier in this thread:
Originally posted by tachyoncatcher View PostThanks for that Mack. It is the direction I have been moving. It has been my thought process that with the polarity in balance you must have another force to cause the rotation. That of inductive attraction, not polarity. If it was strictly polarity, you would have balance, an equal push and pull. Not a formula for movement.
Mike, when I refer to "magnetic induction" I'm talking about the attractive force between the rotor magnet and the iron, not the polarity. The reasons for the split is to minimize the inducement from the stator magnets. So you see, we are not sharing the polarity of the stator magnet with the ramps. Quite the opposite. The polarities of the stator and rotor magnets will come into play later. Once we have ramps that cause acceleration of the rotor with stator and rotor magnets in perfect balance.
What's worth repeating is there are two separate forces at work in this motor and are treated as separate with careful engineering and attention to geometry to keep them that way. The attractive force of a magnet to iron/steel and the balanced polarity forces of the magnets to each other. In my opinion, this is what makes this different from all the other "magnet motors" out there. No wasted movement to bias the magnetic fields.
Something to keep in mind, a magnet will seek the closest point to the middle of the iron mass. This is why we angle the ramps. The rotor magnet keeps trying to get closer by rotating to the smaller gap of the ramp. Simple.
RandyLast edited by tachyoncatcher; 10-03-2015, 04:38 PM.
