Magnet motor revelation
  • About a simple question...
    Hello to all,
    There are two comments from two different members building here and I am citing them both below...
    Originally posted by tachyoncatcher View Post
    It was never intended to self run nor increase acceleration by means of only two modules, two rotor magnets and two stators!...come on friend, you know that.
    No Ufo, I don't know that. In my mind and confirmed by Mack, each module is a duplicate of the first. A module being what you showed in the video. In my mind we should see constant rotation or even acceleration from one module. Unless excessive losses due to crappy bearings, or large berings and shaft are being used. Then, as we add modules we add additional power. If one module is insufficient to cause rotation on its own, then additional modules will not help.
    With only TWO stators and all the magnets on the rotor correctly tuned, it will either self run or it won't. Adding MORE stators will NOT make it work if it doesn't work with two, so don't waste your time!!!!! More stators will make it run faster and stronger, but unless it runs with just two, it will NEVER self run.
    I would like to know where in this Thread do Mack writes that just Two Stators with their respective Ramps...and the rotor with All Magnets properly set and aligned ...This configuration is supposed to deliver a continuous rotation?
    Honestly, I have not able to found such info written by Mack here...So, and if any of you has found it, please, by all means bring it on!!
    I have absolutely nothing against that possibility though...and as a matter of fact I will be VERY happy to be that way!!...since for me at this point due to personal circumstances is very hard just to build a single ramp...So, nothing would be more relieving than knowing just two ramps will do a full-constant rotation even at 2 RPM's ...I really could care less about torque and speed...BUT a FULL, Continuous rotation would be more than enough to demonstrate this motor works... that simple.
    Mack, whenever you have a chance,...please, correct me if I am wrong...or the other statement(s) cited above.
    Right now, I am building Two more Ramps...which are much longer than the ones seen on video...plus I have all rotor magnets mounted...
    The Ramps on Video are 45º in a Six Module set up where I have spaces of 60º between rotor magnets-stators......So, I have decided to also make ramps adjustable from 50º to 55º to play with them...and of course...the limit would be right there...in order to have at least 5º to get stators in when the whole assembly is on.
    Regards to all
    • Geometry
      Originally posted by MadMack View Post
      A simple experiment.
      Secure one of your neos to something. Take a nail and holding it by both ends touch the pole of the magnet with the nail crosswise to the magnet. Feel the amount of force it takes to pull the nail off.
      Take the nail and touch the magnet crosswise with the pointed tip of the nail over the center of the face so the nail contacts only half of the magnet pole. Compare the amount of force it takes to pull it away. It's noticeably less.
      Now take the nail and place the point of the nail in the center of the magnet pole, but this time hold the nail vertical to the magnet like you are going to hammer it in. It takes a lot less force to remove the nail.
      In Ufo's video, look at 2:46, as the rotor magnet passes the stator at the top.
      So, if one was to terminate the ramp to a point. Say, ending at the middle of stator magnet. The ramps "hold" on the rotor magnet would be diminished by geometry, even though the magnetic induction force is the same, as in the nail example. It's all in the geometry. Big heavy induction at the beginning, with gradual release using two forces. Decreasing distance between ramp and stator which maintains the pulling force past mass center, and shrinking mass through geometry which minimizes the release forces.
      My next test,
      Randy
      _
      • Originally posted by tachyoncatcher
        Mike,
        Get rid of that candle video. It's not even a good fake and totally irrelevant to what we are doing/discussing here.
        Randy
        What candle video?
        @Mack
        at 2:46 minute it shows the rotor magnet slowing and just how little
        kick force is present with all of that power available in magnets.
        • Ufo,
          I never wrote it because I never got a 2 pole like this one to actually motor. Logically, you would think that it would, but that was not my experience. I am not an expert on magnetics by any stretch of the imagination and I can only explain how this works in layman's terms. The back pull from a ramp has to be eliminated or dissipated as much as possible. The rotor acceleration has to extend to the point where the next ramp can start to take hold of the rotor magnet before any remaining back pull from the previous ramp can exert itself. Watch the video again about 1:07. You can see the acceleration out to about 210 clockwise degrees from vertical, then there is a tug that slows the rotor back down. It's not enough to stop the rotor but it does slow it down. Ufo, I do not want to discourage you but the two ramps in the video need more work. I hinted at that in my last post. The bottom one is OK but could be just a little better. The opposite ramps are not identical in my motors, in case that helps.
          This motor is similar to an internal combustion engine in this sense; the power produced is a sum of the power pulses in time. The more pulses per second, the higher the rate of power produced. It's the same with a gas engine, more HP as the rpm increases.
          Tachyoncatcher,
          I can't come right out and say where the ramps terminate. Sorry, that's a gray area I have to avoid. Study my reply to Ufo above. Otherwise, you got the idea. Remember the vectors at all times.
          BroMikey,
          At 2:46 you can see the rotor magnet experience a strong back pull right past the end of the top ramp.
          Mack
          • Too much beef!
            Mack,
            What i get from that video in slo-mo is there is too much metal at the end and the ramp extends too far beyond the stator magnets.
            Also, watching this brought to mind an image of my rotor passing the balanced magnets with no ramp. There is an acceleration, then deceleration that takes place as the magnets pass each other. It has got me thinking about the accelerations side and the ramps. I wonder if we can use the ramp ends to extend that acceleration of the rotor as it approaches the stators.
            Thanks Mike.
            Randy
            _
            • Originally posted by MadMack View Post
              Hi guys
              What I think Mack is saying is that surface area/mass of the fork tips
              and exposure area are all part of tuning. Mack says that UFO's video
              has a kick back at 2:46 like Shylo was talkin
              Look at the ramps. And think think think.....
              • Hi Friends,
                I also think that the ramps need to be shorter and more sharp at the stator, otherwise the tuning process of rotor and stator magnets to pass without of only a little drag would not make sense.
                Best regards
                Siggi
                Asymmetry is the Key for free energy
                • The blunt end of the top ramp. If the ramp is good up to that point then what if from that point on, the vector force between the ramp tines and rotor magnet remained at 0 while rotation continued and the attraction between the tines and rotor could also be reduced to 0?
                  Mack
                  • Luke, Feel the force!
                    Uh, I mean spread the force vectors. Spread the tines at the end. Couldn't help myself.
                    Randy
                    _
                      Mack
                      Hey Mack
                      I have this idea.
                      • Hi Mack,
                        That's good info ,understand that it is important.
                        Thanks artv
                        • Originally posted by shylo View Post
                          Hi Mack,
                          Thanks artv
                          hey Shylo
                          You were right in that a small kickback was there, I stand corrected.
                          However Mack did say that we are at the turning point and that even like
                          it is, the motor will run with 6 - 8 stations for ramps and magnets.
                          I have also been thinking about 8 stator magnets and ramps verses just adding
                          rotor magnets. And I think we need all of the ramps to make it go.
                          • Listen to this guy talk about shielding on a neo magnet N52
                            1" X 2" X 1/4" The goal is to create a one way force. He uses tin,
                            plastic spacers and dead carbon battery to space also.
                            It is not like our motor but he is the only one on youtube that
                            goes into great detail.
                            What if we could make the sticky spot 0 through shielding?
                            This is what he points out, that there is a sticky spot and
                            then he shows you his shielding solution. In our case we have
                            cancelled out much of the sticky spot and at the same time
                            are using the forks to redirect flux without moving parts. Now we
                            have been directed to further reduce any reverse pull, and shielding
                            maybe one answer.
                            [VIDEO]https://www.youtube.com/watch?v=KhY7hHb2l6o[/VIDEO]
                            • As we all know Mack has stated that fork tine terminations are
                              not revealed by him due to his more advanced work being patented by
                              another group. What if there were another material in the gap between
                              tine and stator magnet that constitutes terminate? I don't know, but at
                              the same time as we seek out the shielding benefits, I wanted to suggest
                              termination using the right shape or material might enhance what we are
                              desiring. A one way pull just like we have now but with 0 kick back.
                              It is just speculation on my part. Eddy currents are a powerful force.
                              [VIDEO]https://www.youtube.com/watch?v=Baq4whkHCIk[/VIDEO]
                              • Basic shielding knowledge base.
                                Our target is MAGNETIC SHIELDING not EMI shielding.
                                If you are like me you want to know how thick a standard shielding
                                metal should be. 1/4" or .001. In these videos you can find answers.
                                What types of materials? Magnetic Shielding facts. Ferite shielding as well.
                                If we are going to advance the design we need to come up to speed
                                on available information so we may GLEAN, there is that word, something
                                through experimental data on this rig. Some of you more advanced builders
                                do not need to view these materials so bare with me and those who
                                are unfamiliar with basic shielding application. It appears that all motors
                                using magnets have some form of shielding that redirects flux to one side.
                                Such as a hard drive magnet making flux stay on one side. MuMetal is a
                                high nickel content alloy and is not needed for this demonstration.
                                Save your nickels.
                                [VIDEO]https://www.youtube.com/watch?v=IXp5hgTG_Vc[/VIDEO]
                                [VIDEO]https://www.youtube.com/watch?v=NzqUum7MalE[/VIDEO]
                                [VIDEO]https://www.youtube.com/watch?v=pR2ZFnX9gnA[/VIDEO]
                                [VIDEO]https://www.youtube.com/watch?v=3aVxB9oXcEc[/VIDEO]
                                [VIDEO]https://www.youtube.com/watch?v=1TF5OaNu12Y[/VIDEO]
