cold electricity
I have cold electricity references by that very term going back to the early 1900's before Gerry Vassilatos was born.
You are correct that a manifestation of so-callled cold electricity is voltage with little to no current. But, that is only ONE form and is not the type of cold electricity used or referenced in other situations.
Bedini showed a Kromrey G-Field generator at the conference where the coil core's were warm but the magnets went super cold while it was running blowing out cold air. It also went faster and faster the more it was loaded and when shorting it out, it has a brilliant pure white spark - no blue, red or green in it. This is a different form of cold electricity that has nothing to do with voltage without current. This is a time-reversal process.
I made an inductive resistor drop 5C below ambient temperature - someone claimed it was rf cooling - I don't know. But this also is not cold electricity from voltage without current because in that case, it simply generates little to no heat, but does not reverse temperate and start getting colder. My circuit did.
There are other examples including one circuit I have that has amps but no positive voltage so there are no watts and it charges an inductor to run a motor - the complete opposite of voltage without current and that is cold electricity.
You are misrepresenting Eric's view on things - he is sitting right here, but we're too busy for him to lay it out in this thread.
